Old 04-24-2002, 09:35 AM   #1
TigersCanFly OP
Oddometer: 36
Eek Kenda TrakMaster II's (DOT approved, barely?)
Just mounted the Kenda's on Monday. Road the bike to work on Tuesday(27 degrees F in the am), I took a 1 mile river trail section with hardpack, sand and few small jumps/bumps. These tires work unbelievably well on the blacktop, and they are not even broke in. The bike is still smooth, likes to go straight, stable up to 75 mph(fastest I went so far) and competent in the corners. There were no suprises, they are totally predictable. On the way home from work, I decided to give a favorite single track that is 6 miles long a try. I love this trail on my XT. Along with the smaller front sprocket and the awesome knobs, and upgraded front suspension, this bike is quite the trail bike for being 540 lbs. I tried a loosish hill climb last week with the T66's and made it half way. Yesterday I shot to the top with autority. I am having to re-learn how to ride the Tiger off-road, it is a hoot. I climbed a very loose sand dune that is about 35 feet high. It was simply amazing how the bike roosted to the top with out having to dab! Then I rooste to the top in 2nd gear at about 7,000 rpm! Coming down the dune was very predictable and actually fun. I then got into the woods section, complete with tree roots crossing the trail at all angles. The bike tracked straight. I then started getting comfortable with riding like I was on a much smaller bike. I completed a trail that I never thought I would do on the Tiger. I recommend the Trakmaster II's to anyone that doesn't mind loosing some on road manners, but gaining 10 fold offroad ability.
Fish-Bait
"the grass isn't always greener on the other side"
TigersCanFly is offline   Reply With Quote
Old 05-04-2002, 06:44 PM   #2
TigersCanFly OP
Oddometer: 36
Talking Here they are.....Kenda 760 TrakMaster II
TRACTION
Fish-Bait
Old 05-04-2002, 07:51 PM   #3
Rob Z
Rob Z's Avatar
Oddometer: 721
Thanks for the report. Only 75mph so far. Dam that is out my drive-way speed
Keep us posted on their wear. As I do 99% on road, but want to do more off road play. I have thought about getting a 2nd set of rims. One with street and one with mostly dirt. As it is almost impossible, for me, to change a tire on the Tiger.
I want to do the Trans-Continential trail this summer, but stree tires are out and dirt tires wound be wasted befor I got to the trail.
How about price and where you got them.
Rob Z is offline   Reply With Quote
Old 05-05-2002, 12:06 PM   #4
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,264
tire wear data point
Originally posted by Rob Z
"Thanks for the report. Only 75mph so far. Dam that is out my drive-way speed
I want to do the Trans-Continential trail this summer, but stree tires are out and dirt tires wound be wasted befor I got to the trail."
__________________________________________________ __________________________________________________
Since I run a sidecar, I can't comment on cornering or roadholding qualities of these tires on a solo bike(apples and oranges, doncha know). BUT I am extremely hard on tires; I regularly commute on pavement, do the occasional fully loaded 200- 500 mile pavement slog to get to a run or rally, and frequently do full throttle thrashes on logging roads and trails, desert, rocks, mud, logs -you name it.
The Trackmaster hums on pavement and wears off fairly soon, but doesn't melt before your eyes. I like it in the mud and rocks.
I prefer the Kenda K270 on the back( doesn't come in 19 so out of luck for the front:mad:) The knobs on the K270 are closer together, making it a little better on pavement and giving longer wear. This is a disadvantage in gooey stuf- I have had it clog in snow and mud, but if you can keep forward momentum it does OK. It is a good compromise in my opinion. I have heard mixed reviews from solo riders, but I have a friend who runs this on his KLR and does a lot of dualsport stuff; he likes it.
The Conti Twinduro TKC 80 is a nice DOT knobbie that comes in OEM sizes for the Tiger, which means it will fit under the front fender. I got OK wear out a set of these; if they weren't twice the cost of Kendas I would probably run them still.
I got caught short when I replaced the tires this spring so I bought a Pirelli MT21 Rallycross the local shop had for the front. At 120/80 19, it just barely fits the front of my bike, and only because I replaced the stock fender with a UFO dirt fender mounted to the lower triple tree. It doesn't look like I will get spectacular wear from this tire , but so far it is holding up. It is fun in the gravel and mud.
Because I've changed my front fender I have a greater range of tires that will fit the front, although most of them are intended for rear tires. I regularly use Kings 110/90 19. They are a cheap oriental knobbie found on sale in dirtbike shops. So far they have worn very well. THey hum like crazy on pavement; I ramped mine pretty severely coming home from the Mt. Raineer snow camp doing 80 down I-5 with passenger and full camp gear. ' handled OK and they had been on since October.
Last year I literally melted the knobs off a Cheng Shen, in about 50 miles . They only lasted 1 1/2 days on the bike
I have run Avon, Dunstal, Pirelli and Conti Dualsport tires with the 90%-10% type tread. Most of them wore fine on the street and rode quite, but sucked in any type of dirt. The Dunlop(don't remember what model) was a rear with a deeper, more agro tread than the others. It was good in dry dirt and gravel, but wore out very quickly( I did use a Dunlop desert tire on the front with very good results ).
For the Trans Continental, could you run street tires until you get close to the technical stuff and arrange to have fresh knobs waithing for you at a shop near the start of the trail(and maybe fresh streets waiting at the end)?
__________________________________________________ __________________________________________________ ____
"How about price and where you got them. "
Try Chaparral, Dennis Kirk, MAW or
http://www.tiresunlimited.com/
" I need to stop talking and start drinking" ...Mom
RedMenace screwed with this post 05-05-2002 at 01:07 PM
RedMenace is offline   Reply With Quote
Old 04-30-2008, 05:25 AM   #5
JayV2
Muddy Boxer
JayV2's Avatar
Oddometer: 326
TrakMaster II Revisited
Figured I'd dredge this thread back up and see if anyone else has recent experience with these tires.
I'm looking for a 17/21" knobbie setup that simply needs to be the most agressive knobbie possible for mixed terrain. DOT status is unimportant since the bike will not be ridden on the road with these tires.
Could use a 130/90-17 or 140/80-17 rear.
The TrakMaster looks pretty good among a short list of competitors since the 17" rear wheel size is the limiting factor.
JayV2 is offline   Reply With Quote
Old 04-30-2008, 05:44 AM   #6
DRZ400SK4
DRZ400SK4's Avatar
Oddometer: 2,047
I use the K760 on the rear of my DRZ400 all the time. I'm on my fifth or sixth one. I have it set up as a deep geared, serious off road bike. I prefer the K776 on the front, however.
They are excellent DOT off road tires. I've tried 'em all.
2008 Yamaha FZ1 / 2009 Kawasaki KLX450R / 2012 Triumph Scrambler
My Photos In Google Earth
DRZ400SK4 is offline   Reply With Quote
Old 04-30-2008, 06:02 AM   #7
JayV2
Muddy Boxer
JayV2's Avatar
Oddometer: 326
Great pics
- any specific reason you prefer the 776 front vs the 760?
(from the standpoint of versatile off-road traction & no street)
Old 04-30-2008, 06:08 AM   #8
BikePilot
BikePilot's Avatar
Oddometer: 11,251
If you don't need dot there are a lot of MX tires that do better than the 760's for hard riding. The 760's have tall knobs, but are quite heavy and have a weird feel if you push them hard in the dirt as compared to a mx tire (I bought a YZ once that came with 760's). I don't know what is available in a 17" rear though so a 760 might be as good as it gets. Also, I'm guessing that whatever bike you are riding with a 17" rear may not be a real dirt bike and you may not push it hard enough for the differences in flex charcteristics of the carcas to matter much.
At the least you could pick an off road only front tire to save some weight and gain a little performance. Something like a dunlop 952 makes a good all around front tire for trail riding on mixed terrian.
good luck
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 04-30-2008, 06:09 AM   #9
dirt missile
dirt missile's Avatar
Oddometer: 134
I just mounted one that I found by accident at the salvage yard while looking for car parts. It had about 90-95% left on it… for $10! Now that’s a deal! (who the hell would though away a new tire like that?)
Man, what a great off road DOT tire. A little different from my IRC GP-1 on the road, but who cares.
I tried it in some wet & muddy and suddenly I was a much better rider. Tractors right through the muck. But WOW is it noisy on the road, and rides a bit funny on the tarmac… on the DRZ, anyway. For that matter it was loose in the hard pack turns too, but awesome in a straight line.
I have a new set of Maxxis 6006’s waiting to be mounted, but now I’m wondering… ahh, I still have to try the 6006’s, they look really knarly. Anyone try them yet?
dirt missile is offline   Reply With Quote
Old 04-30-2008, 06:26 AM   #10
JayV2
Muddy Boxer
JayV2's Avatar
Oddometer: 326
I was eyeing the Maxxis 6001's when I stumbled across the TrakMasters. They look pretty agressive, but I don't think they are DOT if it matters.
Old 04-30-2008, 06:28 AM   #11
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
I'm another fan of the Trackmaster II. Works great in the soft stuff and wears ok on the hard stuff. I've used them on my DRZ and EXC both with excellent results.
Just make sure to take it easy on the pavement for the first 100mi or so, otherwise the tire can start to chunk.
paochow is offline   Reply With Quote
Old 04-30-2008, 06:29 AM   #12
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
Trackmasters are DOT, stamped right on the tire.
Old 04-30-2008, 06:39 AM   #13
DRZ400SK4
DRZ400SK4's Avatar
Oddometer: 2,047
Any specific reason you prefer the 776 front vs the 760?
The front K760 tends to get a little squirrely on pavement. The 776 hooks up just as well in the dirt, but has better pavement manners.
The K776 is the closest thing I could find to the Michelin AC10 (Also a great off road front tire), buts it's much cheaper, and seems to work and last just as well.
DRZ400SK4 screwed with this post 04-30-2008 at 06:44 AM
Old 04-30-2008, 07:30 PM   #14
jgunsett
Goin' Coastal
jgunsett's Avatar
Oddometer: 515
I'm on my 3rd set of Trackmasters on my DRZ400S. It's just about the best thing you'll find in a DOT knobby, and is great in just about all conditions (fair in mud, great in just about anything else you'll hit). I have the Michelin Ac-10s on my CRF450X. The AC-10s are lighter, and better off road, but they're also a lot more expensive, and don't last nearly as long as the Kendas. I've heard of a lot of riders running a Pirelli DOT knobby on the front (not sure of the model, but I think it's an M-16) and a Kenda Trackmaster on the back. I'm going to try this combo next on my DRZ.
'09 Kawasaki KLR650 '09 Yamaha WR250R 2012 Yamaha XT1200Z Super Tenere, 2012 Can-Am Spyder RT.
"Life's Short - Turn Up the Bass!"
jgunsett is offline   Reply With Quote
Old 05-01-2008, 05:00 AM   #15
Transalp Jas
Transalp Jas's Avatar
Oddometer: 807
I ran trackmaster II's on my 'alp for a season awhile back. Great tires, but I went through them pretty fast. Great on the road, even better in the dirt. I'd still buy them again, but not if I was planning a lot of travelling. Planning to add a second bike for road duty, and after that it'll probaly be all trackmasterII's for the 'alp.
Chuck Norris can blow bubbles with beef jerky.
Chuck Norrris has never gotten a Jeopardy question wrong. Jesus has missed two.
Transalp Jas is offline   Reply With Quote
Times are GMT -7.   It's 03:46 AM.
