Old 08-19-2011, 04:51 PM   #1141
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,464
Originally Posted by Stagehand View Post
nerds
...says Mr. D+D.
Never talk shit about star wars.
[/BSINGINSOLOSTHREAD]
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 08-19-2011, 06:43 PM   #1142
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
Originally Posted by Airhead Wrangler View Post
...says Mr. D+D.
Take your nerd talk elsewhere please
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 09-09-2011, 11:49 AM   #1143
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
Somewhere in this thread I had complained that my right cylinder has a louder valve train than the left side, and proclaimed that I had measured everything carefully when I converted the 1981 rocker setup to the 1985 and later style with shims...
On a whim (whim/shim, get it?) I pulled the valve covers and measured 'em all.. low and behold three are outside spec and require shimming!
The new shims are at the dealer, time permitting they will go in Saturday and I'll post some pictures.
Old 09-11-2011, 09:21 AM   #1144
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
So where has the time gone?
Let's see... spent hours remodeling my work space...
Bike parking area:
reworked the bench area:
Spent endless hours wet sanding my tank:
and finally, reshimmed my noisy valve rockers that were out of spec by quite a bit:
Old 09-16-2011, 04:17 PM   #1145
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
Wow, I must say that correctly shimming your rockers really does make a significant difference in the valve train noise level...
Can't wait to ride home after work... the bike sounds REALLY different!
Old 09-16-2011, 09:08 PM   #1146
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Can you give me a link or a quick write-up on the rocker shimming? I'm at 80k and my left side's a lot louder than the right.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 09-16-2011, 10:31 PM   #1147
fishkens
Further...
Oddometer: 5,147
Yep, in my experience rocker end play is the source of FAR more valve train noise than valve lash.
Adjusting end play on shimmed assemblies is fairly straightforward. Bring each cylinder to TDC (as in adjusting the valves) measure rocker end play clearance. if it's more than .001 you'll probably be able to add a shim to quiet it up.
After measuring all four clearances buy an assortment of shims that will close up the gaps (buy some extras to allow for mixing and matching as needed). Remove the rockers and reassemble with a combination of shims that eliminate the gaps. Test fit (either w/out pushrods or loosening lash adjusters enough to allow you to see if the rockers still swing freely but have no end play - I prefer not installing the pushrods). Finally, put everything back in place, torque the head bolts and adjust the valves.
If you removed as little as .001" - .002" in end play you'll probably notice that the bike is quite a bit quieter. I've removed .003" - .004" which was causing quite a rattle.
As for final clearance, aim for less than .001. The rocker should swing but have no noticeable end play (I can't recall an actual spec - maybe Lone Wolfie has one?).
That's how I do it. Hope it helps.
fishkens is offline   Reply With Quote
Old 09-16-2011, 11:15 PM   #1148
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,125
no noticeable play. SHould just see the oil film kinda thing, but still it rotates without any kind of resistance.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 09-17-2011, 09:19 AM   #1149
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
Brad,
I actually updated my rockers to the 1985 and later version that makes a provision for shims... I don't know how to shim your 81-84 version... perhaps just throwing in a shim?
As to determining the correct shims needed, I used feeler gauges to determine what was needed, took apart the rockers, measured all the shims I had and determined what I needed to buy.
Funny thing is there are like 5 sizes availabe, four cost under a buck and one is $3.... before I saw the prices I was going to buy three of the 0.35's that are $3, instead I spent $5 and got six other shims to do the same job
Old 09-17-2011, 09:31 AM   #1150
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,948
When shimming anything it's prudent to use the least number of shims possible.
Old 09-17-2011, 09:40 AM   #1151
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,125
i ran onto that same thing, just a couple of weeks ago. Crap, months ago, now Obviously the expensive one is the one you need
81-84? I think you have the shimmable ones, and not the ones you press and tighten. Is there a black plastic bushing and some shims already in there?
First of all, you have up-and-down lash on the rocker, yes? I stuck feeler gauges in the gaps on mine to get an idea of what to aim for in terms of how much room I had to make up.
Old 09-17-2011, 09:59 AM   #1152
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
81-84 are the weird ones, 85 on have the plastic insert and shims...
That's what I did.
I ended up with two shims per on 2 and 3 shims per on two... agreed about the minimum shims, but these are to some extent not bearing much load as they are on top and do have some clearance.
SOLO LOBO screwed with this post 09-17-2011 at 10:07 AM
Old 09-17-2011, 04:24 PM   #1153
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
that bike is starting to look mean Gage.
I really like it.
datchew is offline   Reply With Quote
Old 09-17-2011, 08:38 PM   #1154
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Mine's an '85. If I post pics can you tell what I've got? What am I looking for?
Old 09-18-2011, 11:00 AM   #1155
SOLO LOBO OP
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,718
Check Anton's page here:
http://largiader.com/tech/rockers/
Times are GMT -7.   It's 11:37 AM.
