Old 05-03-2013, 07:08 AM   #8806
Rider_WV
Rider_WV's Avatar
Oddometer: 2,366
I have zero complaints out of my Wiseco basket, lifetime warranty too
Rider_WV is online now   Reply With Quote
Old 05-03-2013, 07:36 AM   #8807
Jimmy crack corn
Gnarly ST Devotee
Jimmy crack corn's Avatar
Oddometer: 87
Pissed pumpkin basket?
Originally Posted by IngoldWV View Post
My 97 Suzuki RM125 had that problem with the fingers on the basket. Replaced the basket once too (with OEM). I had put Barnett dirt digger plates in it when I put the new basket in, and that's when I figured out that the stock basket was pretty soft. I had begun to consider an aftermarket basket before I sold the bike.
There is no fluid loss or feel loss at the lever and it seems to function well except when hammered repeatedly. So... most of the time on the ST.
Will pull the clutch and check inner, outer and plates for scoring, groves and sharp edges.
http://www.ktm495.mxbikes.com/clutch/
One of many informative bits from a boogle search.
Seems straight forward enough and I have the service disk.
I sure hope everyone will get a chance to do some riding this weeee!kend. Looks like it'll be a beauty!
"But first... first you must travel a long and difficult road, a road fraught with peril. Mm-hmm. You shall see thangs, wonderful to tell. And, oh, so many startlements. I cannot tell you how long this road shall be, but fear not the obstacles in your path, for fate has vouchsafed your reward. Though the road may wind, yea, your hearts grow weary, still shall ye follow them." -The Blind Seer
Jimmy crack corn is offline   Reply With Quote
Old 05-03-2013, 07:39 AM   #8808
Jimmy crack corn
Gnarly ST Devotee
Oddometer: 87
Originally Posted by JTucker View Post
Depending on basket condition you may be able to file the fingers so it's not so bad. They're known for dragging anyhow, maybe just the nature of the hydraulic clutch? I wonder how well that Rekluse adjustable slave works, although i'd just put the whole auto clutch in at that point.
The Hinson baskets are really nice, if you want an auto go ahead and pop for the full setup with a new basket.
Thanks guys. Ill be happy enough to have it working better at this point.
Old 05-03-2013, 09:04 AM   #8809
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,866
Speedo is fixed on the EXC.
Anyone know the best place to get a front brake cylinder?
Screws are stuck in the top of this one, and I don't know how bad I'll fawk it up if I drill the top off of them.
WVhillbilly is offline   Reply With Quote
Old 05-03-2013, 09:24 AM   #8810
Rider_WV
Rider_WV's Avatar
Oddometer: 2,366
did you try the good old trick of putting the screw driver in the screw and smack the end of the screw driver with a dead blow to knock em loose? Its the dreaded steel bolt corroding in an aluminum housing. Smack it a few times it might pop loose.
Old 05-03-2013, 09:39 AM   #8811
WVdyhrd
mudhole 400 guy
WVdyhrd's Avatar
Oddometer: 2,545
I may know a guy
I've done the exact same thing and was able to just drilled the top off, they taper down in so just keep it dead center and go easy. Or try OnaXR's trick, take a small punch and see if you can bite the edge of one of groves and give it slight taps to encourage counterclockwise.
KTM 400 RXC & 01 955i Tiger, Cannondale HT Caffeine
"The fool doth think he is wise, but the wise man knows himself to be a fool." -Bill
Shakes
WVdyhrd is offline   Reply With Quote
Old 05-03-2013, 09:41 AM   #8812
WVdyhrd
mudhole 400 guy
WVdyhrd's Avatar
Oddometer: 2,545
Shakes
Old 05-03-2013, 11:19 AM   #8813
WVhillbilly
Oddometer: 10,866
Yea, I smacked the screwdriver more than a few times
Figured it would pop them loose right away, always works on the other junk here.
Old 05-03-2013, 12:43 PM   #8814
TheInfamousDrBholmes
TheInfamousDrBholmes's Avatar
Oddometer: 1,661
My granddad used to have a tool, I don't recall what the name of it was, but it was a screw driver that would hit with a hammer and when you would hit it, it would twist, it was like an impact screwdriver or something. I'm thinking it was something like this http://www.harborfreight.com/impact-...ase-37530.html
If that didn't work, I'd drill them out carefully and try to leave as much on there as you can. I have drilled them out before successfully.
If I were president the first thing I would do is sign an executive order to formally change the name of 'Welfare' to 'Farewell'
TheInfamousDrBholmes is offline   Reply With Quote
Old 05-03-2013, 12:51 PM   #8815
WVhillbilly
Oddometer: 10,866
I had one of those, it was the quickest and most efficient way to ruin the top of a screw I've ever seen.
I think it probably resides in the river somewhere behind my house now.
Probably worked great back when the screws and driver bits were made from good steel.
Old 05-03-2013, 12:54 PM   #8816
Oddometer: 1,661
hahaha! Trying to remember some other tricks. I hate those bolts just for the record. I'm thinking i'd just drill it. Maybe drill down in with a small bit in the center then a large bit to cut the head off, then use an easy out in the small hole you drilled first. or just use pliers if enough is left to grab ahold of. But removing the big screw head will reduce your static friction a good bit.
Old 05-03-2013, 01:08 PM   #8817
WVhillbilly
Oddometer: 10,866
1 50313001100 HANDBRAKE CYL. NAT. 1 214.79 191.16
$200
ouch
Old 05-03-2013, 01:22 PM   #8818
wvridgerider
wvridgerider's Avatar
Oddometer: 579
how much and how old? Pics?
CAAD 9 is a newer CDale, is made in USA?
wvridgerider is offline   Reply With Quote
Old 05-03-2013, 01:33 PM   #8819
JTucker
JTucker's Avatar
Oddometer: 2,270
$200
ouch
That's only $70 more than a Nissin master cylinder.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 05-03-2013, 01:34 PM   #8820
WVhillbilly
Oddometer: 10,866
I got new boots, I'll just drag my feet to stop.
Should work ok
Times are GMT -7.   It's 10:11 AM.
