Old 01-19-2008, 08:39 AM   #1
mybeamishboy OP
My Beamish Boy
Oddometer: 14
Bluhduh LC4 Starting Tricks?
I have a 2006 KTM 640 Adventure that runs fine and starts fine .... unless it has sat for more than a week or so.
Since it's not my daily rider, I find myself dreading to ride it because it will take 30 minutes (seat removal, jumping the battery, reassembly, etc). Once running everything will be fine until it sits again.
Is there something I should know about before I fry a starter?
FWIW, I have 8 bikes; KLR650, Triumph S4, A couple of Ducati's, etc ... and have ridden since the late 1960's ... so I think I know the basics of cranking a bike (even my old BSA).
Any thoughts or suggestions would be appreciated.
mybeamishboy is offline   Reply With Quote
Old 01-19-2008, 09:07 AM   #2
arcgotic
Oddometer: 6
Hi man,
i don't know about temps in your area, i live in romania, now there is 3Celsius outside. I started my '98 LC4, last started 1month ago, with help from a break-disk cleaner spray. Just spraied a little on the air filter, and the bike started on first kick (no batery/electric starter here). There are special sprays for starting engines at cold, but any spray high-flamable will do the trick.
Hope this help!
Cheers,
Dani
arcgotic is offline   Reply With Quote
Old 01-19-2008, 09:09 AM   #3
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,232
It's got a kick starter as well, ya know. A lot faster than taking the seat off.
How does it "not start?" Not Crank? Crank over endlessly without firing?
Luke is online now   Reply With Quote
Old 01-19-2008, 09:44 AM   #4
nfranco
over macho grande?
nfranco's Avatar
Oddometer: 790
try this
one of these:
http://batterytender.com/product_info.php?products_id=2
with one of these, scroll down about 2/3:
http://easternbeaver.com/Main/Produc...nkbag_sae.html
plug it into the socket on the dash, happy battery.
nfranco is online now   Reply With Quote
Old 01-19-2008, 10:18 AM   #5
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,328
When mine has been sitting a few weeks (rare) i find it easier to start if i engage the choke, hold in the decomp and kick it a few times.. then release decomp and give the button a stab.
Usually fires right up
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 01-19-2008, 12:20 PM   #6
sherpa
...Robert
sherpa's Avatar
Oddometer: 3,183
Not sure what you are saying exactly.
Is the battery dead when you go to start it or does it crank over fine at first but because it doesn't fire up you end up draining the battery cranking it over for so long?
Trebor Home Inspections
05 640 Adventure
08 KTM 250 XCFW
I'd trade all my motorcycles for one Flying Dragon.
sherpa is offline   Reply With Quote
Old 01-19-2008, 12:40 PM   #7
Zerodog
Oddometer: 1,233
There was another dude with the same kind of issues you are saying last week. There are a few things to remember.
When using the choke do not touch the throttle until the bike fires. It defeats the choke circuit.
It is cold. You probably need to open your fuel screw a bit to make the bike richer on the bottom end. It will make cold starting a lot easier.
Another thing is this. Your float could be a bit stuck. Leaning the bike over until you get gas to puke out of the overflow first ensures your float bowl is full before you try to start it.
Little batteries get their asses kicked by the cold. If you don't get it fired quick you might run out of juice. A battery tender helps. But you should get your bike started quick if it is jetted right.
Zerodog is offline   Reply With Quote
Old 01-19-2008, 03:44 PM   #8
idahoskiguy
idahoskiguy's Avatar
Oddometer: 1,134
Most likely your battery is on the way out and needs to be replaced, suggest a good AGM type battery for about $100.00. They are worth the $$$s and hold up to the vibes. My 2001 640ADV can kill a cheap battery in 500 miles of DS riding, have not had any trouble since installing the AGM type battery, and it can sit for weeks without discharging.
+1 for battery tender, but your battery should not discharge in a week so you may want to check for a current drain somewhere in the system.
idahoskiguy is offline   Reply With Quote
Old 01-19-2008, 06:15 PM   #9
mybeamishboy OP
My Beamish Boy
Oddometer: 14
Thanks for all the responses.
Thanks guys. I think I can address a few of the issues brought up:
1) Not that cold. I am in Atlanta and the bike is in a heater garage. Cold definitely not the problem. Besides the issue existed in the summer.
2) Bike turns over .... and over .... and over.... until the battery gasps and dies.
3) I do already keep a battery tender on the bike (pigtail extension, the works).
4) I have not reason to think its a fuel problem .. although a stuck float is possible.
5) I should mention that after the third or fourth episode of this nonsense I added some Sea Foam to the gas ... didn't make a difference.
6) I have gone at it (with a full battery) without first touching the throttle. Zip.
7) i don't believe in Motorcycle Voodoo (my 1971 BSA convinced me that any bike can be conquered with enough determination, blood, and money). I know there is some silly something I am not seeing.
Or ..... I could trade up for a 950 Adventure ... hmmmm.
Old 01-20-2008, 01:04 AM   #10
AusStealth
Bohican
AusStealth's Avatar
Oddometer: 775
This is a long shot, and before anyone rubbishes the idea, its based on a sequence of events with my 06.
From new I couldn't work out why it stalled for no apparent reason some times, usually in a snotty bit of track! Over time, starting after a week or two of no use became harder. After about 9 months, one day it no longer started at all. Fuel..OK Cranking speed...OK Spark..NOT OK.
The ignition trigger unit on the motor had failed. Once replaced all of the above issues have gone.
So, just a chance that yours is on its way out too.
If I'm wrong then you'd better be right.....
AusStealth is offline   Reply With Quote
Old 01-20-2008, 03:22 AM   #11
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 842
Too warm?
Lighter parts of fuel slowly evaporates -> Hard to ignite.
Drain float bowl and fill with fresh fuel.
Seikkailu_R is offline   Reply With Quote
Old 01-20-2008, 05:35 AM   #12
ediehl
Oddometer: 143
I've got a recemtly acquired '01 LC4 with a brand new battery (and rejetted for an SXC pipe), and it's reluctant to start when cold. I use a battery tender. One interesting thing I've noticed is that it seems to be more inclined to start if I turn the choke all or partially off. Seems counterintuitive. I wonder if the choke mechanism isn't functioning properly, or if maybe the carb is overly rich on the low speed jet? It almost seems easier to kick start when it's cold (well, I don't know about easier (for me)---maybe I should say the engine is more inclined to fire up when kick-started when cold)
Eric
ediehl is offline   Reply With Quote
Old 01-20-2008, 06:59 AM   #13
mo' tarded
Turnip Truck Driver
mo' tarded's Avatar
Oddometer: 133
How many miles are on the bike?
KTM's with the HIGH flow head have been known to be hard to start if the valves are out of spec.
You may also need to give the carb a good once over with carb cleaner. Sounds like a clogged or partially clogged circuit/jet.
Have you done the BST mods?
"What is a villiage without village idiots?" - Stanley Marsh
SMC ... of course
mo' tarded is offline   Reply With Quote
Old 01-20-2008, 08:17 AM   #14
boney
Ride > Post
boney's Avatar
Oddometer: 1,406
Perhaps it's flooded. If your needle valve doesn't seat correctly it's possible that you've got raw fuel in the cylinder and choking it only makes it worse.
Try starting it without the choke or even opening the throttle a bit.
If you don't turn off the petcock when you park it for long periods, try that and see if it makes a difference.
boney is offline   Reply With Quote
Old 01-20-2008, 08:30 AM   #15
idahoskiguy
Oddometer: 1,134
With the new information you provided, it sounds like you need to start with the basics. Air, fuel and spark.
Is the air cleaner clogged?
Do you have spark?
Fuel - too little or too much or contaminated with water? You are turning the petcock off - right? Leaving it on WILL flood the engine.
Valves adjusted properly?
The LC4 is a simple engine, so start by taking to factory spec for all the systems and your problem will be solved.
The devil is in the details
Times are GMT -7.   It's 03:41 PM.
