Old 09-09-2013, 07:05 AM   #9451
IngoldWV
Dingo
IngoldWV's Avatar
Oddometer: 153
Originally Posted by bholmes View Post
Was that a threat or a promise Ingold?
Sent from my Nexus 4 using Tapatalk 2
Promise. I don't threaten.
Above all, be genuine.
IngoldWV is offline   Reply With Quote
Old 09-09-2013, 11:29 AM   #9452
IngoldWV
Dingo
IngoldWV's Avatar
Oddometer: 153
Originally Posted by JTucker View Post
They're supposed to do that, hell new ones setting on the showroom floor leak.
I think I might go for a ride on the WR tomorrow, haven't had it out in a while.
Think y'all are doing it wrong. Only time my 09 XCW leaked was after I cracked the sidecase. Probably from smacking it into a rock. Still runs like a charm. Other than changing that sidecase, I haven't cracked the motor open. I think I might inspect the top end this winter. Lol.
Old 09-09-2013, 03:38 PM   #9453
JTucker
JTucker's Avatar
Oddometer: 2,270
I've changed a few inner clutch cover gaskets, and we sell a lot of them. Maybe the small bike cover gasket seals better?
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 09-09-2013, 03:39 PM   #9454
JTucker
JTucker's Avatar
Oddometer: 2,270
[QUOTE=wvridgerider;22284542]
Ha, I'm glad I'm not the only one that does stuff like that![/QUOTE
When we riding again?
Maybe Sunday, I'll meet you anywhere on the creek.
Old 09-09-2013, 03:52 PM   #9455
Gabby
Oddometer: 443
The new Goldenseal magazine has an article on the old railroad on Blue Creek. I've ridden quite a bit of the old rail bed, but sometime I'd like to start at Hitop and retrace as much as possible.
Gabby is online now   Reply With Quote
Old 09-09-2013, 04:12 PM   #9456
tdrrally
tdrrally's Avatar
Oddometer: 3,330
that is the rail bed that runs through sanderson
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 09-09-2013, 05:57 PM   #9457
Rider_WV
Rider_WV's Avatar
Oddometer: 2,268
There are still several sketchy ass bridges you can ride across too!
Rider_WV is online now   Reply With Quote
Old 09-09-2013, 06:04 PM   #9458
tdrrally
tdrrally's Avatar
Oddometer: 3,330
those aren't bridges their termites holding hands
Old 09-09-2013, 06:05 PM   #9459
wvridgerider
wvridgerider's Avatar
Oddometer: 555
Damn where did you come from? Havent heard from you in a while.
wvridgerider is offline   Reply With Quote
Old 09-09-2013, 06:05 PM   #9460
wvridgerider
Oddometer: 555
Looks like we need a Summersville trip.
Old 09-09-2013, 06:07 PM   #9461
wvridgerider
Oddometer: 555
Had a close call out near Jerry's Run yesterday, crested a gravel hill and all that was in front of me was chrome grille. A semi with a low boy trailer, found a small area to get by.
Old 09-09-2013, 06:43 PM   #9462
Rider_WV
Rider_WV's Avatar
Oddometer: 2,268
Mainly been pedaling. Have about 800 miles on the CX bike so far, still trying to get my legs back.
Old 09-09-2013, 06:54 PM   #9463
TheInfamousDrBholmes
TheInfamousDrBholmes's Avatar
Oddometer: 1,617
Well I pulled the FD on the GS apart and the inner clutch case on the XC. Surprisingly the GS will be the cheaper fix provide I decide to buy gaskets for the XC rather than silicon. The FD looks good, just needs a new seal and I suppose I'll put a new o-ring on it while I'm in there, but the main output seal was the culprit. The XC... I don't know, I think I may just silicon it first and see how that goes. Truly gaskets are a band-aid for crappy tolerances when machining. I know almost, if not all, motorcycle manufactures use them for clutches etc. But when you split your case... what gasket is in the middle? None. Because it's machined properly, reason being other tolerances rely on it being machined correctly and you can't afford to have variances you would undoubtedly have if a gasket was used. Only gasket that should have to be used in an engine is the head gasket That's it in my book, the rest should be machined true enough to seal with a light coat of silicon. Anyhow... nuff of my rant... no manufacturer will ever meet my specs so no use in whining.
If I were president the first thing I would do is sign an executive order to formally change the name of 'Welfare' to 'Farewell'
TheInfamousDrBholmes is offline   Reply With Quote
Old 09-09-2013, 07:09 PM   #9464
wvridgerider
Oddometer: 555
I bought the Bianchi.
Old 09-09-2013, 07:12 PM   #9465
wvridgerider
Oddometer: 555
What kind did you get?
Times are GMT -7.   It's 08:19 AM.
