Go Back   ADVrider > Riding > Regional forums > West – California, the desert southwest and whatever is left
Old 04-15-2009, 09:30 PM   #6106
SergX
Back on the Saddle
SergX's Avatar
Oddometer: 211
Originally Posted by RAZR
fill the tube with air to give it some shape, then stuff it in the tire. don't forget to put a generous amount of baby powder in the tire and on the new tube.
baby powder? thought I had to use windex?
or is that just for the tube?
was looking at the tire - and realized I could *almost* get away with not removing the tire at all, if the spoke hadn't broken right AT the nipple!
It's probably a good idea to replace the nipple along with the spoke, right?
Is it safe to ride it with 1 missing spoke (street, no dirt) until I have time to work on it?
-Sergio
n00b on too tall bike.
K5 Vstrom DL650
Currently no skid plate, and stuck on street-only tires until work starts up again.
SergX is offline   Reply With Quote
Old 04-15-2009, 10:36 PM   #6107
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
-Sergio
You could just remove the tire halfway (one bead) and replace the spoke that way. Undo the rim lock by backing the nut almost all the way off (if equipped) remove the valve core. Push the beads off the rim into the center well of the rim. Pull the bead off with your tire irons and remove the tube. Remove the rim band and find the nipple from the broken spoke. Replace the spoke and nipple with new parts. Tighten the spoke gradually until it rings when you tap it with a screwdriver. Not crazy tight, but snug. Check your rim band for holes or tears and install. Put just enough air in your tube to give it shape and stuff that into your tire. Push the stem into its hole. Use either baby powder or windex but not both, you'll end up with a mess that smells like a clean baby. Put your bead back over the rim, using just the tips of your tire irons to do the work. Be sure to keep the bead of your tire in the well/center of the rim so it is easy to move around. When all is in place, put about 10 lbs. of air in the tire and let it all back out to untwist the tube and check that all is OK. Fill the tire until the beads seat evenly on both sides of the rim and adjust pressure to the correct amount.
You could probably ride on the street for a while with a broken spoke, but your rim is more suseptable to flexing and impacts in this condition. Might be a good time to check all of your spokes and try to figure out why one broke. Good luck.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 04-15-2009, 11:58 PM   #6108
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,279
-Sergio
windex or soapy water on the bead of the tire to lubricate it onto the rim.
baby powder in the tire/on the tube to keep friction down between the tube and tire.
also, when you ride the baby powder helps prolong the life of the tube and to keep "balling" of the tube from happening.
tubes can tear if there is too much friction.
i change my tube when i change my tires. i also only use 'heavy duty' tubes.
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 04-16-2009, 12:07 AM   #6109
datol
n00b and improved!
datol's Avatar
Oddometer: 93
One broke spoke deserves another
-Sergio
I have gotten away with riding with broken spokes for awhile before. The bad thing is that the other spokes near it will start breaking because they are overloaded. If you can get the right spoke and nipple, you might get lucky and be able to just break the bead and push the tire and tube to the side enough to get the old one out, and new one in. Worth a try.
Better sooner rather than later to save yourself chasing broken spokes around the wheel
Dane
Buy it, use it, break it, fix it
We learn nothing from the things we do right the first time.
datol is offline   Reply With Quote
Old 04-16-2009, 12:28 PM   #6110
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,717
sergio...if you can wait till next tues, come over to my house and we'll fix it.
then you can check each spoke using my new spoke torque wrench, but first you must research the proper torque for your particular wheel.
NSFW is offline   Reply With Quote
Old 04-16-2009, 12:59 PM   #6111
luv2race
Confused
luv2race's Avatar
Oddometer: 2,324
I only use 'heavy duty' tubes.
You HAVE to because you ride that KLR like a motocross bike!
John
luv2race is offline   Reply With Quote
Old 04-16-2009, 01:11 PM   #6112
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
That's a good one. I've never thought of calling mine that before
notmybikemodelname is offline   Reply With Quote
Old 04-16-2009, 04:13 PM   #6113
SergX
Back on the Saddle
SergX's Avatar
Oddometer: 211
Thanks for your info guys, and the offer Joel...
I finally gave in and decided to try and replace it myself.
At first I was trying without even removing the wheel from the bike - I was actually able to replace the nipple by just breaking the bead (using windex) and prying the wheel away from the rim, then lifted it with the tire irons in the area I needed to work on. Sweet!
But when it came time to do the spoke itself I realized that it was going to turn into an ordeal!
I had wiggled the new spoke into place without removing the sprocket only to realize it was in the WRONG way, and the sprocket blocked the spoke from going on the correct way.
*sigh*
Luckily my neighbor was home and he was able to provide me with some tools and muscle to take the wheel off, take the sprocket off, and install the new spoke. I had to remove 2 more spokes for it to go in right.
But now it's all done and ready to ride!
But I might still not be able to ride on Saturday due to other things going on.
-Sergio
K5 Vstrom DL650
Old 04-16-2009, 05:56 PM   #6114
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Good job Sergio. Check your other spokes too. Start by feeling them. They should not feel loose at all. Next, find a starting point and tap each spoke with something metal like a wrench or a screwdriver. As you go around the wheel you will notice they will sound a little different. They should kind of ring. If the don't ring and go thunk, that one may be loose. Don't go and tighten them all. You could end up with a wobbly rim. Go gradually around and check them out on both wheels. Careful that if you tighten up a spoke that it is not stuck or you may break another one.
1991 Honda XR628R
1978 Yamaha XT500
Old 04-16-2009, 06:58 PM   #6115
SergX
Back on the Saddle
SergX's Avatar
Oddometer: 211
Thanks.
Yep, I went around and checked all my spokes, found a "flat" one... I've always wondered if I need to be concerned of spokes that sound different from others... they still "ring", but in a different tone... kinda like a piano's keys have different tones... it still rings and is not flat, just not the same as some of the others.
-Sergio
K5 Vstrom DL650
Old 04-18-2009, 02:03 AM   #6116
SergX
Back on the Saddle
SergX's Avatar
Oddometer: 211
Broke another one!
Another spoke broke tonight! DAMNIT!
At least I caught it in time before it did any damage or broke in the nipple.
But looks like I'll still have to remove the wheel AND remove the sprocket to put a new one in! *sigh*
Really starting to hate spoke wheels! That's the 3rd one in 12 months! 2 in two days! WTF?!
Sorry... just venting!
Joel, starting to think your offer about the torque wrench might be a good idea. Does the offer still stand? I'll have the spoke in by then (hopefully) but I'd like to check them all anyway.
-Sergio
K5 Vstrom DL650
Old 04-18-2009, 06:00 AM   #6117
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,717
-Sergio
sure man...
Old 04-18-2009, 10:10 AM   #6118
mike toon
AKA Mr Pastrami
mike toon's Avatar
Oddometer: 183
Sorry to hear this Sergio.
Those really high pitched sounding spokes are too tight and are taking more of their share of the load and must be loosened slightly. Joel will get it going.
`02 CB919
`02 KLR
mike toon is offline   Reply With Quote
Old 04-18-2009, 07:00 PM   #6119
SergX
Back on the Saddle
SergX's Avatar
Oddometer: 211
That explains it!!!
I thought I was adjusting my front tire, and ended up with some pretty major wobble. Ben gave me a few pointers and was able to fix most of the wobble.
Also replaced the broken spoke...
not only that, but, Joel, remember the rocks on Lynx that dislodged my rear brake linkage? Well, we (a friend and I) experimented with the rear brake, and figured out we could modify it so the brake linkage is towards the top of the wheel and will no longer be damaged by rocks!
Such a simple mod! The only downer is that the brake wear indicator no longer works. But at least rocks won't leave me without brakes (and causing me to miss the turn or worse - fly off a cliff).
-Sergio
K5 Vstrom DL650
Old 04-19-2009, 06:57 PM   #6120
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,311
We rode a little be o this
Traveltoad
bike
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Times are GMT -7.   It's 10:53 PM.
