Old 05-17-2013, 02:26 AM   #511
hawaiidirtrider
Oddometer: 50
Talking Beta's are getting more popular ..
There are less Beta enduro bikes available on the used market.. The reputation is there now and it's not so obscure. I still love my 09 525 RS. At some time I'll upgrade but probably I'll get a 2 stroke 300 first.. love that 6 speed electric start 2 stroke 300!
hawaiidirtrider is offline   Reply With Quote
Old 05-17-2013, 05:16 AM   #512
rsteiger
Bob
rsteiger's Avatar
Oddometer: 209
Originally Posted by TNkayaker View Post
Yes, that is correct. headlight is AC. You can buy stator/rectifier kits to change it to all DC.
OK thanks! Did a quick search and found a kit. Not sure if I will do this yet but is is good information to have on hand.
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
rsteiger screwed with this post 05-17-2013 at 05:23 AM
rsteiger is offline   Reply With Quote
Old 05-18-2013, 05:57 PM   #513
McKay
McKay's Avatar
Oddometer: 911
Turn signal ac as well?
Jeff
McKay is offline   Reply With Quote
Old 05-18-2013, 06:08 PM   #514
redpillar
redpillar's Avatar
Oddometer: 875
Nope DC
redpillar is offline   Reply With Quote
Old 05-18-2013, 07:41 PM   #515
McKay
McKay's Avatar
Oddometer: 911
Originally Posted by atravlr View Post
How are the tank stickers holding up?
I didn't get any and really think the tank needs something.
Jeff
Old 05-18-2013, 07:41 PM   #516
McKay
McKay's Avatar
Oddometer: 911
Originally Posted by redpillar View Post
Nope DC
Jeff
Old 05-19-2013, 10:40 PM   #517
atravlr
atravlr's Avatar
Oddometer: 204
Question Tank decals
Actually at 85 mph+ they were starting to peel back. My friend suggested a spray on adhesive. I'll try that, if that does not work I will peel them off.
atravlr is offline   Reply With Quote
Old 05-20-2013, 04:07 AM   #518
rsteiger
Bob
rsteiger's Avatar
Oddometer: 209
If you find something let me know.
I had an aftermarket tank on my DR650 and put some small stickers on and after a bit they began to peel. When I dug into the problem I found out that most of the aftermarket tanks (IMS and Clarke) are permeable to gasoline fumes. Hence nothing will stay stuck on the plastic since the gas fumes are coming out behind the stickers/decals and attacking the adhesive forcing them off. While my small stickers stayed put, you could see the bubbles forming behind the stickers and in somes areas it was pushing the stickers off.
I saw an ad for one of the tank manufacturers once that stated their tanks are not permeable to fuel vapor and this would not happen on their tanks.
2012 WR250R
2010 Beta 520 RR
2009 DL650
2001 GasGas XC250
Old 05-20-2013, 06:35 AM   #519
ballisticexchris
ballisticexchris's Avatar
Oddometer: 910
Originally Posted by hawaiidirtrider View Post
There are less Beta enduro bikes available on the new market.
Not true! They are mass producing them in China now. I heard it on the internet.
Happy Trails
Chris
05 KTM300EXC,
2012 Beta 520RS PLATED!!
ballisticexchris is online now   Reply With Quote
Old 05-20-2013, 06:44 AM   #520
Alacrity
Semi Pro Bar Vaulter
Alacrity's Avatar
Oddometer: 468
Theres perforated graahics out there for this reason. Imagine you could perforate those if its much of a concern.
The greatest pleasure in life is doing what people say you can't. So far...its working. The bars low
Alacrity is offline   Reply With Quote
Old 05-20-2013, 08:26 AM   #521
McKay
McKay's Avatar
Oddometer: 911
How?
Jeff
Old 05-20-2013, 09:29 AM   #522
atravlr
atravlr's Avatar
Oddometer: 204
Decals 2
McKay, the decals are perforated. They have tiny razor blade like slits every 2 inches or so apart from each other. They have developed tiny air bubbles through out and I have tried to push the air out of some but they still reappear. To me it's no big deal, and I attribute it to the heat of my garage. I live in the desert, and my garage reaches 95 degrees. Like I said earlier on my last trip I had some high heat , cold rain and snow all within 4 hours. Then for the last 10 miles we were racing at close to 95 mph. That is when the front of the decal on the tank started to peel back. As of now it is stuck on very well and I cannot peel it back. I guess the next big ride will tell the truth if I will try the spray on adhesive or I will not need it. So try to hold off a little longer and I will get back to you after the holiday, on my next ride.
Old 05-20-2013, 10:03 AM   #523
3girlsdad
aka FiddyK
3girlsdad's Avatar
Oddometer: 369
here's an example of perforated decals. had them on an xr650L and they held up very well. zoom in on the pic and you will see the small cut out holes.
http://www.xrsonly.com/xrs-only-tank...da-xr600-88-up
2008 Honda CRF450X - plated
2007 KTM 450 XCW - a little sip of the kool-aid (gone)
2011 Beta 450 RR - plated (gone. had my sexy italian fling)
2008 Honda XR650L - (gone)
3girlsdad is offline   Reply With Quote
Old 05-20-2013, 01:48 PM   #524
McKay
McKay's Avatar
Oddometer: 911
Yes I understand the perforations, didn't know the Beta ones already had them. I misunderstood and thought somebody figured out a way to add them to stickers that didn't already have them.
We used to put them on with Windex, soaked the sticky side, slide them in place, then squeegeed them dry, worked very well.
Please report back, I live in much the same conditions you do.
Jeff
Old 05-20-2013, 03:58 PM   #525
Alacrity
Alacrity's Avatar
Oddometer: 468
Theres perforated graahics out there for this reason. Imagine you could USE those if its much of a concern.
Nah, ya understood fine, I suck at english. Since they're bubbling - assumed they were un-perfed. Does happen tho.
Petrol's a solvent, great for taking decals off, so its a bitch to get stuff to stick. Works best if they're attached for a bit before filling the tank.
Times are GMT -7.   It's 04:05 AM.
