Old 03-03-2008, 03:59 AM   #1
RobinW OP
Oddometer: 6
lower conrod & main bearing failure on KTM 640 ADV -03?
What would make the lower conrod and main bearings have a failure in less than 15000km of highway use?
Bike is serviced according to specs and even had an extra oilchange and the auto decompressor fixed at 7500 km.
The -03 already had the upgraded roller bearings, so what happened?
RobinW is offline   Reply With Quote
Old 03-03-2008, 04:34 AM   #2
humdinger
bp
humdinger's Avatar
Oddometer: 616
1/ Revving the bejesus out of it in freezing temperatures before the engine reaches its optimum heat range.
2/ Got a lemon
3/ Viscosity of oil incompatible with climate temperature.
4/ Someone working on the bike fucked up big time
'05 640 Adventure
humdinger is offline   Reply With Quote
Old 03-03-2008, 05:14 AM   #3
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,975
5/ There is a rubber seal on the inside of the clutch cover for the crank end . If this dries up or is defective, you lose oil pressure and your lower end will suffer immensely.
The upgraded roller bearing you mention for '03-later has nothing to do with the crankshaft. That is a transmission main shaft bearing.
Sorry to hear about the problems. There is a ton of help on this board.
Good luck.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 03-03-2008, 05:47 AM   #4
gybeman
gybeman's Avatar
Oddometer: 632
Seeing as in 2003 onwards, your model also has an extra oil line lubing the same area, so something is definately wrong. Keep us posted.
gybeman is offline   Reply With Quote
Old 03-03-2008, 06:21 AM   #5
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,975
I thought the extra oil line was to squirt the bottom of the piston?
Old 03-03-2008, 06:37 AM   #6
gybeman
gybeman's Avatar
Oddometer: 632
Whatever, its still extra oil in the failed area that the earlier models didn't have.
Old 03-03-2008, 09:21 AM   #7
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,269
03 didn't get the extra oil line. I think it was in 04 or 05 that this benifit copied from the Rally bikes was put in.....
My thinking is that KTM reconized the need for more oil to the piston con-rod area to help prevent what happened to your 03 engine.....
I suffered a top end failure on my 03 as to where a chunk {probably piston ring debris} dropped into the clutch side crankshaft bearing and damaged it as well....
Possibilities for your failure..
Debris into the bearings
Or like others have said lack of lubrication due to a failed end seal, plugged oil line or oil pump failure.....
gunnerbuck is offline   Reply With Quote
Old 03-03-2008, 09:56 AM   #8
gybeman
gybeman's Avatar
Oddometer: 632
If you have a 2003 or newer Hi-Flow head, you have the additional line line as well. See the banjo bolt and oil line on the front of the engine ?
Old 03-03-2008, 11:01 AM   #9
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,269
I have an 03 with the High Flo head and it does not have this oil line.
However I can see the undrilled bung in the casting on my engine where they put it in on the later models and the Rally engines.
The engine in your picture also shows it with the SAS crap on the header which I believe also came in after 03 in some regions.....
gunnerbuck screwed with this post 03-03-2008 at 11:06 AM
Old 03-03-2008, 11:33 AM   #10
gybeman
gybeman's Avatar
Oddometer: 632
I stand corrected. I have a 2003 brochure and it shows it without the oil line. Seeing as it lived nicely without it for years its odd it needs it now with just 1 or 2 more hp from the hi-flo head. Don't know if the piston is that radically different from 2002-2003/2004.
Old 03-05-2008, 02:46 AM   #11
positionsize
positionsize's Avatar
Oddometer: 103
04's dont have it.
I have a High Flo 2004 Adventure and it does not have this oil line on the front of the motor. Bung only.
They must have introduced this line in 05'.
positionsize is offline   Reply With Quote
Old 12-28-2012, 09:59 AM   #12
electrician
kselectrician
electrician's Avatar
Oddometer: 10
Air Gap
If there is an air gap in the frame with oil, it will starve the crank bearing. This comes from an improper oil change, or if the bike sits for about 9 months the oil will sump down into crank case. Make sure you have banjo bolt #150 on the oil line from frame to engine. It is restricted to prevent sumping.
electrician is offline   Reply With Quote
Times are GMT -7.   It's 03:33 PM.
