01-17-2008, 05:28 AM
#1 |
On roads less travelled
Oddometer: 295
640 Adventure Electrical Reliability
I’ve been trying to find info (without much luck) on the reliability of the 640 adventure CDI and other critical electrical components like the ignition coil that the bike will not run without. Some parts you can limp home without but if the CDI goes you’re done if you’re in the middle of nowhere. Even if you’re on paved roads it could be a long wait for a replacement.
Do any of you carry a spare CDI or coil, stator, or other specific electrical component. I know it’s a lot of pricey parts to carry and may never need them. How many have actually been stranded in the middle of nowhere from this type of failure? Mines an 07 btw. |
01-17-2008, 06:17 AM
#2 |
making chips
Oddometer: 26,648
in my years hanging about there i don't recall hearing about any ignition failures. not to say they don't happen, but if they do nobody has mentioned it (that i've seen).
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 *** Stenhouse Racing - Specializing in KTM Upgrades custom cnc service available to suit your specific needs. |
01-17-2008, 06:49 AM
#3 |
Wandering
Oddometer: 115
I researched the same questions, came up with nothing. Only problem I have had electrically was the solenoid wires breaking at the solenoid plug on the bike wiring harness side. This was more just a pain in the backside as the bike would start if you kicked it.
You must be planning a run??? Flueger
01-17-2008, 07:05 AM
#4 | |
making chips
Oddometer: 26,648
1) a wire came loose under the dash. took 30 minutes to diagnose, then fix at the road side 2) a wire broke through and grounded on my sub frame. took about two hours to diagnose and repair in a hotel parking lot as it was getting dark. i left my cel phone charger on and it drained the battery once too... easy fix for that one though
01-17-2008, 07:24 AM
#5 |
Oddometer: 295
The occasional loose connection I'm ok with and know it will happen at some point, although still a PITA, doing electrical for a living helps with the troubleshooting. I've figured out how to bypass some of the minor switches etc that the bike will run without, I'll pack some premade jumpers just in case. Recently I found the capacitor just about falling off along with the rubber tank mount.
Re planning a run, up into Northern Ontario, maybe James Bay... |
01-17-2008, 07:33 AM
#6 |
Oddometer: 814
Ignition pulser?
One possible show stopper. |
01-17-2008, 07:36 AM
#7 |
Xtankteam™
CDI's hardly ever break. If something goes wrong eletrically, in most cases it's connectors and or chafed wiring.
Click here for an auxiliary sidetank for the BMW Xchallenge . Click here for a recalibrated speedo ring for the BMW G650X series . Max Kool screwed with this post 01-17-2008 at 07:41 AM |
01-17-2008, 08:23 AM
#8 |
No Whammy,No Whammy,STOP!
Oddometer: 1,051
Double check your wire routing, especially after doing any work that moves things around - sub frame, accessory installs. I've had a few cases of wires rubbing through. Sometimes it takes awhile to diagnose. So I shrink tubed any wires that could potentially rub through. I carry a small spool of wire and fuses. That's about it. Oh, and of course the taillight.
01-17-2008, 11:21 AM
#9 |
Oddometer: 295
Good to hear the problems are at a minimum. Thanks for the input
01-17-2008, 12:04 PM
#10 |
I'm alive.
I have about 50 000 km on mine, no electrical problems YET.
I have a friend with about 150 000 km on her 2000 and I don't remember hearing a story about electrical problems. Hell though, if you have the cash and the spare room to carry that stuff, go ahead. |
01-17-2008, 01:51 PM
#11 |
Trans-Global Chook Chaser
Oddometer: 2,737
45 000 km on mine & no electrical problems (apart from that damn taillight bulb holder, which is a fairly easy fix) I have noticed the odd vulnerable bit of loom here & there which I have pre-emptively wrapped up or zip tied into a better position though.
Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
01-18-2008, 03:17 AM
#12 |
Traveler
Oddometer: 4,070
Keep an eye on the fuse holders and give them a little squeeze to tighten the connections. My bike went dead and it was the main fuse holder. The 20 amp one near the battery. Carry twice as many fuses as you think you need, carry a spare head and tail light bulb.
Check the wires where they exit the CDI, they wear against each other. I squirted a gob of silicone glue there. Plug and unplug everything every 10K miles. I oil my connections, others use dielectric grease. Anything to stop corossion. Tighten the plug cap connection. Take your wiring diagram to the copy store and have it supersized, use the best paper or map paper. Down load and print the electrical troubleshooting section of the factory repair manual. Buy this Radio Shack multimeter, it's a good one and will do all the tests. http://www.radioshack.com/product/in...ductId=2104114 b.
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley bmwktmbill screwed with this post 01-18-2008 at 03:27 AM |
01-18-2008, 04:35 AM
#13 |
bp
Oddometer: 616
My '05 has proved pretty sound to date but only 11,500km.
Spade lug on one of the front brake lever popped off and shorted to ground which blew a 10amp fuse next to the battery. Took out the speedo and all lighting. Battery terminal came loose also but I think a routine check of all electrical and mechanical fasteners (loctite the mechanical) is mandatory on these jackhammers.
'05 640 Adventure |
01-18-2008, 09:42 AM
#14 |
Oddometer: 295
From all the replies I won't be running out to buy a bunch of pricey spare parts
01-18-2008, 11:35 AM
#15 |
Oddometer: 58
I did have to buy a wiring harness for my 450exc but only a fuse for the 640.
Lovin it GASGAS 300 KTM 450exc KTM 640 adventure |
