Old 09-15-2010, 06:14 PM   #346
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,756
Originally Posted by mookymoo
My 2c ... less chance of flattening the battery priming the Facet pump & filling the bowls. (e.g. falling over a lot in sand)
You have to crank the motor for the vacuum pump to pump.
Might be unwarranted worry, but Im happy with the 40171. Moreover, I dont know anyone else that has had any problems with it either.
+1, I considered the vacuum but went with the 40171 for the same reason.
almost 30k km on the stocker with no issues. switched to the facet for over 10k kms now and it works flawlessly.
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2, 1999 Intruder 1500, 08 Aprilia rxv450, 90 DRBIG 800,79GS850
Ride Reports
FINNDIAN is offline   Reply With Quote
Old 09-15-2010, 06:20 PM   #347
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,954
Originally Posted by Stobie
When I installed my Facet 40171 ... It ran OK, but a bit rich. I installed a $30 Mr. Gasket fuel pressure regulator, set it to 1.5 psi ...
Apparently, my Facet is a bit of an overachiever.
I think 1.5psi is just right too, Stobie.
Brown Dog is offline   Reply With Quote
Old 09-16-2010, 09:25 PM   #348
renogeorge
Oddometer: 1,390
Facet
I may have missed it, but I had not heard on the 40171 having "over pressure" issues. My only experience is with this pump on a bike is with my Super Moto which carries the pump higher (I think) than the Adventures. This might be a factor in that the SM would be MORE prone to over pressure or gravity feed overcoming the carb fuel valve---less vertical distance for the fuel to rise from the pump to the carb.
So maybe there are differnces in manufacturing tolerances between various 40171 Facet pumps????? Or something else at work here??
40171 on a SM for 15k miles, no regulator, never turn off petcocks--works great! Maybe I'm just lucky?
renogeorge is offline   Reply With Quote
Old 11-26-2010, 07:39 PM   #349
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,922
Originally Posted by AdvGa
Well, I just got done installing the Facet #40171 from Aircraft Spruce. THIS WAS FOR PREVENTATIVE maintenance only, using the Original one (added connectors) as a backup. Started right up....yeah!
Here is the install pic's:
I wanted to mount the pump with the tangs facing the bottom of the battery but it is TOO DEEP this way and keeps the Bash plate from closing, So had to rotate it 90 degrees and it now closes.
Thanks for ALL those who shared their experiences with this for it was extremely valuable.
Happy New Year to All.....
OK, I order a 40171 today with filter, and I was looking over installation ideas. {Preventive maintenance on a 26k miles bike.} I remembered this post from many months ago. I initially thought that it showed the pressure line running up the exhaust side of the bike. See the filter over there? But that line looks to be the cross-over line. I don't get it.
Anyone tried to run the gas pressure line going to the carbs by routing it up the exhaust side? Is the answer, "No, because only a dumb@~~ would run the pressure line by the hot exhaust"? It just seems it would be easier to run the pressure line out and up rather than circling it back. And, it might get the gas line coming out of the airbox off of the oil pressure sensor, which I invariably knock off just about every time I mess with the carbs.
Thoughts 'preciated.
Orangecicle is offline   Reply With Quote
Old 11-26-2010, 08:13 PM   #350
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Orange,
Here is the Left Side Fuel filter (Red Arrow) that was not too clear on the other picture that shown the Right Side one:
Hope this helps....
AdvGa is offline   Reply With Quote
Old 11-27-2010, 03:20 AM   #351
Orangecicle
On a "Quest"
Oddometer: 2,922
Orange,
Hope this helps....
Well . . . I'm still perplexed. Does your bike have the pretty much stock configuration of tank feed to fuel pump and then up the left (non-exhaust) side of the bike?
Old 11-27-2010, 07:38 AM   #352
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Orange,
Let me see if I can explain this...these pictures and hoses are confusing.
Mine is a Stock Configurations BUT with These Filters (2) each are installed between the Tank Feeds to the Facet Pump. This is to ensure all fuel is filtered before feeding the pump.
Then the Outlet Hose of the Facet Pump feeds the Other Hose that feeds the Carb's up through the frame.
Hope this clarifys and answered your question.
Old 11-28-2010, 04:14 PM   #353
sonoran
you already know
sonoran's Avatar
Oddometer: 24,573
I'm curious as to why folks are running 2 inline filters before the Facet? Is the one Facet filter not sufficient?
sonoran is offline   Reply With Quote
Old 11-28-2010, 04:23 PM   #354
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
Originally Posted by sonoran
I'm curious as to why folks are running 2 inline filters before the Facet ...
one from each tank im sure
Old 11-28-2010, 06:56 PM   #355
sonoran
you already know
sonoran's Avatar
Oddometer: 24,573
Yeah but the facet is fed from the left tank. Only half of the fuel would be filtered twice.
Old 11-28-2010, 07:52 PM   #356
triplenickel
triplenickel's Avatar
Oddometer: 2,428
The pump only has one inlet.
07 SE
PG007
Old 11-28-2010, 09:09 PM   #357
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 412
No Problems
Originally Posted by DockingPilot
I'm about to switch over from the earlier Facet (I forget the #).
Question: Hows the 40171 treating you ? Any flooding or hydro locking issues with the petcocks left open with this one ?
Pleased to report that I have had no problems after 18K miles.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 11-29-2010, 08:14 AM   #358
StmbtDave
AKA Invisible Dave
StmbtDave's Avatar
Location: Loveland, CO summer - Green Valley, AZ winter
Oddometer: 3,026
I installed a 4071 to replace the stock pump. During the installation I turned the key on & off a number of times, without starting, to check the pump connections. When the time came to start the bike, the bike let out a horrible ratchet like sound. I pulled both spark plugs, hit the starter, and fuel came gushing out of the front cylinder. Evidently, the multiple bumping of the fuel pump flooded the carb which in turn hydro locked the engine.
I just didn't feel I could trust the 40171 so I did the solid state conversion to the stock pump and put it back on the bike. I'll keep the 40171 as a backup.
Dave
Why are we stopping? We don't have time for that!
StmbtDave is offline   Reply With Quote
Old 11-29-2010, 09:01 AM   #359
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Dave,
Sorry to hear about this unusual experience. Most likely a malfunctioning pump. Would not trust it even as a backup with these symptoms. Probably a Bad Check Valve.
If you got it from Spruce Aircraft, call them at 800-861-3192 and sure they will exchange it for you.
Old 11-29-2010, 09:30 AM   #360
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
Originally Posted by StmbtDave
I just didn't feel I could trust the 40171 ...
Dave
The 40171 puts out Too Much Fuel Pressure IMHO reguardless of the checkvalve
Times are GMT -7.   It's 02:49 AM.
