Old 11-22-2011, 08:57 PM   #16
squish
Out of the office.
Oddometer: 6,155
There are a ton of aftermarket front fenders the newer fenders are molded in such a way that most of them do not need braces.
I have Acerbies Black Honda CRF450R front fender for my GS, that I've yet to mount seems like it was 20 bucks or so.
On vacation for a spell
squish is offline   Reply With Quote
Old 11-22-2011, 10:58 PM   #17
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Originally Posted by worley_craig View Post
Airhead Wrangler, I'm digging your headlight setup. Can you tell me more about that. I was thinking about retro fitting my R100GS with a /7 headlight bucket, but didn't know what to do with the speedo and tach.
Baja Designs 8" race light. I really like mine.
The standard race light is a single filament or HID light - no high/ low function - but is adjustable on the fly unsing the knob on the top. Quick detach using pegs into receivers, and an e-clip at the base. The receivers jubliee clip to the fork legs. The receivers length is 15.5mm, compared to 15.0mm open fork leg space (between the triple clamps). Either put a 5mm spacer under the bottom bearing, or have slot machined in the receivers. Sounds complicated, but is fairly easy in practice
I've got a Boatman H4 conversion in mine so I could run a Hella insert with a standard H4 bulb, in order to meet NZ legal requirements, which requires a headlight that dips to the left. Some of the reasons I went with this light set up include that:
1. The (toughened glass) Hella insert is cheap to replace if I catch a random stone. Compare that to the stock bosch item;
2. It has a pilot slot, so I can run a 20w halogen 'pilot light' - which I use as a day running light, rather than the headlight
3. The headlight bucket gives better protection for the assembly that the comparable Trailtech competitor
4. The bucket has given me room to hide some electrics, & is big enough to allow heat to dissipate from the reflector (running a 90/130w)
5. The design seemed more rbust than the stock /7 light. Crash with those & you are up for at least a chrome bezel
6. Cost. Whilst the race light seems initially expensive, stock /7 parts would be dearer over here, if available
7. Looks to fit well with the HPN tank IMHO
We both have vapour speedometers, but with different mount solutions.
Sorry Airhead Wrangler if I stole your thunder...
I've pulled my photos of my 48mm USD fork conversion in order to keep from offending Beemeboff's (senior) sensibilities..
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 11-23-2011 at 03:05 AM Reason: Expanded explanation
Box'a'bits is offline   Reply With Quote
Old 11-23-2011, 02:24 PM   #18
worley_craig
Oddometer: 6
Thanks for the info guys! Sweet setup.
worley_craig is offline   Reply With Quote
Old 02-19-2014, 07:36 PM   #19
cgoodwin
Oddometer: 96
Very similar light for $299
http://gnarlyparts.ca/product_info.p...ucts_id=106195
cgoodwin is offline   Reply With Quote
Old 02-19-2014, 07:44 PM   #20
MotorcycleWriter
MotorcycleWriter's Avatar
Oddometer: 1,053
Hey, Airhead Wrangler, what can you say about that headlight and speedo? I'm looking to replace mine as well and am in ask-a-bunch-of-dumb-questions mode.
IGNORE: Someone beat me to that question!
MotorcycleWriter is offline   Reply With Quote
Old 02-19-2014, 08:22 PM   #21
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
Which one?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-20-2014, 06:17 AM   #22
MotorcycleWriter
Oddometer: 1,053
Either one!
Old 02-20-2014, 06:33 AM   #23
jian var
Oddometer: 39
Ufo vintage series!
jian var is offline   Reply With Quote
Old 02-20-2014, 06:37 AM   #24
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
What's wrong with a standard high mudguard?
Rob Farmer is offline   Reply With Quote
Old 02-20-2014, 06:53 AM   #25
MotorcycleWriter
Oddometer: 1,053
Here's another source for G/S and GS parts: http://www.boxercafe.com/r80-gsparts.htm
Times are GMT -7.   It's 12:22 AM.
