Old 08-07-2008, 02:07 PM   #1
BigCanoe OP
Oddometer: 703
Acerbis rally pro installation?
I bought a used pair off EBay with no instructions. It looks straight enough, ecept for a couple of questions:
1) What are the long oval (rounded rectangle) washers for?
2) I assume the rubber sleeves go over the part that goes in the bar end?
3) The guards themselves are a little different, one has an extra tab about 2x3, is this the driver side, I assume they only go one way.
Anyone have any pics of their installation?
2007 Yamaha TW200
BigCanoe is offline   Reply With Quote
Old 08-07-2008, 02:27 PM   #2
panasync
Oddometer: 62
'Don't know - neither of my two sets of Rally Pros had them or any other brand I've owned for that matter.
Yes, if you have steel bars, no for (thicker walled) aluminum bars.
Driver side ? How about the right side. The tab adds some protection for the master cylinder.
Sorry, no pics.
panasync is offline   Reply With Quote
Old 08-07-2008, 03:01 PM   #3
BigCanoe OP
Oddometer: 703
Driver's side, not sure what I was thinking there :)
I dont see how these can fit with the stock levers...
2007 Yamaha TW200
BigCanoe screwed with this post 08-07-2008 at 03:08 PM
Old 08-07-2008, 03:35 PM   #4
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,577
I looked for quite a bit for different levers for mine (2003 DR650) but just ended up removing the ball-ends.
Mike
Sorry I don't have any good pics of mine available.
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is online now   Reply With Quote
Old 08-07-2008, 07:15 PM   #5
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
click on the part that says "mounting instructions"
http://www.acerbis.com/p106_handguard/1325.html
hope that helps.
datchew is offline   Reply With Quote
Old 08-08-2008, 05:31 AM   #6
BigCanoe OP
Oddometer: 703
Ah yes, thanks for the link. Do you think the ATV extensions would work without having to cut the levers?
2007 Yamaha TW200
Old 08-08-2008, 09:13 AM   #7
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,890
You could move the guards up or down to clear the levers, replace levers, in most cases cutting the balls off did the trick
gimmie the button!
Truckin_Thumper is offline   Reply With Quote
Old 08-08-2008, 09:56 AM   #8
BigCanoe OP
Oddometer: 703
Seeing how my other thread is discussing removing pink graphics, maybe ballless is best
2007 Yamaha TW200
Old 08-09-2008, 05:46 AM   #9
Truckin_Thumper
low profile
Oddometer: 28,890
gimmie the button!
Times are GMT -7.   It's 08:03 PM.
