Old 10-25-2012, 09:45 AM   #496
mookymoo
Mookish Mook
Oddometer: 4,289
Originally Posted by DeeGee View Post
I had my facet die on me in the middle of nowhere on a recent trip to Morocco, luckily I was carrying a spare one the facet had only been fitted for approximately 18 months .
First time I've heard of the Dr. Bean thingy. Can anyone point me in the direction so I can find more info please.
Cheers
DG
Any details on the failure Gav?
Corrosion?
Electrical failure?
Seized?
mookymoo is offline   Reply With Quote
Old 10-25-2012, 09:54 AM   #497
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,767
Corrosion?
Electrical failure?
Seized?
Afraid not Nick, symptoms were the usual spluttering to a halt. Bike would turn over but not fire. When I turned the key the usual clicking sound of the pump priming was replaced with a whirring sound. I took the fuel (outlet) line off and turned the key and no fuel came out. Like I say luckily I had a spare one with me and replaced it within half hour.
In hindsight I should've brought it home and sent it to guys at parts for aircraft where I bought it from to see if they could shed any light on why it failed.
Sadly it's somewhere in the Cedar Forest!!
DeeGee is offline   Reply With Quote
Old 10-25-2012, 11:30 AM   #498
mattc
mattc's Avatar
Oddometer: 404
http://www.advrider.com/forums/showthread.php?t=823347
There you are.
2008 950 SE-R
2000 XR650R
2001 CR250R
1983 ATC200E
mattc is offline   Reply With Quote
Old 11-27-2012, 01:07 PM   #499
Pointman0853
Unregistered Gun Owner
Pointman0853's Avatar
Oddometer: 1,326
Facet Update...
20k plus miles on my 40171, no issues. I carry a spare while on long trips.
YRMV...
Pointman
AMA Life Member 600475
IBA #5
More Cowbell!
Pointman0853 is offline   Reply With Quote
Old 11-27-2012, 05:23 PM   #500
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,867
I'm at about 50,000 miles on my 40171. Still working well at the end of this season.
I think the biggest thing is to check and clean filters. If you install a FACET filter (I don't, I use a cleanable Pingle, or cheap large plastic moto filter) or any other filter on the INLET SIDE, clean or replace it every 10,000 miles when you do a valve check. I think that running the tank dry, (running the pump dry) or starving for gas over a long period of time can do damage.
Remember, these are Airplane pumps, I'm pretty sure they are not designed to run Dry.
The current one in my bike I'll put another 10,000 miles on it and see how it lasts. Then swap in a new one before my next trip out west. That figures out to a whopping $.001 per mile. If I was just running around town all the time. I'd keep it in until it fails, but not when I travel off road. I prefer to swap out parts before they strand me.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer screwed with this post 11-27-2012 at 06:15 PM
cjracer is offline   Reply With Quote
Old 11-27-2012, 05:43 PM   #501
AdvGa
AdvGa's Avatar
Oddometer: 1,320
The Facet Pump's INLET Fuel source needs to be Filtered to protect the Pump Mechanism from damage.
When I talked with the Facet Engineer,
he suggested a 74 Micron Fuel Filter but Most, if not all Filters, are NOT marked with its filtering capacity.
The problem with most Fuel Filters in Stores are Opaque and Do Not have their Filtration Specs listed.
I found these Glass ones where you can see inside and they have been doing well for years:
http://www.bikebandit.com/biker-s-ch...r-fittings-kit
AdvGa is offline   Reply With Quote
Old 11-28-2012, 06:01 PM   #502
mattc
mattc's Avatar
Oddometer: 404
Mine let fuel leak thru while sitting, and would flood the engine.
Did a Dr. Bean kit on my stock pump. All better, no rigging some junk into place that doesn't belong. MUCH better!
2008 950 SE-R
2000 XR650R
2001 CR250R
1983 ATC200E
Old 11-28-2012, 07:41 PM   #503
triplenickel
triplenickel's Avatar
Oddometer: 2,263
No contradiction here!
07 SE
PG007
Old 11-28-2012, 07:55 PM   #504
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 270
I've used the facet pumps on buggies since the 80's there is a small screen in many of the pumps that I've had clog up.
I used to use thermal epoxy to put a 1" AL heat sink on the big transistor on top and one on each side to help keep them cool. (They need a little ventilation... not a bunch but some.)
I've literally put a hundred thousand miles on them on multiple vehicles.
Cheers
Dave
pdxmotorhead is offline   Reply With Quote
Old 11-29-2012, 01:16 AM   #505
superhak31
Oddometer: 56
Had a Carter and i neglected to put a pre filter inline = FAIL. Replaced with facet 40171 w/prefilter. Better pressure ratio and it works great. No fuel hydro locking like the carter/napa. 06' 950 adv/blk
superhak31 is offline   Reply With Quote
Old 11-29-2012, 05:13 PM   #506
mattc
mattc's Avatar
Oddometer: 404
Well, I look at it as a better of two solutions. One works fine for me without having some janky shit rigged up. The other works, but not as it is supposed to, and has to be "customized" into place.
2008 950 SE-R
2000 XR650R
2001 CR250R
1983 ATC200E
Old 11-29-2012, 05:57 PM   #507
triplenickel
Oddometer: 2,263
It's all good bud, just teasing.
07 SE
PG007
Old 12-03-2012, 01:32 PM   #508
mookymoo
Mookish Mook
Oddometer: 4,289
The eroding points are just one failure mode.
Many stock 950 pumps also seize (the piston corrodes/seizes). Mine failed this way the night before I was planning to swap it out. In some cases, a sharp whack on the pump will free the piston and have it work again (for a limited time, I guess) - which is how I got home that night.
Times are GMT -7.   It's 06:13 AM.
