Old 02-23-2008, 10:50 AM   #46
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,861
So the CRF450x bolt on pin will fit the GSPD?
My Kung Fu is better than yours
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch screwed with this post 02-23-2008 at 10:55 AM
Cigars&Scotch is offline   Reply With Quote
Old 02-23-2008, 10:56 AM   #47
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
Originally Posted by GoodTill
So the CRF450F bolt on pin will fit the GSPD?
I have much to learn, grandfather
I wonder if you could call them with a neck size? I bet its more a question of how long the arm is rather than how big the collar is.
Unintentional psychokinesis.
Stagehand screwed with this post 02-23-2008 at 04:47 PM
Stagehand is offline   Reply With Quote
Old 02-23-2008, 08:29 PM   #48
HPMGuy OP
Oddometer: 264
Scotts does not make a bolt on ring specifically for this application.
To clarify exactly what is needed for the Scotts installation:
1)Scotts damper with a 40mm reverse mounted stepped arm.
2)BRP Sub Mount 10614P3
3)I now have the bolt on towers available, or Scotts Standard Length Weld on Tower (VERY tight fit between tank and tower)
Hope this helps cure some of the confusion.
I understand the fact that a welded on e would be stiffer, just dont want to weld anything to the frame.
Do you know which one is the bolt on application? I did not see anything listed on the web site.
HPMGuy screwed with this post 07-16-2008 at 10:43 AM
HPMGuy is offline   Reply With Quote
Old 02-28-2008, 11:06 AM   #49
OldTiredness
Oddometer: 35
Sign me up for one when you get the g/s one together.... I would prefer having the stock lugs/recess so I could run the blinkers/headlight in the stock configuration. Being able to use a damper would be less important...
Originally Posted by HPMGuy
Hello Solo,
Congratulations on the new bike!
No I have not come by a stock clamp to duplicate. Carl (here on AdvRider) has a spare, and should be sending it my way soon. I would appreciate some input from G/S riders as to what would be necessary to incorporate into the clamp. Some pictures of the clamp on the bike, with the accessories bolted to it would be great!
OldTiredness is offline   Reply With Quote
Old 02-28-2008, 04:52 PM   #50
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,113
I would not want a copy of the stocker top triple (at least for mine), I just ordered a set of Acerbis handguards with integrated turn signals..... I would want the ability to run other handlebars (like HPNGuy's R100clamp) and perhaps a damper as well..
http://www.gnarlyparts.com/product_i...oducts_id=1405
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-04-2008, 08:16 PM   #51
ADVnut
Still Looking
ADVnut's Avatar
Oddometer: 177
Guy--
Any word on the bolt on tower for 2006 Kawasaki Kx250?
Scotts does not make a bolt on ring specifically for this application, but they do make one for a Kawasaki KX250 should be just about perfect. It is P/N: 60-65 (for 60mm stem tube, and 65mm rise). Look here for pics. I had intended to order this part, and install it on my bike, but they talked me into using the weld on tower for a more rigid mount. I will order one of these Monday, and make sure that it will work.
1)Scotts damper with a 40mm reverse mounted arm.
3A)Scotts Standard Length Weld on Tower or
3B)Possibly a Bolt on Tower for 2006 Kawisaki Kx250 (I will verify that it works this week).
ADVnut is offline   Reply With Quote
Old 03-05-2008, 07:56 AM   #52
HPMGuy OP
Oddometer: 264
I received the KX250 tower on Monday, and it will not work for this application. It was very close, but has a bend in the back where it has an interference problem with the Kawi frame, this makes it so it will not have enough bite on the BMW. (This is the only bolt on tower that Scotts makes for a 60mm stem tube.)
If there are enough people interested in a bolt on tower, I will machine up a batch of them. Reply here, PM or email me, and I will get a list going, when I get some confirmations, I will start machining. (An estimate on cost will be around $100-$120 each.)
Originally Posted by ADVnut
Guy--
Old 03-05-2008, 09:44 AM   #53
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,113
Hello Solo,
Guy,
Do you have the stock clamp in hand? Please let me know if you need picture of the stock clamp on a bike and I can shoot whatever you need!
Gage
R65LazaruS
Old 03-05-2008, 04:45 PM   #54
HPMGuy OP
Oddometer: 264
No I don't have a sample yet. Carl is awaiting it's arrival (he bought a spare), and as soon as he gets it he will forward it to me.
Pictures would be great! (Email at your convenience.)
Thanks,
Guy
Originally Posted by SOLO LOBO
Guy,
Gage
Old 03-05-2008, 04:50 PM   #55
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
I ready to pull the trigger on the GS clamps when they're done, Guy.
Standing by...
Old 03-05-2008, 05:27 PM   #56
HPMGuy OP
Oddometer: 264
Sorry for the wait, I should have them in my hands tomorrow, (of course I was promised delivery last Friday, and then Monday also.) Platers.........
They will ship out as soon as I receive them, thanks for your patience.
Standing by...
Old 03-05-2008, 05:33 PM   #57
HPMGuy OP
Oddometer: 264
A few people requested a closeup of the weld on tower, so here it is. I ground a little bit of material off of the "wings" to make them line up with the frame, cut approx. .440" off of the top of the tower, positioned it with some clamps/zip ties and welded away. Took me all of about 15 minutes, start to finish. (The black stuff is some anti-rust paint I brushed on.)
Old 03-07-2008, 11:08 AM   #58
HPMGuy OP
Oddometer: 264
The second run just got back from anodizing, and I remembered to take some pictures before I shipped them out this time.
New triple with the BRP SUB mount for a Honda CRF450X, PN 10614P3.
This triple clamp will accept any type of bar mounts designed for the Honda CRF450X, with either 7/8 or 1 1/8 bars, but if you want to install a Scotts damper, you will have to use the SUB mount from BRP or Scotts (same P/N the only difference is if you buy it from Scotts, it will be grey instead of black).
Compared to original GS triple.
Side comparison:
Top comparison:
Old 03-07-2008, 05:40 PM   #59
Cigars&Scotch
My eyes are up here
Oddometer: 1,861
Guy they look great. You stated that you mounted a Pro Taper ATV high bars on the BRP mount.
2 questions
Do the bars hit the fairing at lock
What did you do for the heated grips and hand guards
Mike
77 BMW R90S Huh ?
Old 03-08-2008, 05:51 AM   #60
MoMan
PigPen
MoMan's Avatar
Oddometer: 666
Can't tell because of the camera angle but, is the height/depth at the end of each side (where the fork actually clamps into) the same?
Side comparison:
It could be that the purpose of your life is only to serve as a warning to others.
MoMan is offline   Reply With Quote
Times are GMT -7.   It's 03:47 AM.
