Old 03-12-2012, 05:12 PM   #1186
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
dang I was looking at the needle..not the jet. Thanks
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-12-2012, 06:29 PM   #1187
_cy_
Oddometer: 6,173
needle wears into the jet .. best to replace as set
_cy_ is online now   Reply With Quote
Old 03-12-2012, 06:34 PM   #1188
One Less Harley
Oddometer: 4,695
54 mpg!!!! what's you carb set up??? I might be able to get 42 mpg, w/ a tail wind.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-12-2012, 06:44 PM   #1189
_cy_
Oddometer: 6,173
note that was with an extremely light throttle... no clue on jetting. but what I did do is custom tuned mixture by regulating exhaust discs with a tunable exhaust system. did plug checks to verify mixture range.
kept adding exhaust tuning discs (less back pressure) until power started dropping off with plugs reading very lean. then reversed process slowly by subtracting discs (more back pressure), until power band improved along with correct plug color.
I've got a color tune, but have not used it with G/S yet. my G/S sure runs strong! out runs my R90S to 95 mph and it's got 185 psi compression. very strange...
adding exhaust tuning discs leans mixture... this would an easier way to lean mixture when traveling at altitudes for extended periods.
_cy_ screwed with this post 03-12-2012 at 06:53 PM
Old 03-12-2012, 07:11 PM   #1190
supershaft
because I can
Oddometer: 9,116
You got to remember which word is the noun and and word is the adj.. The numbers we have been discussing are needle jet sizes, not jet needle sizes. Different PN's for jet needles but that is all about how they are held into the slide. Other than that, there are no choices with our CV's. It confusing and very easy to type backwards. Well, I still hope I have helped.
Old 03-15-2012, 07:21 AM   #1191
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
How about this beautiful work by our own wirespokes? That's a custom built brass adapter for the speedo cable to replace the broken plastic one
Some new Alu stock to re-manufacturer the top headlight bucket mounts this weekend
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 03-15-2012 at 09:29 AM
Solo Lobo is offline   Reply With Quote
Old 03-24-2012, 03:44 PM   #1192
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
OK, back on the road:
It's a beautiful sunny 60 degree day here in Seattle, I put it together and hit the road for a limited run.
First thoughts on the WP Extreme 50mm front end:
  • waaaaaaayyyyy plush!!
  • Absorbs bumps/drips/whatever like crazy
  • Steering seems nearly identical to the previous set-up
  • Brakes seem like I will not miss my 320mm rotor kits from the old front end
Things to address now:
  • Tighten the steering head bearing adjustment
  • bleed front brake (spongy, but otherwise seems good)
  • Compression adjustment - well the bike dives heavily under braking and I though I had 10 more clicks of comp to add, got two more and that was it. May need to go to the suspension tuner (no big surprise)
  • Clunk coming from the left (comp) fork upon rebound??
Other things learned:
  • Rebuilding the carbs - next time pull the chokes before cleaning in the ultra sonic tank. Some scrunge built up and froze the chokes. I had to strip (spilling gas everywhere) and clean. Need to get some new choke return springs and gaskets
  • Don't introduce multiple changes at once... while I was riding around testing the new forks, the carbs where horribly out of synch and the handlebars were a bit loose
  • Wrench less, ride more
R65LazaruS
Solo Lobo screwed with this post 03-25-2012 at 09:54 AM
Old 04-28-2012, 02:18 PM   #1193
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
  • Set set my Ohlins back to the baseline settings
  • Adjusted the steering bearing pre-load as it was to light
  • replaced the bent float pin I found (caused) on the last rebuild with new, as well as the other side
  • checked that both the jet needles were on the third notch as I have some popping on decel with the throttle closed
No ride however.... perhaps later
R65LazaruS
Old 09-19-2012, 11:12 AM   #1194
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
"Don't bury me, I'm not dead yet"
R65LazaruS
Old 09-19-2012, 01:06 PM   #1195
_cy_
Oddometer: 6,173
good grief .. you've got a LOT of work into your G/S!
Old 10-17-2012, 08:49 PM   #1196
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
And I'm not done yet !
R65LazaruS
Old 10-18-2012, 10:20 AM   #1197
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,847
After almost 5 years and 121000 thread views - how many miles have you put on this thing
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 10-18-2012, 11:16 AM   #1198
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
I'll have to take a picure of my Odo this weekend and post it up!
R65LazaruS
Old 02-08-2013, 12:43 PM   #1199
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,804
Glacial pace here.... anyway just doing research as I am either going to:
  1. Have my WP's re-valved and rebuilt right away
  2. Have my frame and other bits blasted and powder-coated
  3. Have the reinforcements welded on and then #2
Need to figure out which takes priority... thinking #3 today...
R65LazaruS
Old 02-08-2013, 01:07 PM   #1200
Cordless
Two Wheel Addict
Cordless's Avatar
Oddometer: 2,041
Looking forward to seeing this g/s. And I might just get a chance to.
Will you document your teardown, welding, frame painting, and reassembly here with lots of photos?
Enquiring Minds and all that.
Cordless is offline   Reply With Quote
Times are GMT -7.   It's 12:20 AM.
