Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 09-17-2010, 12:11 AM   #16816
BiggieFalls
b00b
BiggieFalls's Avatar
Oddometer: 949
Originally Posted by RAZR
first thing you do is..... find the internet and open up an account on eBay.
second.... sell your bike.
It's a great bike. Maybe the only one that would withstand the abuse i give it. But it's in such bad shape cosmetically, I'd be lucky to be able to sell it for scrap.
BiggieFalls is offline   Reply With Quote
Old 09-17-2010, 12:12 AM   #16817
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,143
Those intermittent shorts are a PITA.
I'd start with the battery (20) and make sure the lead from the + to the starter relay (21) and then from the relay to the starter is still fully insulated.
I'm not sure how the Husky is but there will come a time when I'll have to replace the KLR's + lead.
Duy. You know, like the decimal system.
Spot shared page: http://share.findmespot.com/shared/f...FogjjtYMdOqF2n
Fishyhead is offline   Reply With Quote
Old 09-17-2010, 12:13 AM   #16818
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,143
Trade you a KLR705
Old 09-17-2010, 12:14 AM   #16819
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,196
Here's a schematic. Do I have to go wire by wire and trace it all the way?
Diagnostics 101:
Look over all connections and the entire wiring harness. Pay attention to where the harness is close to anything else. Look for discoloration, or frayed wires. If you can't find it this way, next is the hard way. Except for the main fuse, remove 1/2 of the fuses on the bike. Take it for a run. If you don't blow a fuse the problem is somewhere in that part of the loom. If you do blow a fuse then the problem is in the other half. Keep doing this split until you are down to the exact are that blows the fuse. Once you know that then you can work that wire in detail.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 09-17-2010, 12:14 AM   #16820
BiggieFalls
b00b
Oddometer: 949
Originally Posted by h8chains
get yourself a continuity tester/volt meter. connect 1 terminal to the frame, and start probing the wires with the battery disconnected.
disconnect all connectors, clean the contacts and look for frayed wires.
inspect 1 wire at a time. shake each wire and look for a spark...kabooom.
I have a good Fluke Multimeter but only know how to use the volt meter part. Why do you do it with the battery disconnected? Where will the voltage come from?
Old 09-17-2010, 12:15 AM   #16821
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,120
hahahaha
my KLR (RIP) had a short and was a PITA.
it was a wire under the seat that if the seat touched it, which would make it touch the frame, it would short.
not a fun job. i hate electrical issues.
good luck!
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 09-17-2010, 12:17 AM   #16822
BiggieFalls
b00b
Oddometer: 949
Originally Posted by Fishyhead
Trade you a KLR705
It's tempting. I've been looking for something in that color range.
Old 09-17-2010, 12:18 AM   #16823
Lonestar2112
scatology expert
Oddometer: 7,196
It is tough to find an intermittant problem this way.
F*CK CANCER
Old 09-17-2010, 12:18 AM   #16824
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,143
It maybe the same wire I'm worried about. I did some re-routing and wrapped a couple of wires with harness tape when I did the 705 a few weeks ago. If she quits on me, that's the first place I'm looking.
Old 09-17-2010, 12:21 AM   #16825
xymotic
xymotic's Avatar
Oddometer: 8,367
Eric, I'd start with the fuse and work back from there.
What does that fuse power?
Check each of those wire groups.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 09-17-2010, 12:26 AM   #16826
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,366
Laugh
yup...it could be that simple or even a thermal switch short for the fan...ive seen it.you have to approach it systematically.it will drive you nuts.my sons 400 had a short in the head light circuit that took me years to find.it was a frayed wire that i luckely found at nite in the garage when i saw it spark and blow the fuse that wire is hanging in my garage to this day,bike long gone
GO KINGS!!!!(Edit:2 TIME STANLEY CUP CHAMPION KINGS) 00'KX500 (dune wrecker)08'SE ,06'EXC,02'YZF/W,76'04'H-D
92 YJ extreem ,76 CJ 5 sand beast ,07 JK cruiser
dunerat is offline   Reply With Quote
Old 09-17-2010, 12:27 AM   #16827
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 3,359
You don't measure voltage, you're checking continuity. There should be a setting that looks like a speaker with sound pulses coming from it. (Look here)
http://www.ladyada.net/learn/multimeter/continuity.html
When you set it to this and connect the leads, the meter beeps, meaning you have a complete circuit. No beep, no circuit.
So connecting one lead to the frame (after removing the battery) and poking each wire and listening for a beep from the meter will allow you to find which wire is shorting to the frame. Then follow that wire around until you find the offending short.
tbarstow is offline   Reply With Quote
Old 09-17-2010, 12:36 AM   #16828
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,366
thats true but Ringing through lamps will give you a false ground read as if you have a ground,resistance grounds ring as a ground.voltage reads a drop
Old 09-17-2010, 12:36 AM   #16829
BiggieFalls
b00b
Oddometer: 949
It's the main 15a fuse under the left side panel. It powers everything. It's the first thing in line. There is only a six inch wire between it and the positive battery terminal. I will inspect it and everything else better in the morning. I saw your frayed wire to the e-start. I'm pretty sure i don't have that.
Thanks for the suggestions guys. I will take a better look at it when I'm fresh in the morning.
The good news: I finally rode my my bike today.
The bad news: If I can't fix it tomorrow, I will miss Big Bear again.
Old 09-17-2010, 12:40 AM   #16830
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,366
you wont miss nothing ,i missed four months and when i rode again i realized i missed nothing...
Times are GMT -7.   It's 05:55 AM.
