12-14-2011, 06:58 PM
#466 | |
Mosquito bait
Oddometer: 5,497
So finally got them set to 3.2mm and tried it around the yard. Same problem. Engine cuts out when hitting a small bump. Fires right back up, runs great, power seems fine, doesn't smell rich. Fuck it. Going back to the stock fuel pump. I'll carry around some spare point. Didn't have these problems before the switch to the Facet pump.
"There isn't any secret," he said. "It's all very obvious." |
12-14-2011, 08:05 PM
#467 |
Sand seeker
Oddometer: 1,104
Dr Bean has some new kits made up. Got one coming.....
Everybody's on the run |
12-14-2011, 08:58 PM
#468 |
el semental negro
Oddometer: 228
Please dont flame me, but why not go with OEM pump and carry spare. If it fails out on trail, swap with spare. Upon returning home rebuild broken pump with new points. If on extended trip, carry spare pump and new points. It wont take that much room, and you know it will work.
12-15-2011, 05:40 PM
#469 | |
Gas Passer
Oddometer: 320
Pump
"When a man cannot choose, he ceases to be a man." JB |
12-15-2011, 07:04 PM
#470 |
AKA Invisible Dave
Oddometer: 2,466
I carry a spare Facet and filter under the seat, wired, plumbed, and ready to go. I think it was $65 and packs much smaller than the stock pump. You don't have the option of a rebuild if it goes bad but life if full of trade-offs.
Dave
Why are we stopping? We don't have time for that! http://share.findmespot.com/shared/f...8pP8skl622N3ri |
12-16-2011, 07:36 AM
#471 |
Oddometer: 315
40171 Failures?
I have been watching this thread intermittently. Are there really that many documented 40171 failures out there?
I have run one on my SM for 20k miles with no issues. I have also run these pumps successfully on dune buggies with no problems. Nothing is 100% foolproof. I am a little skeptical that a faulty pump is causing a stumble. Full float bowls should carry you over momentary disruptions in fuel deliveries to the carbs. Other problem......float level, electrical?? I am not religous about the Facet. But I have found them to be affordable and dependable. Having said that, I would probably try a vacuum pump if reworking.....Just because I like to tinker FWIW |
02-01-2012, 08:58 PM
#472 |
AKA Invisible Dave
Oddometer: 2,466
Another One Bites The Dust
The 950 left me stranded today. It started stumbling as if running out of fuel. The engine would crank, crank, crank but no fire. I pushed it to a nearby gas station and topped up the tanks thinking I could get a gravity feed. Still no fire. Moved it over to the parking lot and started checking. Dropped the skid plate, put one hand on the Facet and turned the key. It hummed as I thought it should. Pulled the hose from the output side of the pump and turned it on. Pump hummed but no fuel coming out. I do carry a spare pump under my seat (see post 2 up from here) so I pulled out the old and installed the new, leaving off the output hose. Quickly turned the pump on and off and a big yellow wad, like blowing your nose with a head cold, came flying out. Turned on the pump again and beautiful clear fuel was flowing
. Reassembled everything and was back on the road in maybe 20 mins total. Tomorrow's project is check out the old pump to see if it's salvageable. If not, I'll have to order another spare for under the seat.Because of the yellow wad, I can't say this was a pump failure. I have filters on both the input and output side of the pump so if it was contaminated gas I don't know why the filter didn't stop it. Dave
02-01-2012, 09:21 PM
#473 | |
Oddometer: 1,320
02-01-2012, 10:31 PM
#474 | |
Don't mean sheeit. .
Oddometer: 2,549
Zak ktm old bmw others |
02-02-2012, 12:11 PM
#475 | |
AKA Invisible Dave
Oddometer: 2,466
Dave
02-02-2012, 12:23 PM
#476 | |
Oddometer: 1,320
02-02-2012, 06:36 PM
#477 | |
Unregistered Gun Owner
Oddometer: 1,324
It is interesting that after 5-years, folks still seem to be doubting the Facet reliability. I have a spare under my seat for longer trips. The KTM factory Dakar mechanics I worked with in Baja told me long ago that the stock pump was shite, and didn't work. If I didn't aleady have the facet, I'd use the Mikuni vacuum model. Pointman, 40K miles on the 40701, still pumping!
AMA Life Member 600475 IBA #5 More Cowbell! |
02-02-2012, 06:56 PM
#478 |
Oddometer: 315
40171 Problem--What problem?
I am with Pointman on this. I have nothing to gain from supporting the Facet 40171. I know mine has worked flawlessly for 15k miles. Nice to see a well thought out analysis of a problem by Stmbt Dave. In more typical internet fashion, it would have been easy to blame the pump and create a feeding frenzie. If there is a better option to the Facet, I am all ears. But I haven't heard it yet, although the vacuum pump is something I would like to try--if I had any reason to do so.
As said earlier, I have used Facets on dune buggies before my 950, with great results--hanging down in a fenderwell or other "unprotected spots". FWIW |
02-02-2012, 07:30 PM
#479 | |
Oddometer: 1,320
This is why I/we discussed many times the positives of using http://www.toptiergas.com/retailers.html Fuels... this mitigates these possibilities. I don't think just using a Vacuum pump would bypass these issues. |
02-02-2012, 07:44 PM
#480 |
Oddometer: 315
I never meant to suggest that a vacuum pump would help with Ethanol problems. I ride a 950 SM with 30k miles on it. My territory is CA, NV, WA, OR, ID, MT, UT. AZ, CO. I am not picky about which stations I use. Never had a fuel problem that I know of, except for varnishing of fuel in dirt bikes that sit for extended periods with gas turned off. Maybe I'm just lucky......
