Old 06-08-2009, 11:26 PM   #121
fetid_swamp
fetid_swamp's Avatar
Oddometer: 745
FWIW a list was being put together on the austalian DBW.NET forums.
most were weighed by owners/riders using bathroom scales front and back.
interesting reading.
full tank unless noted otherwise.
SUZUKI
99rmx250 124kg
07drz400e - 129kg, incl case savers, bash plate, rad guards, led taillight, uhd tubes f&r, bar risers and pro tapers, tiny indicators, gps, egos. still has std header and exhaust & speedo, tank full.
07 drz 400e 137kg std incl whipps bash plate , B&B muffler insert, ego handguards, alli 7/8" bars & kick start kit
00Drz400e 139kg Standard
03 dr650 dead standard 155kg
KTM
07 KTM 250 EXC-F 122kg - full tank of fuel, bashplate, BB handgaurds
04ktm300EXC 113kg Gnarly pipe, bashplate,Ego handguards, MSC damper + triples
05 KTM 450 EXC - 126kg same as above
00Ktm 520 123kg
05 ktm 525 exc frame 450 sx donk, half a tank 127kgs
06 ktm625 SXC ~170 kg :Bashplate, damper, 18 litre tank & KTM comfort seat, rear luggage rack, UHD tubes x 3, Dunlop Rally Raid rear tyre 140
??ktm640 157kg stock tank, 167kg with big tank, dry 149kg
??KTM 950SE 198kg- brand new fully fuelled with handguards
??KTM 950SE 189kg Titanium/Carbon pipes and 17inch wheels.
HONDA
97 XR250 129Kg Includes barkbusters, bashplate,
08 crfx 250 with uhd's, bashplate only head and tail lights left from adr 112kgs
00xr400 131kg
??xr650R dry 132kg, stock 140kg, 27L tank 151kg
00xr650 141.5 kg
HUSKY
08 wr250 Husky 119kgs half a tank.
08 TE450 128kg fully wet
YAMAHA
00wr400 124.5
HUSABERG
00 501, 123.5kg
fetid_swamp is offline   Reply With Quote
Old 06-09-2009, 02:06 AM   #122
Kapp555
Better to be Offroad!
Kapp555's Avatar
Oddometer: 671
Great list and thanks for all your hard work. Makes a lot of difference to a guy like me who is shopping for a nice light used dual sport.
Kapp555 is offline   Reply With Quote
Old 06-09-2009, 12:08 PM   #123
Sycamore
d00b
Sycamore's Avatar
Oddometer: 1,697
The weight of my XR650R changes every hour, depending on how tired I am when I pick it up.
Sycamore is offline   Reply With Quote
Old 06-09-2009, 05:12 PM   #124
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,636
Originally Posted by Django Loco
I think it's fine to include them. But I would separate them into Vintage bike list. Where you draw the line is up to you. Young guys think bikes from the
late 80's are "vintage". For me, it's more like pre 1970. YMMV.
The Euro bikes are important .... well at least the adventure/dual sport ones we do not get in the USA.
The list is so long you have to search not read, so having it all lumped together doesn't really make it too much less useful. I'd dump it in to a spreadsheet with formulae to calculate with/without fuel, then you could also sort & filter to your heart's content. Hmmm, might even make it into a database-driven web page, I need a little sample project!
Bikes not available in the USA are useful to those of us who don't live in the USA. I understand it may not be at your fingertips, but if you have the data by all means publish it, please.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is online now   Reply With Quote
Old 06-10-2009, 05:05 PM   #125
fetid_swamp
Oddometer: 745
just a quick note to point out that the short list above are austalian bikes so unlike many in the us (dnt know about europe) the xr's and drze's are licenced usually with the big headlights and indicators and stiff from their roadgoing cousins...
Old 06-10-2009, 05:57 PM   #126
montesa_vr OP
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,904
Absolutely will do if the opportunity arises. I'm afraid Tenere fans will be devastated by reality if we get that thing on a scale.
montesa_vr is offline   Reply With Quote
Old 06-16-2009, 08:49 PM   #127
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,360
Originally Posted by montesa_vr
I presume the 525 and 530 are comparable to the 450 in weight.
Not sure about the 08 and up 450/530 but the older RFS bikes all weighed the same. On the same scale with the same fuel tank my wife's 2004 250 EXC-G weighed within 5lbs of my 2005 525 EXC. (250, 400, 450 and 525 weight differences are negligible for the intents and purposes of this information)
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 06-16-2009, 10:14 PM   #128
holycaveman
Oddometer: 14,387
You guys bench pressing these things or what
Banned for the truth.
holycaveman is offline   Reply With Quote
Old 06-17-2009, 02:03 AM   #129
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,636
Yep, every time we fall off!
Cheers,
Colin
The Stable
Old 06-17-2009, 05:43 AM   #130
achesley
Old Motorcyclist
achesley's Avatar
Oddometer: 3,471
So far, I have not taken my DR650SE any place I've not been on my 1250 Bandit. But, the loose gravel is way more easier and fun on the DR.
At my age and my hip problem, I'm not going to get into anything very technical anyways.
A '00 KLR 650 40,000 miles, A '07 1250S 74,000 , A '03 5.3L Chevy Truck 78,000 + '43 style dude , Simper Fi ;-)
achesley is offline   Reply With Quote
Old 12-08-2009, 11:30 AM   #131
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 773
bench pressing ?
Nah,more like a clean and jerk ? Only type of voluntary exercise I get !
pennswoodsed is offline   Reply With Quote
Old 12-08-2009, 03:23 PM   #132
col klink
the str8n'r
col klink's Avatar
Oddometer: 87
What do they really weigh?
Originally Posted by strongbad
I think more manufacturers are moving away from the "lie weights" and listing actual "dry weights". KTM's dry weights are real weights. Husky's advertised weights are accurate too, aren't they?
Kawasaki said the new KLR650 was 50 lb heavier than the old, but the main difference was a more accurate weight spec for new model. The same goes for the new 250 ninja which is 30 lbs "heavier", but I suspect the main difference will be a more truthful spec for the newer model.
The folks that are weighing their new Yamaha WR250x bikes are finding them close to the 280lb spec.
KLR 650's
Early version customer bikes, ready to ride w/half tanks or so of fuel, examples 2003 and 2005 weighed 391 lbs
my '08 similarly ready to ride weighs 451 lbs, the entire 60 lbs difference is on the front wheel. wow! I can feel it too when I ride them.
I still like my heavy KLR. It may weigh alot, but at least it doesn't make much power.
1972 R75/5 (col. Klink) That junk's old, but it's str8
2008 KLR685 w/Stage1 porting, Stock exhaust and intake,
GMDATL Alignment Correction (str8n'd the frame)
GMDATL spec/Racetech Goldvalve Emulators,
GMDATL spec/Racetech Shock Goldvalve, remote reservoir, compression adjuster and a 400# spring.
It's str8 now but it wasn't when it was new.
parabellum tall shield
www.gmdatl.com
Kent Soignier
col klink is offline   Reply With Quote
Old 12-08-2009, 06:38 PM   #133
montesa_vr OP
montesa_vr's Avatar
Oddometer: 1,904
Klink, you have distilled KLR ownership to its essence. I salute you.
Old 04-08-2010, 07:38 AM   #134
Highside>Lowside
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 1,076
Great list(s); thanks for doing the work to get them to us in different orders, as well. Anyone ever find the weight for the '95 KTM 620 RXC? I know the 620 Adventure is listed, but there is a lot of extra stuff hanging off of it, as well as an electric leg.
Highside>Lowside is offline   Reply With Quote
Old 04-08-2010, 11:01 AM   #135
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,581
I seem to recall 277lb ready to ride for the SC (which is for all intents a non DS RXC, non Estart model) was listed by KTM.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Times are GMT -7.   It's 07:26 PM.
