Old 02-17-2009, 09:25 AM   #841
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
Yeah, I have the XR650L and 400. I have the tank on the 650 and being able to swap them over for a trip to Mexico would be good, that 200 bucks for a new gas tank will keep me in Mexico for another week!!!!
So, it was the Acerbis brackets for the XR400 tank that you bought? 1/2" foam.
ordering now.
LaOutbackTrail is offline   Reply With Quote
Old 02-17-2009, 12:35 PM   #842
tworr
Oddometer: 14
It's the brackets that allow this tank to fit the 400.
The tank I ordered was the red XR650L(2142480229) 93-96 5.8gal tank.
It looks like this tank can fit different year models of XR250, XR400 with the correct brackets. Just tanks notes that it can also fit newer models of XR650L's.
"**Will fit All newer models with Modifications**
Modifications include: Relocating Blinkers and Shaving Frame pins to make this tank fit."
For me, the XR400 brackets were longer flat pieces of aluminum. I'll post the pictures tomorrow showing how they are almost 3" longer than stock to allow this tank to fit on the XR400.
If you already have the larger tank, then you could literally only spend $15 for the bracket to swap them back and forth.
1. That could get old really fast.
2. IT'S A RED 6 GALLON TANK!!! It may be a long time before there are any RED XR650 tanks again!!!
My bracket may have been cheaper because I requested it without the petcocks. I knew the tank came with the XR650 mounting kit that I didn't need and couldn't use. I was able use the petcocks from that kit without spending the extra money for XR400 mounting kit with petcocks.
tworr is offline   Reply With Quote
Old 02-17-2009, 05:47 PM   #843
tworr
Oddometer: 14
Originally Posted by DrLewall
are the 650 tank brackets available from dealer or they after market? Have any pix of the brackets??
It looks like my 650 mount kit was missing a couple of the parts, but I think you will get the idea of how it mounts.
I guess it's a good thing that I didn't need these parts and is probably why I ended up with them.
Edit: Cumbacheech pointed out that my kit was only missing the second support(#8).
new XR400 bracket for XR650L tank.
Stock mounts vs new tank brackets.
tworr screwed with this post 02-18-2009 at 06:40 AM
Old 02-17-2009, 05:55 PM   #844
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
My kit was missing the second support(#8) and rubber caps(#7).
FYI - You are not missing the and rubber caps(#7), those come from the tank shrouds (look and you will see them). So in case you ever get a xr650l and you want to use that tank at least you know where to find those rubber pieces.
Cumbacheech
Cumbacheech is offline   Reply With Quote
Old 02-17-2009, 06:44 PM   #845
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,574
TNX tworr! that helps alot and gives me some ideas for tank upgrade!
DrLewall is offline   Reply With Quote
Old 02-18-2009, 06:41 AM   #846
tworr
Oddometer: 14
Cumbacheech
Thanks Cumbacheech! I corrected it above.
Old 02-18-2009, 06:52 AM   #847
tworr
Oddometer: 14
Awesome!!
I couldn't find these brackets for the longest, but when I started asking for specs to make my own and I was suddenly able to buy some.
Old 02-19-2009, 08:30 AM   #848
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Well, I've been working on dual sporting the bike. I'm making my own harness and slowly building my kit. So far I'm at $55 bucks.
I'll start you off at the front.
I picked up a pair of spare front turn signals for my XR650L, this included the bracket that clamps to the triple clamp, it bolts right up and looks factory.
Spin this around here and look at the rear end.
The tail light is made by Acerbis. Includes tail, stop and plate lights and a place to hold the plate.
Unfortunately, it doesnt really work well, because it is aimed a little high.
But, she doesnt mind...
I also have these bags. They just need a strap holding them down and they'll be golden. I might drill a small hole in the plastic and just use a bolt.
I've also added Acerbis mirrors. I wanted to use a spare turn signal switch that came off of my XRL, but its disappeared. And I need a headlight with flasher, horn and a switch. I'll probably buy a switch anyways so that I can turn the light completely off.
This is the headlight I want. The DOT/CE approved Acerbis DHH.
I'll probably buy the handlebar switch from Procycle.us
This switch has high beam on indication as well as a total off switch.
Another $120 I'll be set.
Old 02-19-2009, 08:32 AM   #849
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Oh, and I have new grips.
Pro-Taper Pillow Top. I likes these! I put them on the XRL just before Mexico. and they are great.
I put the Tusk handguards from my wife's 225 onto the 400 also. Went on without a problem! But. None of my junk is lined up right.... I'll work on that...
LaOutbackTrail screwed with this post 02-19-2009 at 08:37 AM
Old 02-20-2009, 07:27 AM   #850
Chris W
Chris W's Avatar
Oddometer: 1,139
MX Style Rear Fender?
Has anyone come across a MX Style rear fender. One without the built in light or the "turn down"?
I ordered an acerbis "MX Style" off e-bay but the photo looked like it could have been a stock photo. It ended up being on backorder until sho knows when anyway so I canceled it.
Thanks.
Chris W
IBA #393
"I know I'm getting tired when I start ducking for over passes..." ~ Ardys Kellerman
Chris W is offline   Reply With Quote
Old 02-20-2009, 07:39 AM   #851
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Kinda off topic here but whats the deal with the starting hot or cold on these bikes? Im thinking of getting one thats been plated,a 98 I think.What are the fixes to make em start easily? Thanks!
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 02-20-2009, 07:52 AM   #852
Chris W
Chris W's Avatar
Oddometer: 1,139
Mine has a stock carb and jetting.
6 kicks when it's cold. One kick when it's hot.
Everytime.
Chris W
IBA #393
Old 02-20-2009, 07:54 AM   #853
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,973
Everytime.
Pretty much the same for me. If it is getting harder to start, I adjust the valves, and it's super easy again.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 02-20-2009, 08:20 AM   #854
Squeaky
A Few Loose Screws...
Squeaky's Avatar
Oddometer: 1,610
Turn the idle up to get it started, back it down after it's warmed up.
Rebecca
Houston, TX
'03 VStrom 1k "Wilbur"
'98 XR400R "Templeton"
Squeaky is offline   Reply With Quote
Old 02-20-2009, 08:48 AM   #855
playzNmud
I love pedal derby
playzNmud's Avatar
Oddometer: 4,080
Hi ALL
I posted up a while back about having an online manual for the XR400 - but was unable to send it out due to it's size (100MB)
I have a program with limited time (14 days) I can use to send this out. It takes about 30 minutes to send it... .so, if anybody is interested please let me know SOON, and I will send it out to you.
J.
*PM me with your real email addy....
XR400
```_o
`_-\<,_
(_)/_(_)
playzNmud screwed with this post 02-20-2009 at 09:01 AM
playzNmud is offline   Reply With Quote
Times are GMT -7.   It's 12:22 PM.
