Old 01-21-2008, 03:21 AM   #16
Joerg
Joerg's Avatar
Oddometer: 1,356
Thumb Lots of!
Originally Posted by motoboyvfr
Does anyone know if there's a reliable driveshaft rebuilding service out there?
Lots of ... at least in Europe.
Just for the record: The BMW airhead driveshaft u-joints can be replaced by "any" shop that does standard cardan overhaul ... they do not need to be specialized in motorcycles. The complete u-joint is available as a spare part from their suppliers, and the exchange as such is pretty much a routine procedure. Cost was, two years ago and in my area , about 130 CHF = 80 EUR = 120 USD per joint, plus shipping.
- Joerg
1990 BMW R80GS and K100LT * Lausanne, Switzerland
My Motorcycle WebPages - LED voltage monitor (aka charge light)
Joerg is offline   Reply With Quote
Old 01-21-2008, 08:42 AM   #17
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,898
Originally Posted by mark1305
At risk of causing undue thread-drift, when is a good point in time/mileage to check the shaft for twist?
Having recently joined the airhead community with a 83 R80 ST under 35k miles
I think you are exempt from this discussion! The ST is a monolever bike which uses a totally different driveshaft design that - the best of my knowledge - does not have the issues of the later model paralever bikes, especially the GS bikes.
Maybe it's because there is only one u-joint on the driveshaft or that it is bathed in fluid?
Anthing else?
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 01-21-2008, 09:35 AM   #18
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,181
Anthing else?
oh, man.. every once in a while I get it proved to me how dense I am. Thanks for the catch. I assumed we were talking paralever witout fully reading. DOH
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 01-21-2008, 06:36 PM   #19
TEXASYETI
TEXASYETI's Avatar
Oddometer: 1,898
I was referring to Mark1305's post, not the OP. I believe in regards to the OP you are right on track as always!
1981 R80G/S
1991 R100 GSPD
Old 01-21-2008, 06:48 PM   #20
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,181
Maybe not-- He doesnt specify, (only says Airhead shaft?) and I have a only the 77RSin the sig to base a guess on, but didnt till now...
SO which is it, Motoboy? Mono or Paralever?
Old 01-21-2008, 08:43 PM   #21
kbasa
Colnago!
kbasa's Avatar
Oddometer: 67,827
'78 R100.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 01-21-2008, 08:45 PM   #22
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,181
Originally Posted by kbasa
'78 R100.
/me slaps forehead and heads for bed
Old 01-21-2008, 09:16 PM   #23
TEXASYETI
TEXASYETI's Avatar
Oddometer: 1,898
Well gosh darn! That is what happens when you ask a bunch of people who have been traumatized by BMW and their tendency to introduce a "new" design which is supposedly better then the previous.
Didn't he ask about circlips on his output shaft too! What about diode board mounts?
No?
Let's talk about it anyway!
1981 R80G/S
1991 R100 GSPD
Old 01-21-2008, 11:17 PM   #24
TheBigMuff
UNFKNBLVBL
TheBigMuff's Avatar
Oddometer: 52
R80ST shaft repair not needed
Having recently joined the airhead community with a 83 R80 ST under 35k miles, I've done all the peace-of-mind things like all fluids & oils, spline lube, SHB and swingarm bearings check & lube, valve check & adjust, etc., but am trying to get away from the tear-everything-apart-and-check-it mentality I've used on other bikes.
SNIP
The ST has the monolever shaft; it is the road version of the original g/s with single universal joint that is almost perfectly in line with the shaft. Also the shaft and uni are bathed (lubed and cooled) in gear oil. I have never heard of a monolever shaft needing repair [I meant actually breaking] so would be very surprised if it needs repair at such low miles. Check it at 100k...
You should however consider a spline lube if it has not already been done. I pulled mine at 10 years / 55k km and it was dry - definitely needed doing.
Good luck Lachlan
TheBigMuff screwed with this post 01-22-2008 at 06:37 AM
TheBigMuff is offline   Reply With Quote
Old 01-22-2008, 12:54 AM   #25
Joerg
Joerg's Avatar
Oddometer: 1,356
Hi,
Well ... at 87 Mm, the driveshaft of my 1981 R100TIC needed an overhaul since the U-joint had developed some play. At the same time I changed that damper spring on the shaft, which caused a "clonking" noise upon acceleration. More: http://homepage.sunrise.ch/mysunrise...htm#driveshaft
OK - strictly speaking this is not a monolever, but the driveshaft design is the same anyway
And my comments above about the "repair in almost every shop" hold for that one, too - the dimensions of the U-joint are the same.
- Joerg
Old 01-22-2008, 03:21 AM   #26
Andy-Gadget
Any bike can go anywere
Andy-Gadget's Avatar
Oddometer: 1,344
Years ago I had a problem with my RS's final drive, if I engine braked to a stop, it would clunk when I released the clutch to take off again.
I pulled the swinging arm out looking for the cause, and found this.
This is the wire clip that holds the whole cush drive together.
What I figured had happened was the collar that normally covers the wire clip and hold it in place should have been stationary relative to the wire clip and move in relation to the rear cush cam.
In my bikes case the collar was stationary relative to the cush cam and moving on the wire clip.
It didn't have far to go to failure, and while I can't confirm it, I suspect that the cush cams would have come far enough apart to stop driving, as it will move backwards until hitting the end of the final drive pinion.
My fix was to replace it with an old model non-cush drive shaft, that I happened to have
"If a man empties his purse into his head, no man can take it away from him.
An investment in knowledge always pays the best interest"
Benjamin Franklin.
'95 Sport 1100 Guzzi,'84 Cali 2 Guzzi, '95 Guzzi mille, '84 R65LS, '84 R100, '82 R100RS, '05 DL650, '72 Bultaco Sherpa T 350, '78 Montessa 348, "00 XR650R
Andy-Gadget is online now   Reply With Quote
Old 01-22-2008, 06:27 AM   #27
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,011
The ST has the monolever shaft; it is the road version of the original g/s with single universal joint that is almost perfectly in line with the shaft. Also the shaft and uni are bathed (lubed and cooled) in gear oil. I have never heard of a monolever shaft needing repair so would be very surprised if it needs repair at such low miles. Check it at 100k...
Good luck Lachlan
Whewhhh!. Thanks for the catch, guys. I can rest easier now. The bike is without any symptoms. When I first got it I checked for clunks and lubed the splines along with changing all gear oils. I was happy to find the splines still had grease and no rust fro the last time they were attended to. Oils all looked good.
So life will be good for many miles, I hope.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-22-2008, 08:45 AM   #28
motoboyvfr
Guest
Oddometer: n/a
Shaft Resolution
The shaft in question is on a '78 R100S. It's the old type that's connected with a tapered shaft (interference fit) and a nut inside the clutch bell housing. I attempted to disassemble it in a machine shop last week and it wouldn't budge.
After looking at some different options, I've decided to send the swing arm to Max BMW and have them disassemble the shaft and remove the bearings so I can powdercoat the arm and install a new shaft and bearings later.
This is the best solution I can find unless someone has the shaft and bearing puller sitting around that they're willing to lend or rent to me.
Old 01-22-2008, 08:46 AM   #29
motoboyvfr
Guest
Oddometer: n/a
1977 R100S.
Old 07-17-2010, 02:30 AM   #30
rockyuk
rockyuk's Avatar
Oddometer: 49
driveshaft spring
Thank you Joerg for your explanation of driveshaft rebuild on your website and especially about building your own compressing tool.I had been putting off this job for a long time but your site gave me the push i needed. Also remember i am new at this sort of thing (i,m a builder) so was a little apprehensive.
[IMG][/IMG]
Here is prototype #2 of your tool. You should have put a patent on it
[IMG][/IMG]
out with the old in with the new
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
To fit the new spring circlip was tricky.I used 4 thin screwdrivers, 3 in one hand and 1 in my spare hand!
Now we are happy again. I had actually gotten used to the slight clunk and play in the driveshaft that i was compensating for it in my slow-speed riding. Now its like a new bike,so much smoother.
[IMG][/IMG]
Next i have to eliminate that clunk from the forks, or should i just empty out all the junk from the fairing pockets.
Thanks again Joerg youre a star. The last time i entered your country the border policeman asked me for 20Euro Swiss tax. I was unsure of the currency at the time and after fumbling in my pocket i handed him 20 Cent.The look on his face was priceless.
[IMG][/IMG]
rockyuk is offline   Reply With Quote
Times are GMT -7.   It's 01:43 AM.
