Old 02-28-2008, 07:26 AM   #1
DockingPilot OP
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,561
Facet #40171 Users Check In
I'm about to switch over from the earlier Facet (I forget the #).
Question: Hows the 40171 treating you ? Any flooding or hydro locking issues with the petcocks left open with this one ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 02-28-2008, 02:07 PM   #2
Ooobah-Moto
Ooobah-Moto's Avatar
Oddometer: 3,809
Please post!!!!
+1 this thread...
If it's any consolation, a friend of mine here in Ontario just finished up a weekend training ride down south and his 40171 worked perfect!
I'm planning to install my 40171 in the coming week.
Ooobah-Moto is offline   Reply With Quote
Old 02-28-2008, 03:11 PM   #3
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,311
So did Dennis post a ride report?
I have heard only good things of the Facet 171 you speak of - no worries - even with aqualine tanks on.
edit: correct model name
Be true....to yourself
HappyGoLucky screwed with this post 02-29-2008 at 05:21 AM
HappyGoLucky is offline   Reply With Quote
Old 02-28-2008, 03:58 PM   #4
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,968
So far so good. 2,000 miles on it using the 12 gal tanks and it holds the fuel back over night. It has been starting up much better than w/ my old facet. (I think it flooded the motor on start up)
Riding has slowed down around here w/ all the snow/ice, but hopefully it will get better soon.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-23-2008, 05:22 AM   #5
DockingPilot OP
Oddometer: 9,561
My Facet 40171 is working flawlessly.
Frank Reinbold
Old 03-23-2008, 08:20 AM   #6
Hair
Outside the boxer
Oddometer: 13,927
I have a Facet pump on my SE. I am not sure of the model. I think that it is the older one that allow for gas to flow when the 950 AVDs were on their side stand. It doesn't do this on the SE.
But I have noticed that my pump runs a lot. Even when it sounds like it is pushing on a serous pressure head.
Do these pump have a pressure swtich? Do they turn off for a while when the carb bowls are full?
I am having battery problems. It would be great if I could figure out if the pump is draining the battery.
As we age we tend to become more direct in our thoughts and actions.
For me laundry day is no longer Wishy Washy day.
Hair is offline   Reply With Quote
Old 03-23-2008, 08:27 AM   #7
DockingPilot OP
Oddometer: 9,561
Mine shuts off.
Frank Reinbold
Old 03-23-2008, 09:01 AM   #8
Hair
Outside the boxer
Oddometer: 13,927
Does it really pull down before it turns off?
Old 03-23-2008, 09:03 AM   #9
DockingPilot OP
Oddometer: 9,561
well, it does not flow fuel when off if thats what you mean.
Frank Reinbold
Old 03-23-2008, 10:00 AM   #10
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
This quote is from the HOW. It is part of a description of a series of tests done on several Facet fuel pumps for the light/experimental aircraft industry.
Dennis Douglas, Pillar Point Avionics, Inc.:
"In the "OFF" state, however, the differences between the pumps become more obvious. At a 30-inch head pressure, the 40105 and 40106 pumps have a forward "leak" rate or drain rate of about 15 gal/h. These pumps thus flow freely in the forward direction at about one-half the pumping rate.... In the reverse direction, the 40105 and 40106 drain backwards at between 0.05 ga/h to about 0.25 gal/hr, with a mean value over a dozen tests with four different pumps of about 0.1 gal/h. (As a point of reference, 0.1 gal/h is about one drop per second). Compare these numbers to the 40171 pump, which showed no detectable leakage in the "OFF" state in either the forward or reverse directions over several hours."
The full quote is at:
http://www.ktm950.info/how/wotf/wotf.html#FuelPumps
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 03-23-2008, 04:56 PM   #11
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Arrived from good ol USA the other day...
Couple of 40171,s waiting to replace the 40105s should give me the functionality I wanted originally with electrically switching between front and rear tanks (without having to turn off fuel taps!)
Cheers
Pilbara
Pilbara is offline   Reply With Quote
Old 03-23-2008, 08:38 PM   #12
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
40171's should work good for that use. I have a bunch of them "out there" in daily use on various iterations of multi tank installs. None have failed yet and all are performing as designed.
-cp
cpmodem screwed with this post 03-24-2008 at 02:22 AM
Old 03-23-2008, 10:43 PM   #13
Lost Again
Fresher Meat
Lost Again's Avatar
Oddometer: 273
Go for it!
I swapped my old Facet for a new 40171. It works perfectly. No leaks or hydrolock. The only pain was having to remove the battery to get at the mounting hardware.
Lost Again is offline   Reply With Quote
Old 03-24-2008, 09:00 AM   #14
Hair
Outside the boxer
Oddometer: 13,927
This post did nothing to answer my question.
I get this all the time. Guys who respond back with a truck load of irrelevant info so a simple question.
I really don't think that the answer is "See my link to my page of irrelevant info."
Old 03-24-2008, 09:09 AM   #15
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Talking Maybe you should make your question clearer
Gee whiz, and there I thought I was answering your question.
-cp
Times are GMT -7.   It's 08:13 AM.
