Old 02-15-2014, 06:24 PM   #1
ritetwist OP
ritetwist's Avatar
Oddometer: 178
'85 r80 g/s
I am picking up a new to me 1985 R 80 G/S Paris Dakar tomorrow.Pretty much original.
I have only seen it parked between other bikes.Did not hear it run yet.
Bought on sellers word, who I trust.
93,300 kms.( 58,000 miles)
Owner says it WAS a Gaston signed tank, but it wore off.
Any way of confirming this by the SN ?
Thanks guys.
Yeah,I know: Pics in a couple of days.
Afraid to sleep for fear of missing something.
ritetwist is offline   Reply With Quote
Old 02-15-2014, 06:30 PM   #2
_cy_
Oddometer: 6,370
congrats!
Old 02-15-2014, 08:14 PM   #3
Puddle
Oddometer: 128
I don't think you can determine if the signature was present using the Serial Number. The tank was a dealer option add. Without the invoice I would look carefully at the tank, if its still white, to see if the shadow of the signature is there. Otherwise enjoy it. The PD tank is great and if in good shape it is rare.
Puddle is offline   Reply With Quote
Old 02-16-2014, 09:42 AM   #4
akabeton
akabeton's Avatar
Oddometer: 427
Congratulations
A very nice addition to the stable.
Looking forward to pics.
1995 R100 GSPD
akabeton is offline   Reply With Quote
Old 02-16-2014, 05:47 PM   #5
akabeton
akabeton's Avatar
Oddometer: 427
Free room & board
I will feed and exercise her on the coast here till your winter is over.
1995 R100 GSPD
Old 02-16-2014, 07:32 PM   #6
ritetwist OP
ritetwist's Avatar
Oddometer: 178
Ok, got it in the shop.
Looks good (pics in 2 days)
Wiping it down and checking it over.What am I looking for? Tank and liner is dry,pristine.Bowls were drained.
No major oils drips,some oil and dirt around the push rod tubes.
Battery was taken out a long time ago.
Charging battery now to see if it is recoverable.
I grabbed a spare car battery to check the electrics.When I hook up the + and touch it to the heavy starter wire (key off)
I get major sparking.Hooking up to the other 2 + wires, all lights and all dash lights appear functional.
The signals do not flash, that is no biggie.
It does act like there is a major short in the starter area.
Will get the tank and starter cover off tomorrow and do some tracing.
Hesitate to think that the PO knew about this, but who knows?
Anything else I should be looking at?
Thanks.
Old 02-16-2014, 08:08 PM   #7
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 820
Eek
Thanks.
Got a digital multi-meter (DMM)? If not, go buy one. Doesn't have to be an expensive or fancy one either. I just bought a decent, rugged one for $25.
With the battery out/disconnected and with he switch ignition off, there should be no current draw on the battery. A measurement between the positive battery cable and the engine should read infinite Ohms. If is is near 0 Ohms, you have a big time short. But just start following the cable away from the battery and disconnecting everything as you go. You will find the short.
Do you hear the starter try to spin when you connect the battery? Maybe just the starter relay is welded closed.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is online now   Reply With Quote
Old 02-16-2014, 08:52 PM   #8
Left Testicle
Oddometer: 224
still can get the gaston stickers. email bruce@marshall.co.nz nothing to fo with me
Left Testicle is offline   Reply With Quote
Old 02-16-2014, 09:17 PM   #9
ritetwist OP
ritetwist's Avatar
Oddometer: 178
Thanks Moto,I have an inexpensive analog tester.My expensive digitals are all broke.
I was thinking of the testing as you suggested.
Electrics are not my strong point, infrequent use is my reason.
The starter does not turn, or try to.Just a big spark when I touch the main wire to the battery cable.
Tear down tomorrow.
I cannot open the link Left T.
ritetwist screwed with this post 02-16-2014 at 09:18 PM Reason: add on.
Old 02-17-2014, 02:22 PM   #10
ritetwist OP
ritetwist's Avatar
Oddometer: 178
Problem solved !
Dug around a bit last night and this morning,finally called the PO,he was concerned that the bike was giving me trouble.
Then he asked me if the heated grips were on.They were after market and bypassed the ignition switch.Direct hookup to the battery.I had pondered on that switch on the handlebar, but did not follow it up.He said they were quite effective,big current draw, therefore the light show when I touched the lead.
It was on, all is well.
Not running yet, but the engine does turn over.
Thanks for the support and help.
Pics tomorrow.
Old 02-17-2014, 07:52 PM   #11
Spark Plug
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
Congrats!!
Pics are necessary and be sure to post the vin digits in here. http://advrider.com/forums/showthread.php?t=387620
I'm the current care taker of a '85 also.
Nothing to see here.
Spark Plug is offline   Reply With Quote
Old 02-17-2014, 08:34 PM   #12
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,814
Drop the oil pan, and clean it, plus inspect the oil pickup tube, remove and clean. It's easy to do, and would get rid of any sludge which might have settled since the bike is low miles and if oil has sat in there to long in a questionable environment.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-18-2014, 03:47 PM   #13
ritetwist OP
ritetwist's Avatar
Oddometer: 178
Pics, as promised:
[IMG][/IMG]
[IMG][/IMG]
Old 02-18-2014, 07:26 PM   #14
Spark Plug
Low on compression
Spark Plug's Avatar
Oddometer: 1,343
Very nice!
I dig the camo LS in the background.
Old 02-18-2014, 07:31 PM   #15
Motopsychoman
Not a total poseur
Oddometer: 820
Eek
Nice shop! I have to work in my low overhead basement if I want to work indoors.
Oh, nice bike too.
Times are GMT -7.   It's 08:58 PM.
