Old 07-09-2013, 10:51 AM   #1246
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Originally Posted by Airhead Wrangler View Post
No need to go that big. 4ga or even 6 should be good enough. I'd try going straight to the trans or block somewhere, but if that's not easy, then the frame, would probably get you home fine. For your long term solution this place in Everett has everything you could ever want and more: http://www.allbatterysalesandservice...cfm/4,513.html
Just got this... will install at lunch
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 07-09-2013, 11:52 AM   #1247
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Turns out that my toolkit is missing the allen wrench to take out the trans mounting bolts, that and the bolt I was going to use may not be long enough to accodate the new cable end.
I'll have to nurse it home as it tonight and buy a longer bolt this weekend.
R65LazaruS
Old 07-09-2013, 11:55 AM   #1248
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
considering:
Originally Posted by chollo9 View Post
Any of the tranny cover mounting bolts would work. I replaced one of mine with a 6mm stud, then used (in order) a short spacer against the cover (O.D. same as the stock bolt head/washer, ring terminal from cable, washer, and nut. Tighten to same spec as other cover bolts. You may need to make up a new cable depending on which bolt you use. This has held up for me for quite a while. You could do the same thing with a longer bolt, but it involves some dicking around finding the correct length, plus I wanted to take the wear and tear on the case threads out of the equation.
or:
Originally Posted by pkboxer View Post
I have longer allen bolt in the lower right transmission mounting hole and then a double nut with a new ground wire clamped between the nuts.
I did have to order the bolt to get the right length.
R65LazaruS
Old 07-13-2013, 12:52 PM   #1249
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
New negative cable installed, as soon as that was done I checked the battery voltage (it has been off of the tender for 5 or 6 days now and it was ~8 volts... new battery on order but I am sweating heading out to the rally now as the only prep time I have before an early scheduled departure on Thursday Am is 2 hours today perhaps an hour or two tomorrow and that's it due to work and other stuff...
Charger's on the bike (new battery arrives Tuesday) and I need to re-set the timing as its not right after my search for the squeak.
R65LazaruS
Old 07-13-2013, 07:13 PM   #1250
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,532
Here's where I went.....I did it so long ago I cannot remember if I went with a longer/different bolt.
 photo 026016D5-5559-4D21-801F-CD4EC2EC7BA0-10053-0000096E5863334B_zps1812b9e3.jpg
 photo 6DA92C3B-CE19-4980-A1EF-27F08F0852B1-10053-0000096E0859BF75_zps11e23e39.jpg
Old 07-13-2013, 08:33 PM   #1251
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,871
For a long time I went to the subframe bolt, next to the shock mount. Its shouldnt matter, I mean, its not through the forks, and a bunch of bearings and grease, but is probably better off the engine itself.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 11-13-2013, 03:29 PM   #1252
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
It's been a while... how time flys
Anyway, just handed my rear Ohlins over to Alex at Konflict Motorsports for a servicing, re-valving and perhaps spring change.
Not so exciting, but progress none the less!
R65LazaruS
Old 11-13-2013, 05:17 PM   #1253
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,551
He just did my forks and has a heavier rear spring on order.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 11-23-2013, 09:50 AM   #1254
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Just a service and a change to the heavier spring I had as the other one was way too soft.
Alex commented that he had never seen such a weak shim in a low-speed damping circuit before... the heaver spring may work, if not I'll have it re-valved
R65LazaruS
Solo Lobo screwed with this post 11-23-2013 at 10:11 AM
Old 11-23-2013, 10:18 AM   #1255
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,747
The ohlins I bought had a 200 lbs spring on it. sag was just right for a 165 lbs rider. Maybe a wee bit stiff but with luggage dead on!!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-28-2014, 02:28 PM   #1256
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Well, it's 50+ degrees in Seattle and sunny today! I had my G/S all checked out and ready for the first ride since what... September?
Dog's not feeling well and had to drive...
In other news, scored a correct early G/S tank with the raised filler neck (at least I think it is genuine and correct).
R65LazaruS
Old 02-28-2014, 02:31 PM   #1257
One Less Harley
Oddometer: 4,747
I saw one of those on ebay a while back went for pretty cheap...that's the one isn't it...I just didn't need a third tank. It was tempting to buy it anyway...
BTW- had the Ohlin's rep, mention he doesn't recommend the neoprene booty as it keeps the heat in on the shock and oil and it's detrimental to performance.. That being said I'm keeping mine covered.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-28-2014, 02:33 PM   #1258
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Actually this one was for sale in the airhead flea market for a week or more before I decided I coulnd't live without it.. now I need to buy the correct cap and see if it can work without removing the Acerbis tank mounts or now.
R65LazaruS
Old 02-28-2014, 02:35 PM   #1259
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,986
Hmm... Both Dan Kyle Racing and Alex said to use one... and when I had mine rebuil there were no nasty suprises nor toasted oil and the sock has been on for most of my miles.
now on the other hand, if I was Stagehand or something I might keep it off!
R65LazaruS
Old 02-28-2014, 02:35 PM   #1260
One Less Harley
Oddometer: 4,747
I swap between the HPN and stock tank, leaving the front mounts on, but take the rear off, and plug the right fuel line. I hardly ever use the little tank though.
My tank has the screw cap like yours...1984 year.
you should be able to see them here..bike in pretty trim.....BTW not usually this clean.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-28-2014 at 02:47 PM
Times are GMT -7.   It's 10:26 PM.
