Old 02-02-2012, 08:04 PM   #481
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by renogeorge View Post
I never meant to suggest that a vacuum pump would help with Ethanol problems. ....
No problem.
Here is what a Facet Engineer said to me when I talked with him:
"Install Outlet End Above Inlet by abt 30 degrees Recommends 74 Micron Filter (Not 10-15 Micron - Too Fine/Restrictive)"
Unfortunately, most of the Filters you find at Auto Parts stores, aren't even marked with these numbers... even the ones that do come from places not doing well with quality and would be hard pressed to prove they even do filter what is stated.
AdvGa is offline   Reply With Quote
Old 02-02-2012, 08:14 PM   #482
renogeorge
Oddometer: 1,392
Filters?
So are you suggesting that the "yellow blob" problem may be attributed to ethanol and that a less dense filter may pass the blob? Sounds like it could work that way..... I don't know the micron rating of my filter. It is an off the shelf auto parts store deal--nothing special.
renogeorge is offline   Reply With Quote
Old 02-02-2012, 09:35 PM   #483
AdvGa
AdvGa's Avatar
Oddometer: 1,320
So are you suggesting that the "yellow blob" problem may be attributed to ethanol and that a less dense filter may pass the blob? ....
Ethanol acts like and is a Solvent and for example, could/does disolve some finishes/resins off the Storage Tanks/Lines etc, into a suspended liquid form that is small enough to pass through the Filter Media. Then when conditions exist, these fine particle suspended in solution then coagulate or precipitate out of solution making the above mentioned residues, including the Yellowish Residues we have seen in Carb/Throttle Body Pictures.
This could be more likely to happen when a New Storage System is put in place as required to be replaced every so many years by the EPA, I believe.
As far as the Fuel Filters, I don't trust the stuff in Auto Parts Stores if they are not marked properly just what they are supposed to do (if anything at all).
So I am using these these Glass Fuel Filters a trial, especially with all the Funky Gas w/Ethanol, would be easier to see if there are any problems. Those obscure metal ones made me feel uncomfortable:
So far with a few thousands of miles they are working well and the replaceable media is just slightly more tan in color.
Old 02-03-2012, 06:28 AM   #484
renogeorge
Oddometer: 1,392
Ethanol
Good info. Thanks
Old 03-11-2012, 07:15 PM   #485
Ohno
moto-pirate
Ohno's Avatar
Oddometer: 294
Brand new Facet not working
Installed a 40171 that I had sitting on the self for a year and a half. Everything went smoothly until we tried to fire up the engine. Nothing. The pump is making clicking noises but you almost have to put your ear up to it to hear it. Is that normal? What's the preferred method of testing the pump?
"It's better to be a pirate than to join the Navy."
1971 Triumph Bonneville
1974 Yamaha DT175
1971 Honda CL350
1972 Honda CL350
1982 Kawasaki GPz 550
1983 Kawasaki GPz 550
1993 Honda XR100
1992 Honda XR250L
1993 Honda XR250L
1997 BMW F650 Funduro
2004 KTM 950
www.teamboxer.com
www.ohnodesign.com
Ohno is offline   Reply With Quote
Old 03-11-2012, 07:38 PM   #486
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here's a couple of things to check:
1- Are all your Petcocks Open
2- Do you have the Facet Pump Plumbed in the Right Direction
3- Is is wired properly
http://www.advrider.com/forums/showpost.php?p=15245091
http://www.advrider.com/forums/showp...&postcount=389
Old 03-11-2012, 07:44 PM   #487
Ohno
moto-pirate
Ohno's Avatar
Oddometer: 294
Triple checked
We went over everything multiple times but nothing. We took the pump off and directly attached to a battery and only got a very low clicking noise. No vibration coming from the pump at all.
1974 Yamaha DT175
1971 Honda CL350
1972 Honda CL350
1993 Honda XR100
1992 Honda XR250L
1993 Honda XR250L
2004 KTM 950
www.teamboxer.com
www.ohnodesign.com
Old 03-11-2012, 07:59 PM   #488
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,122
This seems a bit too obvious, but I'll throw it out there: is it pumping gas? check by draining the float bowls or disconnecting a fuel line between pump and carbs and holding it in a jar while you turn the key. The facet is quieter than the stock pump. You're better off diagnosing by how much gas it's pumping vs. how noisy it is.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 03-31-2012, 06:45 PM   #489
1coolbanana
1coolbanana's Avatar
Oddometer: 1,446
Hi all
New the KTM clan, just having bought a nice 2004 950 Adventure.
What a hoot, very impressed so far.
When I bought it, the bloke had already installed a Facet pump, so I assumed it would be the 40171 as seems to be the norm.
Well after pulling everything apart, I found that its a Facet Posi-Flo 60104.
Its plastic bodied and rated at 1.5-4 psi.
Should I get rid of it and replace with the 40171 or is it ok?
What worries me the most is the spec sheet rate it as only for use up to 60 degrees C
It works fine but does make some loud rattling noises sometimes after restart after she gets real hot, maybe vapor lock and running dry for a few seconds????
Rest of the time seems fine.
Cheers and thanks for any advice
Tidied it all up and rerouted the lines but paranoid about whether I should change it out for the 40171???
1coolbanana screwed with this post 04-01-2012 at 02:22 AM
1coolbanana is offline   Reply With Quote
Old 04-02-2012, 12:34 AM   #490
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
I think the hose on the right side on the last photo is a bit sharp.
I didn't see a fuel filter. Check valve included. The only thing would worry me is this 60C limitation. If it has been proven, you are good to go.
My 0.02
Cheers.
Old 04-02-2012, 12:43 AM   #491
1coolbanana
Oddometer: 1,446
My 0.02
Cheers.
Hi and thanks for the reply.
Yeah, the outlet is sharper than I like.
I want to add a 45 degree brass elbow to that side.
The inlet side has the standard metal filters supplied with Facets, same filter as the 40171 by the look of it.
I think the 40171 is rated at about 75C but not sure.
Id happily change it if this one is not suitable, just dont want to spend the money if its not needed.
Cheers
Old 07-01-2012, 11:03 PM   #492
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
My Facet 40105 died yestereday.
I post it here as I believe it is the same pump in its basic construction. Served me flawlessly since installation in 2007 for 60k kms. Died yesterday and an updated used OEM with Dr Bean kit replaced it. Let it be remembered...
Old 10-24-2012, 11:03 PM   #493
mongboy68
mongboy68's Avatar
Oddometer: 10
Originally Posted by Stobie View Post
I had a similar flooding problem, but probably worse than yours. It would try to flood out if I didn't hit the starter button as soon as I turned on the key. I tried resetting the float height, but the bike didn't like it, so I installed a Mr. Gasket fuel pressure regulator.
Blingity-blang:
Set to 1.5 psi, problem solved for about $40 including all the fittings. I wish it weren't chrome plated, though.
i had exact same trouble fitted regulator as ur pic and prob solved thanks
mongboy68 is offline   Reply With Quote
Old 10-25-2012, 06:23 AM   #494
mattc
mattc's Avatar
Oddometer: 451
I recently Removed my Facet 40171 because from the start, it allowed fuel to bleed through and into the carbs, causing hard starts and tons of white smoke from unburned fuel. This was after sitting for a couple hours or overnight.
I used Dr. Bean's kit on the stock fuel pump and so far so good.
mattc is online now   Reply With Quote
Old 10-25-2012, 07:04 AM   #495
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,882
I had my facet die on me in the middle of nowhere on a recent trip to Morocco, luckily I was carrying a spare one the facet had only been fitted for approximately 18 months .
First time I've heard of the Dr. Bean thingy. Can anyone point me in the direction so I can find more info please.
Cheers
DG
DeeGee is offline   Reply With Quote
Times are GMT -7.   It's 05:25 PM.
