Old 07-15-2008, 11:02 AM   #106
HPMGuy OP
Oddometer: 264
Glad to hear the setup went together well! Looking forward to seeing some pics.....
I will be making another run of the rear racks in the near future....I will keep you posted.
Originally Posted by Cigars&Scotch
I just intalles Guys setup on my 90 PD. What a sweet setup!!
I used the Pro Taper Contour ATV High bars (sorry Jason) and they fit great. You do have to file the ends of the bar to get the BMW switch assemblies on. Nothing that a Dremel tool can't handle.
I used the Aerostich heated grip assembly with BMW grips. I just cut the existing wires close to the connector and soldered them up. The stock and the Stich uses a 2 wire setup, so it's prettu easy. I used Kapton tape under the left bar to insulated it a little and also used some of the tape to hold the Stich elements on the bars. Then some of the old lady's hair spray and slide the grips on.
Now I need a cross bar to hold my GPS. Any know where I can get a cross bar for a fat bar?
Picts tmr.
Great job Guy!!
No make another batch of rear trays!!! Please
HPMGuy is offline   Reply With Quote
Old 07-15-2008, 06:16 PM   #107
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,861
Well i went to install the Scotts tda and found out I have the wrong arm. I have a straight arm and I guess I need a stepped on.
Now that I looked at ADVnut setup, I see the stepped arm
Order went in to BRP for stepped arm.
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch is offline   Reply With Quote
Old 07-16-2008, 09:39 AM   #108
HPMGuy OP
Oddometer: 264
You might not need to buy a new arm, you can lower the plastic collar on the tower pin to bring the pin up level with the top of the straight arm. If it won't extend enough, you could buy the next taller pin from Scotts (about $10), this will be a bit cheaper.....and you won't have to buy the puller to replace the arm on the damper.
Old 07-16-2008, 10:15 AM   #109
Cigars&Scotch
My eyes are up here
Oddometer: 1,861
Puller, we don't need no stinking puller.
We have the 41A adapting tool
Mike
77 BMW R90S Huh ?
Old 07-16-2008, 10:55 AM   #110
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,112
how about something like this instead for $32?
http://www.motorcycle-superstore.com...ter-Mount.aspx
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 07-18-2008, 05:56 AM   #111
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,205
Got the first bits, they look great.
remainder will be here soon... Should be able to install everything next weekend.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 08-10-2008, 06:21 AM   #112
Cigars&Scotch
My eyes are up here
Oddometer: 1,861
Thought i put up some photos of the finished product. It took about 2 hrs to do. Biggest issue was taking all the stuuf off the bars and getting the new bars ready.
Thanks Guy
Mike
77 BMW R90S Huh ?
Old 08-17-2008, 04:07 PM   #113
ADVnut
Still Looking
ADVnut's Avatar
Oddometer: 177
Thanks Guy
Where'd ya get that crossbar?
ADVnut is offline   Reply With Quote
Old 08-17-2008, 04:38 PM   #114
Cigars&Scotch
My eyes are up here
Oddometer: 1,861
Touratech x bar. It is the longest of the 3 they sell.
Mike
77 BMW R90S Huh ?
Old 01-21-2010, 10:56 AM   #115
rainmaker8
rainmaker8's Avatar
Oddometer: 111
remote adjuster possible?
What a great thread! I cannot wait to try this...
Not to get picky, but has anybody considered a remote adjuster?
compare to a competitor product GPR:
http://gprstabilizer.com/prod_v3
rainmaker8 is offline   Reply With Quote
Old 09-29-2011, 12:46 AM   #116
ontic
Oddometer: 1,070
Bump,
Bringing up an old thread,
I've got a few questions for you guys running these scotts dampers on airheads.
I am in the market for a (probably cheap second hand) scotts damper for my 80G/S which will soon be wearing its WP50 extreme front end with Rdubb triples made by Guy.
Who has gone with the road or offroad versions (ie damping both ways or only away from center)?
From my reading I found some talk that the road version is better for heavy bikes. There were a few other reasons as well, and it just makes sense to me, but I am leaning towards the road version.
However, who's got what and how has it worked out?
Also,
I need to figure out which tower attachment and what stepped arm thingimy I need... I am planning on getting a submount set of bosses (probably BRP) for the Rdubb/Guy clamp.
thanks for any advice, and/or links to other threads where scotts dampers on airheads (particularly G/S or GS) is discussed.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 09-30-2011, 06:47 PM   #117
ontic
Oddometer: 1,070
and another bump,
if this one does no good I suppose I'll start a thread,
anyone- G/S or GS or just a dirty airhead with a scotts stabilizer want to share some experience?
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 09-30-2011, 07:07 PM   #118
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,205
Originally Posted by ontic View Post
and another bump,
scotts= awesome. i love it on my GS. When I'm really pushing it, the bike sometimes wants to turn in, on corners, especially loose ones. A couple of clicks up and I can throttle through instead of fighting it. It reduces fatigue so you can ride farther, faster. Slimy sections and puddles are not longer puckering, it just tractors through. Really brilliant, imho.
I could go on and on, you need more?
Old 09-30-2011, 11:23 PM   #119
ontic
Oddometer: 1,070
More More
Thanks Stagehand I was hoping you would turn up
Have you got the road or the off-road version (damping both ways or only damping away from center). What are your thoughts on the choice between the two.
And aside from = awesome in the dirt, do you notice any effects on the rubber cow on the road?
Due to reading somewhere that the road version is probably better for heavy bikes (for road and offroad) and just trying to imagine a damper working only one way, I'm leaning towards the road version.
If I get persuaded towards the off-road version I'll be annoyed because I just missed a cheap one
Also,
What have you used for the bolt on tower thing? Is this a part that Guy sells?
Thanks.
1974 R90/6
1981 R80G/S
1994 XLR250R
Old 12-17-2012, 02:39 PM   #120
hgervat1
Oddometer: 1
Handle bar mounts GS1200
Would you happen to have a set of stock handle bar upper and lower mount for a 1200 GS ?
hgervat1 is offline   Reply With Quote
Times are GMT -7.   It's 06:11 AM.
