Old 01-31-2008, 11:22 AM   #1
rednose OP
ReDnOsE
Oddometer: 63
Eh? R1200GS side effects on changing handlebar setup
Hi,
it is almost four times I unscrew/rescrew the torx of the handlebars on the triplecamp of my R1200GS. I noticed that
1) every time I unscrew I find some "aluminium powder" around the torx
2) on screwing them, you may "feel" they are pretty soft
My opinion is they are very soft, and if you put too much strength, you may broken them. For those of you needing to change the setup of the handlbar for on-road / off-road riding like me, how do you proceed? I mean, you buy a new set of torx from BMW and replace them from time to time, you replace them with steel bolt, or simply it is not a problem?? Please suggestions welcome!!
Ciao
rednose is offline   Reply With Quote
Old 01-31-2008, 11:39 AM   #2
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,532
Antiseize and a torque wrench. I also put a little antiseize around the bar where it contacts the clamp. It's also very important to go around and torque down the bolts a few clicks in a diagonal fashion.
In the field you may not have the torque wrench or the external torx bit handy, so some people replace the bolts with conventional allen bolts of the correct hardness. Then you can use a small allen wrench to quickly adjust the angle with less chance of overtorquing the bolts.
TaterHarry is offline   Reply With Quote
Old 01-31-2008, 12:07 PM   #3
Michaelrm69
Michaelrm69's Avatar
Oddometer: 94
I believe that Touratech makes a quick release style pin/screw to replace your torx bits with (at least two of them). I've only seen it on their website and can not vouch for their usefullness...
Michaelrm69 is offline   Reply With Quote
Old 01-31-2008, 12:12 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,586
I'm not so sure antiseize is a good idea. The antiseize will allow more actual torque before tightening down, and may actually cause an issue. IIRC BMW specs dry.
I have had mine off 4-5 times, and know the powder he is referring to. There is a slight corrosion there that manifests itself as a whiteish powder. It wont hurt anything, and the threads should be fine. I clean off the bolt, and blow out the powder, and reinstall them.
That is what I did, and my shifter bolt, to make it so I didn't have to carry extra sockets.
Jim
JimVonBaden is online now   Reply With Quote
Old 01-31-2008, 12:21 PM   #5
TaterHarry
Redneck Emeritus
TaterHarry's Avatar
Oddometer: 2,532
Huh. On my '07 Adventure I found dabs of antiseize on the tips of the bolts when I put my risers on. The bike was practically new so there was no corrosion to speak of I think I would be more prone to use the antiseize and be careful with the torque if you're going to be adjusting frequently. JMO.
Old 01-31-2008, 12:22 PM   #6
fooey
Live Bullet
Oddometer: 130
Jim
+1 what JB said and I would NEVER put anything between the handlebar and clamps, lube wise I mean, r12oogs info says 21nm (15ft lb) 1st front, then rear, gap at rear only.
Alfred: 06 gs12 happy trails to you!
fooey is offline   Reply With Quote
Old 01-31-2008, 01:13 PM   #7
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,861
this could be a galvanic reaction. I think these bolts a zinc and the clamp is aluminium....
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 01-31-2008, 03:26 PM   #8
Wallowa
Oddometer: 5,340
Laugh I Disagree...Use Anti-Seize...Here Is Why..
Placing two dissimilar metals in contact will generate galvanic current and ion exchange...the bolts on the clap for the handlebar may not hit the exact specification for torque if anti-seize is used...but that is not as critical as the galling of the metal when removing the bolts...the 'powder' is lost metal...use anti-seize save the metal; the torque on those bolts is not that critical....ARP and other manufacturers of high quality fasteners measure the correct torque by stretch of the bolt at specified torque but they also list 'lubed/wet' and 'dry' torque values...think about Loctite, wet torque..I know BMW doesn't recommend anything...but for example: spark plugs in aluminum head = anti-seize; valves in aluminum SCUBA tanks = breathing quality silicon grease [or you will tear/gall the threads each time you remove plugs or valves]....I have seen the damage to both without a coating to prevent galvanic exchange..
So it is your call...read Carrol Smith's books on race prep and fasteners, great information..
But then this is just my opinion...
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 01-31-2008, 03:46 PM   #9
H-Jay
Mo 2 C
H-Jay's Avatar
Oddometer: 401
A Wunderlich Alternative
I installed these quick release gadgets and 35mm risers on my 1200GSA. What a difference when you want to quickly get up on the pegs and not have to hunch over to reach those bars. It also solved the soft torx bolt problem.
Handlebar Quick-Adjust
Part number:8160109-111
Price: 39.95
H-Jay
2007 BMW R1200GSA
1968 Norton Fastback
1969 Triumph Bonnie
South America Blog
Patagonia Bound Ride Report
http://www.advrider.com/forums/showthread.php?t=420453
Alaska Ride Report http://www.advrider.com/forums/showthread.php?t=250239
H-Jay screwed with this post 01-31-2008 at 08:24 PM
H-Jay is offline   Reply With Quote
Old 01-31-2008, 03:52 PM   #10
Archangel
GS Heaven
Archangel's Avatar
Oddometer: 140
Originally Posted by H-Jay
I installed these quick release gadgets and 35mm risers on my 1200GSA. What a difference when you want to quickly get up on the pegs and not have to hunch over to reach those bars. It also solved the soft torq bolt problem.
Price: 39.95
So they do work then? I was curious about how they performed but have been too lazy to search for answer as of yet!!
Thanks for the update H-Jay!
______________________________________________
05 BMW R1200GS
86 Honda XR 100 (for mini racing!)
Archangel is offline   Reply With Quote
Old 02-01-2008, 12:14 AM   #11
rednose OP
ReDnOsE
Oddometer: 63
doubt
Hi,
I was aware of the wunderlich farkle for the handlebar (always deeply looking at catalogs ), but I'm not sure they are "safe" to mount. I mean, not only the torx, but even the holes on the triple clamp (sorry I'm not english, I don't know the mechanical term for the place where you screw something; let's avoid .... sex terms ) they look to me quite "soft". I'm worried that after some operations, the wunderlich ... screw up everything. Am I wrong?
Ciao!
Old 02-01-2008, 04:11 AM   #12
fooey
Live Bullet
Oddometer: 130
Originally Posted by rednose
Hi,
Ciao!
Looks like the wunderlich parts are fine, the clamping part is still just a bolt. I think the threads on the triple clamp are weak. Repeated tightening and loosening will take its toll. The question is how many cycles until the threads go away? of course that depends on how tight each time, technique, dry, not dry, clean,dirty etc. So if your going to loosen and tighten many many times eventually you will probably need a triple clamp. Maybe they will last the life of the bike, maybe not. It's a chance you take if you want to adjust frequently. Just MY opinion.
Times are GMT -7.   It's 12:19 PM.
