Old 07-15-2012, 07:20 PM   #151
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,129
That's just plain awesome
Originally Posted by kayaker43 View Post
I live in Michigan, the 650 is fully legal, the 200 is marginal .
Here's a few more pics. Its an experiment that went extremely well. I wanted to see if a sub 200 lb bike was possible and everything about it far exceeded my expectations. The extreme lightness changes everything. The super torquey 218 stroker motor, long travel and trials tire combined with the light weight puts it in a whole different category. The BBR frame is acually pretty heavy so I'm building the second generation frame and will also refine the ergos at the same time. My hope is to offer frame kits to accept stock honda parts and the xr200 or crf230 engines. It weighs 183 lbs, no gas now and I'm shooting for 175 - 180 lbs with full size wheels, adult ergonomics and race quality suspension.
At 275 lbs I may have the lightest 650 around but the little XR is another 92 lbs lighter yet !!
A new category,.. super playbikes ?? Imagine a bike docile enough to learn on that can still spank a 450 in the woods
You can see the swingarm stretch, relocated footpegs and 3.5 lb custom pipe in this last picture.
No kidding.... what are the mfg's thinking... this is the type of trail bike I want, and I am sure would be cheaper than a KTM freeride.
Not to mention, if you are basing the engine on the honda 200/230... A CRAP ton of cheap fairly reliable Chinese motors will bolt right in
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 07-15-2012, 10:15 PM   #152
kayaker43
Oddometer: 13
Gronk, I'm pretty sure a stock 650r weighs more than 290? that's probably the dry weight and I can't find my notes but I thought it was 306 ish with all fluids and no gas. Everything contributes to the weight loss,.. lighter wheels, brakes, shock, swingarm, lighter headlight, etc,.. The missing airbox saves nearly 5 lbs and the missing shock linkage was another couple lbs. The better suspension makes a huge difference too, no swapping in the whoops and no shock fade.
Byron 555, the Freeride is not really very light and it has less suspension travel. There's another one called the Bergham R250 that is the same way. Hardly any lighter and less travel. They both have all the complication I don't want on the trail with fuel injection, e-start and water cooling. however they both validate the concept that less power is better if its the right kind of power. My little Powroll 218 stroker with torque cam is the friendliest, smoothest most ridable power I ever experienced. That was the biggest shocker, coming off a 650 I thought the 200 would be pretty lame but it will pull 6th gear in deep sand and hang right with a 450 in michigan trails. I may be using 80% of my power all the time but it still has more than I need! The 218 has about 30% more torque than stock and that feels like a lot more when you shed so much weight.
Building around the little XR motor means I can swap in many of the chinese clones as you pointed out but also the CRf230 engine with its e-start and available hop up parts. These old school engines may seem uninspiring but they respond well to hop ups and really wake up when installed in a radically lightened bike.
kayaker43 is offline   Reply With Quote
Old 10-24-2012, 11:26 AM   #153
Tachedoutoffroad
Mr. Parrish
Tachedoutoffroad's Avatar
Oddometer: 652
on a 500lb industrial digital scale
-2006 Husqvarna 610SM, no mirrors, new pipe, no bark busters, no passenger pegs, 3.2 gallons = 318lbs
-2007 Husqvarna 610TE, mirror, skid plate, no pegs, bark busters, small rack, 3.2 gallons = 325lbs
-2006 Yami WR450, plated, armored, bark busters, 3.4? gallons, Lighter tiny battery, GPS, small rack = 285lbs
-2009 Husky 450SMR, 2.2 gallons, no armor, mirrors= 283lbs
-1996 Honda XR400, armored, bark busters, no battery , 2.2 gallons, dirty = 280lbs
-2011 Huky 310TE, huge bark busters, skid plate, 2.1 gallons, GPS mounted, dirty = 264lbs
When I get time Ill throw a YZ426, DR200, and XR250 on there
I loved my 610s, but they felt every bit of the 60lbs more than teh 310. Was great above 30mph, but sucked in the woods and on top of me. 310 wont run 95mph down the interstate for an hour like the SM will.
'00 KTM 400EXC --plated!
'89 Honda Transalp
Sikorsky UH-60L
Support your local know-it-all gear guy and give your money to Brian at https://www.atomic-moto.com/
Tachedoutoffroad screwed with this post 10-24-2012 at 06:34 PM
Tachedoutoffroad is offline   Reply With Quote
Old 10-24-2012, 11:32 AM   #154
montesa_vr OP
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,902
Nice contribution Tached -- were those weights full tanks of gas?
montesa_vr is offline   Reply With Quote
Old 10-24-2012, 06:33 PM   #155
Tachedoutoffroad
Mr. Parrish
Oddometer: 652
Yes. Full of gas. Smallest was 310/ 400 probably 2.2. WR and 610 have 3.2ish. None were "big" tanks.
'89 Honda Transalp
Sikorsky UH-60L
Old 10-26-2012, 07:24 AM   #156
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Originally Posted by neepuk View Post
1998 DR650se Weighs in Today at 332 Lbs, Ready to ride with about 3 1/2 gallons of gas. Advertised at 324...
Suzuki now claims 377lbs full of gas for a stock DR650se,they usually dont add weight to their specs. The pre 96 DR was way heavier,I forget how much but they were even more of a tank.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 10-26-2012, 07:29 AM   #157
Foot dragger
singletracker
Oddometer: 12,863
Neat little 200,those footpegs being right down at the bottom of the frame work good in rocks/stumps and deep ruts? I would hate to turn my foot around backwards with those. Amazing its lighter then a 200KTM with that old school Honda engine,or even lighter then the newest trickest 2 stroke 125 made.
Old 10-26-2012, 09:27 AM   #158
pjturbo
Oddometer: 412
Back in 1982 I took a Suzuki RM125 chassis and put a Honday XR200 engine in it. With 1 gal. of gas it weighted 198 lb. It routinely got 100 mpg on PNW single track trails. The manfufactures haven't improved since then.
Phil
pjturbo is offline   Reply With Quote
Old 01-26-2013, 08:00 AM   #159
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,073
Cool thread. I think the bathroom scale method works well if you use a short 2x6 to distribute the weight of the bike on the scale and block up the other tire to same height.
TE630. Skid, barkbusters, windshield, gps, rack, no luggage, no fuel, no Givi = 340 lbs.
6.6 gal fuel and normal luggage load (bags,Givi,tools,etc) = 410 lbs.
47 rear wheel hp
The weight of the TCI Outback rack was almost exactly offset by the 14lb weight loss going to FMF exhaust.
Before Safari and FMF
Heading to camp on WRT
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB screwed with this post 01-26-2013 at 08:21 AM
DYNOBOB is offline   Reply With Quote
Old 01-26-2013, 08:20 AM   #160
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,313
that white tank looks much better than stock
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 01-27-2013, 06:09 AM   #161
tdvt
Oddometer: 217
The bike below is a modified BBR framed XR200 that used cr85 suspension and wheels. I laced up some full size trials wheels and extended the swingarm so its now the same size as an XR200 but it weighs just under 192 lbs full of gas or about 30 lbs less than the lightest 125 on the list. It has a Powroll stroker 218 motor, MX suspension and brakes and is street legal. It can embarass pretty much anything in the tight woods and with the 6 speed wide ratio trans will cruise 55 without stress. I think its the best bike Honda never built. Ironicly its 95% stock Honda parts bolted to a custom frame, something Honda could have easily done.
This bike need it's own thread!
The low tech/ low weight concept makes total sense to me. I'd much rather have something along these lines than something with a on-the edge motor, water-cooled, etc.& all the extra junk that goes with it.
I'll be interested in your new, lighter frame.
Thanks for sharing this.
tdvt is offline   Reply With Quote
Old 01-27-2013, 06:15 AM   #162
JensEskildsen
Oddometer: 1,041
Yeah, that bike is way cool!
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 01-27-2013, 07:26 AM   #163
SRG
SRG
SRG's Avatar
Oddometer: 1,295
2010 Husaberg FX450. Sicass dualsport kit, tail bag w/ tools, FMF can, 2.25 gal. gas = 284#
Lazy Traveler
SRG is offline   Reply With Quote
Old 01-27-2013, 04:08 PM   #164
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,128
Wow that is an amazing looking bike kayaker! I run a small eco/tourist business in Malaysia. Deep in the jungle we have some of the most amazing secluded mountains, rivers and waterfalls. I've wanted to add those places to our itinerary but only the most hard core dirtbikers on 300 lb KLX250's (one of the ONLY common dirt bikes here) and long distance hikers can make it out there (without fainting from heat exhaustion!)
On a bike like this I bet it would open up places like that to a much larger group of folks! Ever heard of a KLX150? It's a street legal, but cheaper version of the trail KLX 140 in the US. (Both have 144cc engine). Heavier shock, cast swingarm and other parts it brings the weight to 250 lbs ready to ride with 9 rear wheel hp and poor suspension for a 95lb person. The good thing is they are uber reliable, cheap and everywhere now. BBR got a big bore/carb kit that can get it up to 14 rwhp and KX80/85/100 suspension bolts right on. I wonder if a guy like you could get the 250 lber down to 200 ready to ride?
rickypanecatyl is offline   Reply With Quote
Old 01-28-2013, 04:22 AM   #165
Krono
Speed Junkie
Oddometer: 193
About Honda CRF250L
Advertised at 144 kg, i weigthed it at 141 kg with the bathroom scale all wet.
As stock (euro model) it doesn't have the emission stuff, side reflectors and big plate support, that seems right with Ramz weighting (309 lbs), with 7.7 lt (2.06 gallons) http://rickramsey.net/CRF250Lmods.htm#weigh
To "un-weight" 10kg (22 lbs), I removed some unuseful things (still keeping it here legal), as ..
Chain guard, Helmet lock, Blinkers, Saddle strap, Right rear mirror, Passenger footpegs
.. and swapped heavy parts with lighters ..
Rear fender eliminator, UFO headlight plate, FMF exhaust line (w/ fuel controller & db killer), Alu sprocket (w/ speedo DRD), A123-4cells battery
Now it weights 131kg (289 lbs), bathroom scale controlled with 34.5 in seat height. Matter also where the weight is.
With added performance (and 1'300$ more to the bill), i'm pleased with the result for a daily driver + WE offroader
L
SM510R
Krono is offline   Reply With Quote
Times are GMT -7.   It's 04:12 PM.
