Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 05-04-2009, 07:23 PM   #6391
Oni
Ronin
Oni's Avatar
Oddometer: 1,839
Originally Posted by h8chains
i don't believe it's the dainese, but the combination of nowwhat's ability to take punishment, ninja like quick reflex, strong physique, and luck that save his .....
Yeah...years of JuJitsu does a lot to toughen up the ol' bod.
Oni is offline   Reply With Quote
Old 05-04-2009, 08:13 PM   #6392
qwiksilver
qwiksilver's Avatar
Oddometer: 348
how was the ride sergio?.....
I was there. It was a good one.
Between Sergio's choice of roads and Mike at North Hollywood Scooters hosting the BBQ, we had a perfect day.
qwiksilver is offline   Reply With Quote
Old 05-04-2009, 08:33 PM   #6393
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,980
OSS.....
Nowwhat is online now   Reply With Quote
Old 05-04-2009, 08:45 PM   #6394
RSC E
ADVWNT2B
RSC E's Avatar
Oddometer: 217
Originally Posted by notmybikemodelname
My pressure suit is a Tecate. I also have a Modelo one that is a little more beefy. I like these suits as they seem to fit better and get lighter as the day goes on. Best of all they sell them at any convenience store
that's some funny shit right there
RSC E is online now   Reply With Quote
Old 05-05-2009, 12:57 PM   #6395
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,644
good things happen to cheap people
looks the 640A will be back on the road again.
got a used stator, a new rotor from ktm hutt, and motomike will lend me his flywheel puller. should be ready to fire up by this coming monday and ready for big bear the following weekend.
NSFW is offline   Reply With Quote
Old 05-05-2009, 01:05 PM   #6396
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Almost cheaper than buying a new bike! Great news. Have fun.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 05-05-2009, 01:23 PM   #6397
Ben99r1
Ben99r1's Avatar
Oddometer: 3,067
Joel. Are you using red loctite this time? Ben
Ben99r1 is offline   Reply With Quote
Old 05-05-2009, 02:09 PM   #6398
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,644
not red, but blue and not just blue...gotta be 243! a $400 lesson for all you guys in a single post......
Old 05-05-2009, 03:37 PM   #6399
knlkern
knlkern's Avatar
Oddometer: 303
I used Red 271 on a project once, when it came time to fix a manufacturing mistake it became a real problem to get those bolts removed, a cutting torch was the answer!
www.district37ama.org/dualsport/ -webmaster.
525exc
K1200lt
knlkern is offline   Reply With Quote
Old 05-05-2009, 06:17 PM   #6400
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,644
loctite betta than lockwasher
i went to a loctite seminar and shocked to learn that there are over 3k of loctite products.
hard to believe.....using the proper locktite is better than a lock washer. they did a comparative study where they subjected the fasteners to cyclic load and vibration; loctite won.....
like chris said...someone will need a torch and a good wrench to loosen up the bolt.
here's a trivial question...what's the difference between a screw and a bolt?
Old 05-05-2009, 06:54 PM   #6401
PAPABEAR
ca ibex
PAPABEAR's Avatar
Oddometer: 36
loctite
I used to work as an r&d chemist for loctite. we created some good stuff.
make sure to read applications. not all glue products are the same
carpe diem
PAPABEAR is offline   Reply With Quote
Old 05-05-2009, 09:44 PM   #6402
grinder96
grinder96's Avatar
Oddometer: 1,434
OK I'll bite.
A bolt compresses one or more materials between its head and usually a nut or machined threads.
A screw uses the material itself to form threads and compress.
Turin
11' Husky TE630, 06-Husky SM610, 02'Honda VFR800, 04'Honda xr80r
"Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves." - Albert Einstein
grinder96 is offline   Reply With Quote
Old 05-05-2009, 10:22 PM   #6403
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,644
loctite and water crossing
Originally Posted by grinder96
OK I'll bite.
who else wants to give it a try....
while others are doing their research...turin you can enjoy this vid from last saturday's ride....
Old 05-05-2009, 10:39 PM   #6404
knlkern
knlkern's Avatar
Oddometer: 303
Front wheel up..
Front wheel UP!!
Damn that's fun stuff!
525exc
K1200lt
Old 05-05-2009, 11:24 PM   #6405
mike toon
AKA Mr Pastrami
mike toon's Avatar
Oddometer: 183
A screw is only up to a certain size. 10 I believe. Bolts I believe starts at 1/4".
`02 CB919
`02 KLR
mike toon is offline   Reply With Quote
Times are GMT -7.   It's 07:30 PM.
