Old 02-18-2008, 05:06 AM   #1
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
Norton Mercury 1969
Just purchased this sad fellow. It has sat in a garage for 25 years after being diagnosed with damaged valves. 1969 model in original if somewhat sad trim. Just completed a 61 Norton ES2 resto so can't wait to start on this one. It is great to have more than one Norton in the garage.
manxkipper screwed with this post 03-02-2011 at 11:33 PM
manxkipper is offline   Reply With Quote
Old 02-18-2008, 05:11 AM   #2
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
The completed ES2. The Mercury should turn out like this.
manxkipper screwed with this post 03-02-2011 at 11:31 PM
Old 02-19-2008, 10:52 AM   #3
Nessman
Cluttered Minimalist
Nessman's Avatar
Oddometer: 1,747
Kewl,
A friend had an Atlas in his garage for years, never could talk him out of it. Love the upright Norton twin, IMO the prettiest Brit vertical twin.
Looking forward to the story.
'07 Bandit 1250ABS
'78 XS650 with patina
Huge piles of Guzzi that aren't motorcycle shaped.
Nessman is offline   Reply With Quote
Old 02-21-2008, 09:54 PM   #4
dungspreader
King of the Heap
dungspreader's Avatar
Oddometer: 451
Manxkipper, you are a lucky fella !
I thought WanKing was a town in China 'till I discovered Adventure Rider
dungspreader is offline   Reply With Quote
Old 02-21-2008, 10:31 PM   #5
Steve G.
Steve G.'s Avatar
Oddometer: 6,950
Very cool! Nortons are close to my heart, have a couple myself, they are all great in my book. I've always admired the way featherbeds go around corners though, true athletes!
Steve
Steve G. is offline   Reply With Quote
Old 02-22-2008, 01:47 AM   #6
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
Very, very nice. Sad? No way. This is a damn complete original example of a pretty rare model. Love the blue oil tank and the humpback Mercury seat. If the single is any example, you will soon have it all well sorted. Luvly.
I have an Atlas but OMFG but they do vibrate - no wonder they invented Isolastic engine mounts for the Commando - and I reckon the 650 would be a sweeter running more useable bike.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 02-22-2008, 04:01 AM   #7
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,501
The 600 was the sweetest running Norton twin - the 600 was a bored 500,the 650 was stroked,and the 750 and 850 used the same stroke.My 600 SS was not much slower than a 650,and revved much free er.I used to take it out to 75mph in second every day on the way home from work.
motu is offline   Reply With Quote
Old 02-24-2008, 01:54 AM   #8
NCGS
De Oppresso Liber
NCGS's Avatar
Oddometer: 1,183
'13 Explorer XC
'13 Multistrada Pikes Peak
Do not regret growing older, it's a privilege denied to many.
NCGS is offline   Reply With Quote
Old 03-20-2008, 02:12 AM   #9
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
No compression on cylinder 1 equals the following - broken left cylinder inlet valve guide. trashes both cylinders pistons and head. It looks like little elves have been busy with hammer and chisel. The inlet valve stem has picked up some metal and appears fractionally bent. Exhaust valve on cylinder 1 is also bent and the seat is trashed.
The only puzzle for me is - how did metal get back up the inlet manifold and land in cylinder 2? The Mercury only has one carb so it is theoretically possible for the foreign object to make its way into the second cylinder.
Strangely the bores look ok. You never know what pandora's box will serve up! The prior owner told me that the bike lost power so he parked it.
manxkipper screwed with this post 03-02-2011 at 11:29 PM
Old 03-20-2008, 02:13 AM   #10
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
second pic
Old 03-20-2008, 02:14 AM   #11
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
Piston pic
manxkipper screwed with this post 03-02-2011 at 11:28 PM
Old 03-20-2008, 02:26 AM   #12
manxkipper OP
Fishpistel
manxkipper's Avatar
Oddometer: 465
Two of the barrel studs were loose when I removed the barrel from the crankcase. As I lifted the barrel off both studs came out with their respective threads. It seems that Charles Atlas torqued the nuts down during the previous rebuild. Helicoil city coming up.
The hamfisted alway confuse their abilities with their intentions. Anyway enough griping.
Old 03-20-2008, 04:01 AM   #13
kirk69er
kirk69er's Avatar
Oddometer: 471
wow
..good shots
..looks like a lotta fun
kirk69er is offline   Reply With Quote
Old 03-20-2008, 06:39 AM   #14
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Piston pic
Looks like the previous owner had a serious lack of mechanical sensitivity. He let that thing run for quite awhile with all those bits in there.
I remember once sucking a slide needle clip into one of the cylinders on my Royal Enfield. It was obvious something serious had gone wrong, and I shut it down immediately and pushed it home (only a couple of blocks).
On taking it apart, I found the clip neatly caught between the intake valve and the seat. It had only nicked the top of the piston a couple of times.
As for the Mercury, I agree with other's assemsments; that's not at all sad. It's all there, and in basically good condition. A little corrosion is no problem at all.
What's sad is to find something like that which some tasteless idiot had attampted to "customize". Which meant hacksawing or bending anything they didn't just throw away.
caponerd is offline   Reply With Quote
Old 03-20-2008, 09:11 PM   #15
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,578
That is going to be one sweet Norton! So where does one find pistons and valve guides for that particular engine?
My freshly restored Laverda sucked a whole needle through, made a god aweful clunk and before I could kill it the bike returned to idle, but only on one cylinder due to missing the needle. I took it apart and couldn't find the needle and it just scratched the top of the piston, guess it didn't like it and spit it out the exhaust!
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 05:25 PM.
