Old 01-21-2008, 07:41 AM   #1
adam_c_eckhardt OP
done with Chemistry!
adam_c_eckhardt's Avatar
Oddometer: 5,270
Outdoor faucet heater?
As the temperature is below zero right now, I worry about my outside faucet freezing.
I was wondering if anybody out there knows of anything made to keep it warm? I was thinking something like a small heating element that can wrap around the thing a few times- just to keep it relatively warm. Do they much such a thing? If not, could I fabriate one? I've googled for a while, and can't come up with anything.
Any advice would be appreciated, and no, I'm not moving my house to the south. Thanks!
adam_c_eckhardt is offline   Reply With Quote
Old 01-21-2008, 07:45 AM   #2
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,271
Hardware stores have styrofoam covers that are made to clamp and completely cover outside faucets like a clamshell insulator. Really cheap, usually under 10 bucks.
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Old 01-21-2008, 07:47 AM   #3
adam_c_eckhardt OP
Oddometer: 5,270
I've already got one of those- I just worry that if it sits at -10 for long enough, that the cover will do no good. Thanks, though!
Old 01-21-2008, 07:58 AM   #4
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,271
Ok then, next step up is insulated electrical heater tape that you need to plug into 115V power. This stuff look like a long rubber belt with an AC plug at the end, and it is mostly sold at usually plumbers harware stores...of ourse you'll need AC power outlet near by. Cost is about $25. Google it: "elctical heat tape".
2003 KX250 - plated
AtomicGeo Videos
Old 01-21-2008, 08:22 AM   #5
adam_c_eckhardt OP
Oddometer: 5,270
EXACTLY what I was looking for!!!! THANKS!
Old 01-21-2008, 09:50 AM   #6
EchoCharlie
Oddometer: 25
You should check to see if it's a frost free faucet.
Alot of places have outdoor fixtures that actually cut the water off far enough into the soil (or wall) that the water left in the pipe will not freeze.
This can explain it better than I.
http://www.easy2diy.com/cm/easy/diy_...ge_id=35720531
EchoCharlie is offline   Reply With Quote
Old 01-21-2008, 01:42 PM   #7
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,662
Yeah, I'd recommend a frost free faucet. Easy to install (if you can do simple plumbing) and cheap.
I installed them in an old house I remodeled in Michigan and they worked quite well.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 01-21-2008, 02:12 PM   #8
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,032
Works great but be sure you install it with a slight downhill angle. If it's level or worse yet slightly uphill, water won't drain from the pipe and it will freeze in the pipe resulting in a leak as soon as you turn on the faucet. Don't ask how I know this .
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 01-21-2008, 03:38 PM   #9
Beemer Pat
Oddometer: 2,722
Do you have a shutoff valve to the faucet??? If you do shut the water off and open it. If you don’t install a ball valve before the faucet and your set. I lived in MN for 12 years and did this in both homes I owned.
Beemer Pat is offline   Reply With Quote
Old 01-22-2008, 05:46 AM   #10
Mtncrzr
Just Kidding, not really
Mtncrzr's Avatar
Oddometer: 1,213
I just had to install a shut off valve after my front faucet froze for the second year in a row...
It was one of the 10 inch long ones that shuts off the water inside the house too... I guess it wasn't long enough. Now, no worries.
I'll be the one on the horizontal silver 640 KTM Adventure.
Mtncrzr is offline   Reply With Quote
Old 01-22-2008, 03:36 PM   #11
adam_c_eckhardt OP
Oddometer: 5,270
I found that it IS a frost free type, plus, I added a bit of heat to it. I've lived in cold climates all my life, but now that I own the place and pay the mortgage, I can't sleep at night when it gets down to -20... Now I feel better. Thanks for the great advice!
Old 01-22-2008, 04:31 PM   #12
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,271
I've had frost free faucets with sill cocks as much as 1 ft, that will still fail if you do nothing. This happens in cases where the faucet is put at an outer corner wall, in which case nothing is gained by using a frost free faucet.
2003 KX250 - plated
AtomicGeo Videos
Times are GMT -7.   It's 05:41 AM.
