Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 10-24-2009, 10:56 AM   #346
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 983
Neutral switch position
Hi there
I had to replace the fork seals (easiest forks I've ever done). To prop up the front end, I used 2 axel stands and a hydraulic floor jack. In the process I managed to dislodge the neutral switch. The problem is that I can't find the sucker. Anybody know where to look for the switch?
Bill
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 10-24-2009, 01:16 PM   #347
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,154
The neutral switch is on the back of the engine cant remember which side. Don't try to reattach it when the exhaust is hot. I have a scar now because of it.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Old 10-25-2009, 01:25 AM   #348
Bill the Bong
Supern00ba
Oddometer: 983
Thanks John
Found it and fixed!
Bill
Old 10-25-2009, 04:09 PM   #349
rockjohn
rockjohn's Avatar
Oddometer: 567
Hi all, I'm new to the Elefant family. I recently purchased a 94 900E and love it, I have a ? regarding the carbs, if I were to replace them what would I look for and were would I look. Bike has had most mods done already and runs strong but stumbles at the bottom or stalls.
rockjohn is offline   Reply With Quote
Old 10-25-2009, 07:43 PM   #350
RonS
Out there...
RonS's Avatar
Oddometer: 21,834
Keihn 39 mm FCR's. You can find them here along with a lot of other stuff for the elephant:
http://www.elefantadventurebikes.com...nt_carburetion
RonS is offline   Reply With Quote
Old 10-27-2009, 06:22 AM   #351
Tangai
Oddometer: 590
No doubt, the FCRs will make it run better, but you may only need to clean the stock carbs and check the diaphragms for holes. They are common Mikuni CV carbs and parts are easy to find.
Tangai is offline   Reply With Quote
Old 10-28-2009, 05:09 PM   #352
rockjohn
rockjohn's Avatar
Oddometer: 567
what's the up side in performance with FCRs.
Knuckle Dragging Silver Back
Free Your Mind...And Your Ass Will Follow
Old 10-29-2009, 08:53 AM   #353
Tangai
Oddometer: 590
You’ll have a little more power and a little quicker response. However, unless someone (the seller of the carbs) has worked out the jetting and installation process perfectly, it can be a lot of work to get everything working correctly. I’d rather convert the E-900 to EFI using parts from a crashed Gran Canyon or just leave it stock—as it runs great the way it is.
Tangai screwed with this post 12-04-2010 at 06:49 AM
Old 10-31-2009, 12:15 AM   #354
Bill the Bong
Supern00ba
Oddometer: 983
Hi everybody.
I've got another small niggle - 750LE. The idiot light works when I select the left side indicator (blinker), but not for the right side. The indicators works fine on the right side (F & R) and seems the same brightness. Does anybody know where the trigger signal for the idiot light comes from? I'm thinking of replacing the flasher unit as a matter of course.
Bill
Old 10-31-2009, 06:07 AM   #355
rockjohn
rockjohn's Avatar
Oddometer: 567
Tangai, nice bike. How do you like your wolfman bags, I need some bags would you recommend them.
Old 10-31-2009, 10:45 AM   #356
RonS
Out there...
RonS's Avatar
Oddometer: 21,834
Should have mentioned that there is an excellent site for the Elefant. The archive is an invaluable source of info and mailing list is very active:
http://www.elefantman.com/
Old 11-06-2009, 05:18 AM   #357
Bill the Bong
Supern00ba
Oddometer: 983
Bump
Still looking for info on this if anybody can help.
Bill
Originally Posted by Bill the Bong
Hi everybody.
Bill
Old 11-09-2009, 12:27 PM   #358
Samruay
ADV for ADV sake
Samruay's Avatar
Oddometer: 109
Hi Guys! I am new in this Community, however I'm riding "Elefants" since 1985 ...
Hereunder some videos to introduce my little 650 fant
http://www.youtube.com/user/EnduroOldSkool
Concerning the carbs upgrade:
Just putted few days ago the same question into another thread...
http://www.advrider.com/forums/showt...6#post11336856
Glad to see we definitely agree on the solution
Does anyone working on improving the Forks efficiency for intensive off-road use ?
Cheers,
SAM
Samruay screwed with this post 11-10-2009 at 04:01 AM
Samruay is offline   Reply With Quote
Old 11-09-2009, 10:28 PM   #359
«dmx_must_fly»
Elefant Rider
«dmx_must_fly»'s Avatar
Oddometer: 150
if you have the oem reg. on your bike then probably its nothing to worry about.
check the voltage at the battery to see if there is some thing wrong or just the idiot light circuit gone mad. that happens
the idiot light circuit is in the reg and it gets its readings from the coils
check all the connections of the charging circuit and mainly the fuses
Cheers
Yovav
Cagiva Elefant 750 Lucky Explorer 1994
Citroen C4 auto PK 2011 3 wheels too much but grate climate control
«dmx_must_fly» is offline   Reply With Quote
Old 11-10-2009, 05:22 AM   #360
Willis24
Willis24's Avatar
Oddometer: 335
SAM
Is that a Galassetti exhaust? I have emailed them several times with an inquiry for price and shipping of a system for my Gran Canyon... I guess they either do not speak english or do not ship international.
2000 Cagiva Gran Canyon
Willis24 is offline   Reply With Quote
Times are GMT -7.   It's 12:04 PM.
