03-04-2008, 01:08 AM
#1 |
A Few Loose Screws...
Universal RAM Mount - SPoT Tracker
If I don't find what will work well, I might just leave it in my tank bag, but I'd rather mount it.
Based on website pics and measurement, here's what I've found so far that might work. If anyone has had experience with any of these mounts, please speak up - whether it's been for the SPoT or some other gadget. None of the local stores have these "universal" type mounts on display to test fit. SPoT Dimensions: 2.75 x 4.38 x 1.5" ![]() CRADLE- Aqua Box II Weather Resistant- Medium Inside Dimensions: 2.86 x 5.75 x 1.2" I test-fit this one that a friend has for his iPod and it fits, but it's a tight squeeze (the top part is a flexible membrane that has enough give to accomodate the depth of the SPoT). The box seems pretty big and bulky, but it offers the advantage of quick removal by just opening the case. There's a Large version, but it seems way too big. ![]() CRADLE-UNI FingerGrip -PLASTIC MEDIUM Grip min 2.25/max 4" Arms min .75/max 1.5" Base 5 x 2.5" Looks kinda funky and the base is a bit longer than the unit, but if the arms are grippy enough it would stay put but could it be in there tight enough to not fall out and still be easily removable for extended stops/overnight without it being a hassle or wearing out the grip/tension on the arms? ![]() CRADLE-UNI QUICK RELEASE -PLASTIC SM Base to top edge 3.5" Rail Height 1.75" Min/Max Width 1.675/2/75" Looks like it might fit well enough, but with just the two side sliders compressing, is it enough to keep it from knocking loose? How easy is it to open/close the grip on the unit? CRADLE-UNI QUICK RELEASE -PLASTIC MEDIUM Base to top 3.875" Rail Height 0.875" Min/Max Width 2.25/3.5" This one looks better than the small, but the side rails are shorter and might not get as good a grip. Again, ease of opening/closing the grip? ![]() CRADLE-UNIVERSAL 2 Grip Min/Max 2.875/4" Arm Length Min/Max .5/2.25" Base Plate 4.5 x 3.0" This one doesn't have a bottom rail or base, but it has spring tension from one side to jam it up against the other side. Is it enough tension to hold it, and how hard would it be to remove it? ![]() Other than the universals, there are cradles that look like they might be close enough to work, but I can't tell from the pics. Any feedback on these (or other) units that will work to hold the SPoT in place GREATLY appreciated!
Rebecca Houston, TX '03 VStrom 1k "Wilbur" '98 XR400R "Templeton" |
03-04-2008, 05:04 AM
#2 |
n00b - Yeah, right
Oddometer: 609
This is so easy I don't even have to show you a picture
Anyone notice yet that the holes for the screws that attach the battery backplate are EXACTLY the distance apart as the mounting holes on a standard diamond shaped Ram mout.
I removed the two screws that hold the battery backplate in place and found longer screws that fit the threads (whatever they are). I added washers and, voila, custom mount. Yes the screws must be removed to change the batteries, just like the original design. |
03-04-2008, 05:23 AM
#3 | |
Satellites not acquired
Oddometer: 5,423
So simple I can't believe this is the first time this has been posted. I wonder how the case will hold up to abuse and vibration.
Cyclenutz.com motorcycle accessories Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5. |
03-04-2008, 06:13 AM
#4 | |
Adventure Sidecar
Why mount a piece of gear this compact that doesn't require your attention during the ride? I'd put it somewhere safe from the elements, vibration and theft. Somewhere within reach if I came off or left the bike for some reason.
the Red Menace "You are measured by how you ride by people who ride, and how you pose by people who pose." Alejo "Riders who get pissed off are doing it wrong." DAKEZ |
03-04-2008, 08:18 AM
#5 | |
Oddometer: 713
However, if you only plan to use the SPOT to send messages in case of emergency, then your suggestion would work just fine.
Suppose you were an idiot...And suppose you were a member of Congress...But I repeat myself. -Mark Twain |
03-04-2008, 08:20 AM
#6 |
Single Track Noob
Oddometer: 1,454
+1 RedMenace
I wonder why you would want to attach it to the bike as well. What if you and your bike get seporated? I keep my cell phone in my pocket for he same reason. It's hard to call for help if you come off the bike and can't get back to it.
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
03-04-2008, 08:27 AM
#7 |
Long Haul Adventurer
Oddometer: 3,181
Red,
You're thinking of the SPoT as a PLB and if it were being used for that purpose you're right on - keeping it on your person is the right thing to do. I think most of the folks around here are using the SPoT as a "Tracking" device though and therefore need to have it in a position where it has satellite reception all or most of the time they are riding. The GPS receiver in the SPoT is not a high-sensitivity receiver so it really needs a clear view of the sky to acquire and keep a GPS lock. BigX, As for mounting, maybe SPoTMaker can provide us with a bit more insight but I don't think the brass screw inserts that hold the plastic battery cover on are going to take the strain and vibration encountered by mounting it on a motorcycle for very long.
Cheers, Dan |
03-04-2008, 09:12 AM
#8 | |
Adventure Sidecar
Boy if I had the money, the communications array my get away from it all machine would sport (in addition to the camera booms and vid equipment already bolted all over the poor beast)
03-04-2008, 09:35 AM
#9 | |
Oddometer: 154
Squeaky - are you finding that you're not getting the performance you want when it's sitting inside your tankbag? Like you, I was at first very interested in finding a way to mount it to the bike, and even considered just velcroing it to the top of my topcase. But after I got the device and started playing with it, I found that the performance turned out to be just fine with the unit just sitting in a top pocket in my tankbag. After thinking about it, I figured that's even a better solution. It's hidden, more secure, less affected by vibration, protected from the elements, etc. I guess if someone wanted to be able to send OK messages while on the move, a RAM mount may be the way to go. But I now have the unit in tracking mode pretty much whenever the bike is moving, so I don't tend to use OK messages that often anyway. aciurczak screwed with this post 03-04-2008 at 09:40 AM |
03-04-2008, 09:49 AM
#10 |
Adventure Sidecar
Hmmm. Now you have me thinking. I wonder if they give a group discount for the units or the subscription service? Might be just the thing for keeping track of my back country tour groups...
03-04-2008, 09:59 AM
#11 |
Oddometer: 3,181
aciurczak
My experience with the SPoT has been that if I place the device on my person the body tends to block good GPS reception; as well as Satellite up-link. So having the SPoT in a Tankbag (cloth doesn't interfere with reception) or on a mount with a clear view of the sky is important for good performance. This is especially important in SPoT-Tracker mode since you won't get an up-link transmission until you have a good GPS lock.
Cheers, Dan |
03-04-2008, 10:10 AM
#12 | ||||
![]() Quote:
03-04-2008, 10:11 AM
#13 |
Oddometer: 154
DRTBYK - Agreed in full! Proper orientation seems to be key to getting good performance out of these. It's also clear that both the GPS downlink and the satphone uplink need to be functional for the unit to perform at all (though I think it does send satphone signals blind even without GPS lock in 911 mode). From what I've read here and seen by looking at the light patterns, all I'm saying is that the 3 most common modes of operation seem to be:
- GPS working, Satphone transmitter working - GPS working, Satphone transmitter not working - GPS not working, Satphone transmitter not working The 4th mode, with the GPS not working, but the Satphone transmitter actually able to get a signal out and received, seems to be a pretty rare case. Given equivalent conditions, it's easier for the device to get a GPS lock than it is to get a satphone signal out and successfully received. |
03-04-2008, 10:47 AM
#14 | |
Oddometer: 5,423
As far as he knows they are still in discussion with SPOT about a mount. Once they get a green light it can take anywhere from 45-75 days from design to distribution so it looks like they are still a ways out if they decide to make one.
03-04-2008, 03:33 PM
#15 |
n00b - Yeah, right
Oddometer: 609
Regarding testing...
I have NOT tested this under off-road conditions so if anybody uses it under those conditions YOU ARE THE TEST DUMMY
This is where the SPOT engineers scratch their heads and say, "Gee, who figured there'd actually be a bunch of guys out there who would push our design to the limits." |
