Old 03-05-2008, 11:20 AM   #1
Scary Mc OP
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
Bluhduh 17t Wont come off... WTF?
Is there a trick to getting the sprocket off the counter shaft? I've got everthing removed and out of the way but the sprocket won't budge.
I've tapped it with the 32mm socket and a hammer to unseat it, tried to gently pry it off, etc.
What am I doing wrong?
30 minute job my ass!
It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you shit your pants every now and then.
Scary Mc is offline   Reply With Quote
Old 03-05-2008, 11:50 AM   #2
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
time to put a 45 on the back and call it a day
MookieBlaylock is offline   Reply With Quote
Old 03-05-2008, 11:50 AM   #3
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,103
Sounds like it may be rusted on the shaft
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 03-05-2008, 11:51 AM   #4
Scary Mc OP
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
It's only got a 112 miles on it and I can't see any rust.
Old 03-05-2008, 12:00 PM   #5
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Something is totally fooked up then. The sprocket on my 03 slides on and off by hand without any effort. Maybe the Trolls in Mattighofen pounded the pooch and bugger'd the splines. Looks like your gonna have to, I hate to say this take it to the stealer and go through the warranty
Sorry
-cp
Old 03-05-2008, 12:07 PM   #6
Scary Mc OP
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
The Dealer, ugh. The spines look to be properly alligned on the shaft... anything is possible I suppose...
I've got a blow dryer strategically zip-tied and heating the assmbly up, we'll see what happens in a few minutes.
Old 03-05-2008, 12:19 PM   #7
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,422
Try to get a gear puller around it if there's room.
Otherwise maybe a slide hammer with a "L" shaped grabber on the end
may bugger up the gear though
good luck
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 03-05-2008, 12:21 PM   #8
ABYSS
KTM
Oddometer: 1,198
Something To Try
I had this happen on a WR 450 once I put the chain back on the front and then put the bike in neutral. Next I had a friend push and pull the chain to rotate it back and forth while I got a large socket and dead blow hammer tapped the sprocket while it was moving. After about three hits it slid right off. i just ended up being real dry in the center and was stuck.
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 03-05-2008, 12:32 PM   #9
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
mmm maybe a larger hammer?
seriously, really silly question here but you did remove the nut on the end of the shaft right? Then also the retainer washer that folds against one of the nut flats?
If you have removed both of these items and it still doesn't want to come of easily, maybe a light pry out with a bar and a soft blow to the shaft will pop it loose. If you don't have a soft blow hammer, thread the nut back on but not tight against the sprocket then with a 2x4 or some other piece of wood do the same procedure..... pry out the sprocket and tap the shaft in.
You don't want to damage the end of the shaft/threads or the internals of the transmission so don't strike the end of the shaft with extreme force even though you my want to right now...
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-05-2008, 12:38 PM   #10
Scary Mc OP
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
Yup, the nut and washer are off.
-Blowdryer method: Nope
-Beating sprocket with socket and big f'ing hammer: Nope
-Prybar method migth work if I could get one in there: Nope
I'm off to buy a slide hammer....
Old 03-05-2008, 12:50 PM   #11
Rabid Dog
Rabid Dog's Avatar
Oddometer: 354
good luck
Scorpion is right - Gear Puller is how I got mine off.
Rabid
2007 KTM 990 Adventure (Black)
Rabid Dog is offline   Reply With Quote
Old 03-05-2008, 12:50 PM   #12
auslander
Meh
auslander's Avatar
Oddometer: 707
After I bent that washer down, it slid out really easily.
"Every normal man must be tempted at times, to spit on his hands, hoist the black flag, and begin slitting throats." - H. L. Mencken
'07 KTM 990 Adventure, '09 Kawasaki KLX250S
auslander is offline   Reply With Quote
Old 03-05-2008, 01:26 PM   #13
Scary Mc OP
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
Luckily Napa is four blocks away from home! Napa had a very small gear puller, $15, that worked perfectly.
The sprocket is off, finally. The inside of the sprocket is coated with some sort or white thread locker like material. This is what was keeping it from coming off.
Anyone else has this stuff on their 17t sprocket?
I'm off to put the 16t on now, with a nice helping of anti-sieze!
Old 03-05-2008, 01:29 PM   #14
auslander
Meh
auslander's Avatar
Oddometer: 707
Goofy. No, mine ('07 990, bought in october last year) didn't have anything on the sprocket.
Old 03-05-2008, 01:45 PM   #15
emelgee
emelgee's Avatar
Oddometer: 870
Get hold of a gear puller, or if it's a new bike take it back to the dealer and let them sort it.
Mark G
KTM 990 rider and proud of it!!
950 adventure gone, but not forgotten.
emelgee is offline   Reply With Quote
Times are GMT -7.   It's 04:35 PM.
