Old 04-26-2009, 04:52 PM   #226
simonpig
packin' heat
simonpig's Avatar
Oddometer: 1,118
Question: when you undo the quick release to T-line of the main tank, should the fuel be able to drain just by gravity if the petcock is open the auxillary tank. Mine doesn't. Thought gravity would take care the fuel clearing... I didn't remove the male part of the quick release... does this matter.
My aux tank has developed a leak around the petcock, and I was trying drain the tank. Had to resort to the siphon method.
Took out the petcock to see if the o-ring was kinked up. Made sure it wasn't, bolted it back on, tight and put a little gas to see what happens. Its still leaks a little.
Do I need another 0-ring? or is the petcock busted?
simonpig is offline   Reply With Quote
Old 04-29-2009, 09:35 PM   #227
neduro OP
Addict
neduro's Avatar
Oddometer: 12,022
Answered your email!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 05-04-2009, 06:20 PM   #228
Rideimal
Oddometer: 83
Are both the 2-1 and the aux tank compatible with the Caribou Cases luggage system?
Rideimal is offline   Reply With Quote
Old 05-04-2009, 06:57 PM   #229
stickfigure
Fiendish Fluoridator
stickfigure's Avatar
Oddometer: 523
I can verify that they are compatible with Caribou's ALS mounting system on H-B racks, although the tank is a tight fit under the rack. I'm using the Pelican 1440 cases.
My understanding is that the aux tank will not fit with Caribou's in-house rack, though.
Jeff
San Francisco to Panama and back... eventually?
How I Nearly Killed My Friends In Baja
stickfigure is offline   Reply With Quote
Old 05-04-2009, 10:16 PM   #230
Rideimal
Oddometer: 83
(damn) That's what I'm wondering about, the racks made by Caribou. Can I get a confirmation that they won't work? Anyone with first-hand experience?
Old 05-05-2009, 05:49 PM   #231
neduro OP
Addict
neduro's Avatar
Oddometer: 12,022
Believe you have to do some minor (if anything can be called that) repositioning of things. I do have customers using that combo, a welder was involved though so it's not inconsequential.
Old 05-05-2009, 06:07 PM   #232
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,747
You should have been a lawyer.
unaweep is online now   Reply With Quote
Old 05-05-2009, 08:17 PM   #233
AntWare
Lost In Translation
AntWare's Avatar
Oddometer: 16,483
Yeah, but if you removed his spine he'd suck at riding
s'up Jim
Choose Life. Choose a job. Choose a career. Choose a family.
Choose a fucking big television.
Choose sitting on that couch watching mind-numbing, spirit-crushing game shows,
stuffing fucking junk food into your mouth.
Choose rotting away at the end of it all, pishing your last in a miserable home,
nothing more than an embarrasment to the selfish, fucked up brats you spawned to replace yourself.
Choose your future. Choose life.
I chose not to choose life, I chose something else instead.
AntWare is offline   Reply With Quote
Old 05-05-2009, 08:22 PM   #234
Rideimal
Oddometer: 83
so just to clarify - is it just the tank that interferes with the caribou rack, or both the tank and the 2-1?
Old 05-06-2009, 04:38 AM   #235
neduro OP
Addict
neduro's Avatar
Oddometer: 12,022
Just the tank, sorta the leading edge where the Caribou case rack goes in before the plastic sidepanel, if I understand correctly.
Jim- I obviously missed my calling.
Old 07-12-2009, 01:21 AM   #236
sidestand
bristol, uk.
sidestand's Avatar
Oddometer: 273
Can you leave the petcock open on the aux tank with all three tanks full ?
I have left the petcock shut until the reserve light came on, then opened it until now but the fuel line from the aux tank does have a one way valve in place to stop any blow back from the main tanks.
Is anyone done/ trying this.?
sidestand is offline   Reply With Quote
Old 07-12-2009, 11:15 AM   #237
stickfigure
Oddometer: 523
Yep, works just fine. I spent two weeks in Baja with the petcock open and routinely filling all three tanks (and I still rolled into gas stations on fumes).
I just got back from Alaska, and this time kept the petcock closed and used the tank as a reserve - but with some problems. My petcock failed, and slowly leaked the contents of the tank into the main. I didn't discover this until I actually needed it - leaving me stranded So be careful, it's a good idea to check the tank contents now and then if you think you're going to need it.
I really wish the tank was white/clear.
Old 07-13-2009, 04:18 AM   #238
sidestand
bristol, uk.
sidestand's Avatar
Oddometer: 273
I would perfer to leave the petcock open all the time, so this is good news, as for the petcock failing, thats a kick in the behind for just when you need it the most. Thanks for the info.
Old 07-13-2009, 01:09 PM   #239
eral
eral's Avatar
Oddometer: 45
Question ADVTank and Givi rack?
Hi,
I have a Givi rack for both side and top cases on a 07 990 adv. Anyone knows if the auxiliary tank can fit in there? Is there a technical drawing with dimensions anywhere? Maybe I could check myself.
Thanks,
Eric
eral is offline   Reply With Quote
Old 07-13-2009, 10:50 PM   #240
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,505
Originally Posted by eral
Hi,
Thanks,
Eric
Ned's outta town ; I'll try to help; since the rack clears the stock exhaust with room to spare and the ADVTANK doesn't interfere with the bodywork, i'd be willing to bet there won't be any issues.
See Ned's pics above for visual reference. (sorry, that's the best I can do)
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Times are GMT -7.   It's 08:23 AM.
