Old 03-18-2008, 02:31 PM   #166
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
Originally Posted by ADVnut
Solo-
You may have older electrics on your bike and not have this problem, but now do all the signals blink really fast? Figure out a way to fix it?
I put those handguards on my GS and it hyper flashes now, kinda like the bulb is out.
Haven't wired 'em up yet.... I'll let you know what happens when I do. I was thinking about boring out the hole the small bulb slots into to take the stock BMW size bulb....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-18-2008, 02:33 PM   #167
soyanarchisto
soyanarchisto's Avatar
Oddometer: 3,591
There was a discussion on the airhead email list about that hyper-flashing problem and I seem to recall that you need to install a resistor or something in the line.
I have the same handguards with the spoilers w/o the turn signal option. I like them but they are not as effective at blocking the wind as the stock guards.
soyanarchisto is online now   Reply With Quote
Old 03-18-2008, 02:34 PM   #168
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,978
Solo-
That would be because the new signals aren't 21w right? The relay thinks a lamp is out because its not seeing enough wattage. I think...
Just need a different relay-
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 03-18-2008, 02:37 PM   #169
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
Originally Posted by soyanarchisto
There was a discussion on the airhead email list about that hyper-flashing problem and I seem to recall that you need to install a resistor or something in the lin .
My G/S hyperflashed when signaling for a left turn, the problem was the left bulb was out (stock system).... must be something about the draw of the bulb. That's why I am thinking stock bulb in the new t/s's
If they are acerbis, you can buy "spoilers" check the first post in this thread, there are the same handguards (less t/s) with spoilers on my old GS
R65LazaruS
Solo Lobo screwed with this post 03-18-2008 at 02:54 PM
Old 03-18-2008, 02:46 PM   #170
elmoreman
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,770
Originally Posted by SOLO LOBO
My G/S hyperflashed when signaling for a left turn, the problem was the left bulb was out (stock system).... muse be something about the draw of the bulb. That's why I am thinking stock bulb in the new t/s's
If you could sort this out before mine come in the mail, I'd appreciate it
airhead aficionado
elmoreman is offline   Reply With Quote
Old 03-18-2008, 02:54 PM   #171
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
I'll do my best!
R65LazaruS
Old 03-18-2008, 02:59 PM   #172
ADVnut
Still Looking
ADVnut's Avatar
Oddometer: 177
All mine hyper flash and I have 4 non-stock turn signals and LED Dash indicators, none 21w.
I was thinking of using a different flasher that is non-BMW maybe a car flasher or one of those signal minders with all the widgets.
ADVnut is offline   Reply With Quote
Old 03-18-2008, 03:11 PM   #173
RocketJ
Oddometer: 674
Electronic flasher
Here is an example http://www.superbrightleds.com/flashers.htm.
Compare and you should be able to find them local, autozone,napa etc.
you can use resistors, but then they will still draw the same amperage anyway, and be more complicated etc...............
RocketJ is offline   Reply With Quote
Old 03-22-2008, 11:51 AM   #174
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
weekly update:
Replaced the throttle and choke cables... man, with the tight fit of the Heinrich it is a realy fiddly job to get everything in there and keep tention off of the cable.... blew some high comp air through the idle jet passages as one carb's idle mix screw wasn't doing much and I thought the passage could be blocked....
Rode about 10 miles, and re-synched the cables (checking for free play this time! )
Today, wired the new front t/s in the barkbusters and removed the stock t/s, threw in the dynabeads and tossed the wheel weights... and superglued my odo button back together (seems to have worked!)
Latest pix....
R65LazaruS
Old 03-22-2008, 12:08 PM   #175
Putts
Gettin' there.
Putts's Avatar
Oddometer: 11,393
Looks terrific, mate.
So, do you feel better now? Is the world all in its place now that you're riding a G/S?
Thought so.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is offline   Reply With Quote
Old 03-22-2008, 12:49 PM   #176
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
Thought so.
R65LazaruS
Old 03-22-2008, 01:07 PM   #177
Putts
Gettin' there.
Putts's Avatar
Oddometer: 11,393
I got the spoilers, they're just like me, they break wind pretty well.
Old 03-22-2008, 01:33 PM   #178
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
Cool ! I went rogue and ordered the same in CLEAR!
R65LazaruS
Old 03-22-2008, 02:04 PM   #179
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
How do flashers work?
The stock BMW indicator relais are most likely depending on a certain resistance from the four bulbs to work. I think they all working mechanically as they all click. If one bulb is out it flashes twice as fast, because of half the resistance in the circuit. If you use LED bulbs it doesn' know what to do as it sees an electronic circuit so it either hyperflashes or does nothing (haven't tried, so don't know). To run either normal bulbs or LED you need an electronic relais that flashes independant of the load (resistance).
I bought this one from a German ebay seller, these guys ship worldwide:
0.2-20A indicates the load range: LED to standard bulbs
Here's the link to the auction: http://cgi.ebay.de/ws/eBayISAPI.dll?...m=140192646433
I think I paid 15 bucks shipped.
Hope that explains it.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 03-24-2008, 09:01 PM   #180
Stuntman
Stuntman's Avatar
Oddometer: 677
Nice work Solo! I've been lusting after a G/S for a long time. One of these days...One of these days.
Bring a compass, it's awkward when you have to eat your friends.
Stuntman is offline   Reply With Quote
Times are GMT -7.   It's 08:07 AM.
