Old 09-30-2011, 07:47 PM   #451
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by booger1 View Post
... I don't see any room to mount a 2nd unless adding another gallon of fuel lines...
Just keep it as a Spare... I added the same Wire Connectors to the Old One that matched the New One so it can be swapped out if needed.
Failing parts of any kind, unfortunately, don't make appointments when they go out.
AdvGa is offline   Reply With Quote
Old 10-06-2011, 05:54 PM   #452
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,502
So I've been running the Facet pump for a few thousand miles now. Running into a problem. Seems like the bike turns real rich/floods when I hit a hard bump now. Bike can stall, or run on one cylinder until I rev it up to clear its throat. Then its fine. Can be fine to the rest of the tank.
I got it to happen repeatedly on my backyard trials course. The skidplate hits a rock every lap, heading downhill, and the engine stalls.
Anyone running a pressure regulator? Or are my floats just plain set too high/rich?
I have the Facet pump with the check valve in it, whichever model that is.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 10-06-2011, 06:09 PM   #453
AdvGa
AdvGa's Avatar
Oddometer: 1,320
[QUOTE=UngaWunga;17018209]... Or are my floats just plain set too high/rich? (My Bet)
I have the Facet pump with the check valve in it, whichever model that is. (40171 has Check Valve- 40105 does not)[/QUOTE]
My thoughts..
Old 10-06-2011, 08:35 PM   #454
horizon seeker
Oddometer: 33
My feelings on the facet 171 is that it's very suseptable to trash in the fuel. The filter is an important part and should be replaced at least every 10k. I always carry a spare pump and filter. Doesn't take long to change out. Performance has always been great.
06 950 ktm
01 650 klr
77 r75/7 bmw
horizon seeker is offline   Reply With Quote
Old 10-07-2011, 10:46 AM   #455
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,502
I'm running a filter before the pump. Would be dumb not to.
What's the stock float height? Recommendations for leaning it out a little?
Old 10-07-2011, 11:26 AM   #456
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by UngaWunga View Post
I'm running a filter before the pump. Would be dumb not to. (Most Definitely)
When I measured mine, they were 2.2 - 2.7mm but there is no consistancy, Head2Wind suggests 3 - 3.5mm I believe.
Higher the number means Less Fuel/Leaner.
Old 10-07-2011, 11:33 AM   #457
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,502
okay thanks. I set them to 3mm last time I was in there. I'll try a little higher.
Old 10-07-2011, 12:18 PM   #458
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,862
I had a similar flooding problem, but probably worse than yours. It would try to flood out if I didn't hit the starter button as soon as I turned on the key. I tried resetting the float height, but the bike didn't like it, so I installed a Mr. Gasket fuel pressure regulator.
Blingity-blang:
Set to 1.5 psi, problem solved for about $40 including all the fittings. I wish it weren't chrome plated, though.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 10-11-2011, 04:35 PM   #459
zedtours
zedtours's Avatar
Oddometer: 361
Originally Posted by Balsta View Post
..after 12 500 miles (20 000 km) only.
Good filter and no dirt in fuel.
The pump makes a funny noice and I believe its a mechanical failure.
For comparison, the original last 18 000 miles (29 000 km).
Am I the first with a damaged 40171? Can't be
Mine was the same about 15000 miles
zedtours is offline   Reply With Quote
Old 11-18-2011, 03:57 PM   #460
southernADV
southernADV's Avatar
Oddometer: 112
Question Help please!!!!!!
i installed my new Facet but when i turn the key it not start,so i tryed it directly to the battery and it starts,so i think the bike is not sending power to the pump,the fuse is OK and when i took off the mitsubishi all was ok!!Now im FRIED!!!!!!!!!!!!!!
HELP PLEASE
Never enough.......
southernADV is offline   Reply With Quote
Old 11-18-2011, 04:10 PM   #461
renogeorge
Oddometer: 1,367
I would be checking the connections to the new pump. Ground and hot reversed? Not much else that can go wrong.
Good luck
renogeorge is offline   Reply With Quote
Old 11-18-2011, 04:16 PM   #462
AdvGa
AdvGa's Avatar
Oddometer: 1,320
1- Make sure your Crimps or Wire Connections are Tight
2- Make sure you Electrical Polarity is Correct on Not Reversed (Its tricky)
3- Make sure your Relay has Tight/Clean Connection:
http://www.advrider.com/forums/showp...9&postcount=34
4- Possible Faulty Aux Fuel Pump Relay as seen here on the Right Arrow:
http://www.advrider.com/forums/showp...11&postcount=7
Which is the same Part as the Aux Start Relay on Left Red Arrow.
Good Luck...
Old 11-18-2011, 04:54 PM   #463
southernADV
Oddometer: 112
If brown is positive the conections are OK because i tried again in the battery with the BROWN wire of the pump in battery positive and it works ok...im confused because the old pump was workink perfectly and the bike dont run since that...
Never enough.......
Old 11-18-2011, 05:06 PM   #464
southernADV
Oddometer: 112
Ohhhhh WRONG i connected the wires wrong because blue is Positive...
I will re-connect the WIRES in the right form and try...
Thanks and sorry..
Never enough.......
Old 11-18-2011, 05:58 PM   #465
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Don't feel Bad 'cause I did it too and still get confused... this Bike has some Odd Wire Color Schemes.
Times are GMT -7.   It's 05:03 AM.
