Old 02-02-2008, 09:22 AM   #1
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
TT350 Not XT350
Anyone have a TT350? Wanting to make it street legal and better for longer distances. Baja Designs and IMS do not make a larger tank. Does anyone know who does. This is a total loss / magneto ignition (no key and kick start only) so how would I add turn signals and brake light? Would I need a higher out stator? Anyone know who specializes in old 1980's enduro bikes close to Illinois?
Anyway, I've searched this forum and found tons of XT350 threads. Should I just use XT350 stuff (stator, turn signals and brake light switch)?
Any and ALL advice appreciated.
Tim
xltrider is offline   Reply With Quote
Old 02-02-2008, 10:44 AM   #2
BikePilot
BikePilot's Avatar
Oddometer: 11,251
Its not a total loss system (total loss means it has no charging system and the ignition would be powered by a battery).
Otherwise, I'm afraid I'm not much help.
best of luck
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 02-02-2008, 12:08 PM   #3
switchback
Eatin' Dirt Since 1982
switchback's Avatar
Oddometer: 1,485
I had a TT350 and made it street legal in a very easy state to do so. The first question I would ask is what are the min. requirements in your state?
f you want a kit call Trick Dual Sport for a version that will draw the minimum wattage. http://www.trickdualsport.com/ A kit would be similar to one for any XR.
You my be able to add a stator from an XT for more juice.
I would swap out the tail light with an LED 1157 bulb first.
The existing taillight has a third wire for a brake light that I would wire to the front brake using a hydraulic switch.
Swap the headlight for a DOT 55/60W low/high beam (if not using a kit).
If you do require blinkers get some LED versions.
TT350s are one of my favorite bikes of all time!
David
Wind is strong and cold
Rain blurs the winding road ahead
I live on two wheels
switchback is offline   Reply With Quote
Old 02-02-2008, 01:17 PM   #4
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,716
Clarke makes a big tank
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is online now   Reply With Quote
Old 02-02-2008, 01:29 PM   #5
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Thanks. All 3 of you guys rule.
Tim
Old 02-02-2008, 08:16 PM   #6
TTKlaus
Oddometer: 329
I have a TT350, wouldn't get rid of it for nothing. It's easy to make streetlegal. You would not gain enough by using the XT350 stator and flywheel. The stock stator is enough to power the stock 55W headlight and the tailight. The cheap way to do it would be to get a halogen headlight and run a 35W H4 in it. Get a rectifier put it in line and change the taillight to an LED, get LED blinkers and your home free, don't forget the horn. I used to run mine using the cheap way, but now I have a Universal Baja Designs system on it, Baja Designs also rewired my stator for higher output. Works great. I don't think Clarke has a bigger tank, I believe their's is stock size 2.6gallon. But the stock tank with a properly running bike should get you anywhere from 80 to 120 miles. I've gone 140 miles before on a tank (would not recommend it, it was scary out in the middle of nowhere and no gas station in site).
TTKlaus
Do it in the Dirt!
1974 DT250, 1980 TT500, 1986 TT350, 1993 KLX650C, 03 KTM450EXC
TTKlaus is offline   Reply With Quote
Old 02-04-2008, 06:50 PM   #7
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Yeah I went to the Clarke website and they make an over sized for the XT models. Stock capacity on the TT tanks. I'm going to go the TTKlaus route with the lighting. Man this is going to be one fun bike.
xltrider
Old 03-01-2008, 01:19 AM   #8
kta
kta's Avatar
Oddometer: 582
Hey Gang!
I just joined the TT350 following. I've owned LOTS of bikes, but this one feels real solid to me. I bought it on a whim. I definitely dont' need it but only paid $100, so who cares.
As you can see I am missing the kickstarter, everything else is in very good shape - obviously it has a bad rattle can job, but that's fixable.
I have recently been thinking that it would make a killer dual sport. Reading a few threads here I think has made me decide to keep it and fix it up.
Anyone happen to have a spare kickstarter shaft?
Ongoing Ride Report: ..... I'll just skip to the Baja part.
Motorcycle Tours in Guatemala
kta is offline   Reply With Quote
Old 03-07-2008, 06:03 PM   #9
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Thumb
Last weekend (Sunday 03/02/08) I made a BIG mess of mine. In a good way, off roading for an hour and a half. Cold, wet, shivering and smiling. Mine has a Supertrapp w/ jet kit. No other engine performance mods needed. It's quite fast enough. Suspension works good too! I'm really going to enjot this bike.
Tim
Old 03-07-2008, 06:14 PM   #10
Hair
Outside the boxer
Oddometer: 13,883
Klaus knows his TT shit. He easily kicks our modern bike asses. That is when he is not busy adjusting his points.
With my feet on the ground, my nose in the air
I am riding just fast enough to feel the wind in my Hair.
Hair is offline   Reply With Quote
Old 09-29-2008, 08:51 PM   #11
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Haven't posted in a while. Got a Baja Design dual sport kit and am currently trying to title it. Using Western Surety Company as my bonding company and I still need dual sport legal tires. I'll post with any updates in the next couple of weeks for those wanting to title a TT350.
Tim
Old 09-29-2008, 08:51 PM   #12
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Tim
Old 06-01-2009, 03:28 AM   #13
bigboy87
Oddometer: 13
Just Joined
Hey guys I just joined this site and I have a 87 tt350 and a 89 tt350 parts bike... I was just saying whats up
bigboy87 is offline   Reply With Quote
Old 06-24-2009, 06:14 PM   #14
76 bronco J
76 bronco J's Avatar
Oddometer: 17
..............speedometer...............
>>>>>> I've started dual sporting my 1986 TT350 & replaced the stock trip meter with a speedometer from a mid 70's DT250.......the speedo attaches to the stock cable & it was even at 30mph when tested with my friends 2005 XT225.......I imagine a speedo from any of the DT series with 21" front wheel would work & lots have the yamaha label on the gauge face for the "looks like it's suppose to be there look" which might help during inspection...... I got mine off ebay with shipping for only $16 & these old metal housing nippon seiki speedometers are built pretty durable .........
76 bronco J is offline   Reply With Quote
Old 02-22-2011, 08:23 AM   #15
xltrider OP
Seasoned Adventurer
xltrider's Avatar
Oddometer: 588
Finally located a oversized tank and skid plate. Now for the speedo. Thanks bronco J.
Times are GMT -7.   It's 07:09 AM.
