Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 05-10-2010, 11:02 PM   #14011
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,438
Originally Posted by rruugger
Randy, I gota admit......I ran a little wide on that bit of road as well and slipped into that rut too. Rode it all the way to the end! May have hogged it out a bit. Sorry.
same here, it was a blind approach, can't see it from the other side. safest way is stay right. but the next thing, it's off camber and i'm sliding to the right. me too got swallowed by the san adreas fault; have to ride it out until i found an escape.
NSFW is offline   Reply With Quote
Old 05-11-2010, 08:11 AM   #14012
Earl999
Earl999's Avatar
Oddometer: 903
Originally Posted by jamin_mathis
Yeah I did Daves mod, pulled the silencer and snorkel, I should put the hex screws on cuz the phillips are getting chewed up. I'll swap them next time I clean the carb, Thanks for the idea!
Same here, I drilled the snorkel rivets out then tossed the snorkel & stock paper filter, and put in a UNI, but I left the exhaust and emissions alone. I used a .020" washer for shimming the needle up. I bought my 4 mm Hex head screws at my local Ace hardware store, you'll need short length (~6 mm) for the slide cover, and medium length (~12 mm) for the float bowl cover. Amazing what a dense cool charge of fuel and air will do for an engine, mine runs SO much cooler and better now!
Different topic, I really like my stock Dunlop tires, but are only sold at Honda dealers. Just curious what tires you're running? I've read that the Kenda 270 5.10X18 is the way to go for the rear, with some liking a more aggressive front tire like D606, or soft Cheng Shin trials tire!
I run Metzeler tires on my Husky 610SM street tard, and was lookng at their Sahara 3 dual sport tires, any inputs?
WR250
XR650L
CR500AF
CR250R
Earl999 is offline   Reply With Quote
Old 05-11-2010, 09:32 AM   #14013
notmybikemodelname
KOTW is a myth!
notmybikemodelname's Avatar
Location: I'm in jail Dad, and I like it here.............
Oddometer: 7,276
Orange for Orange
I just saw this at Cal Worthington Ford.
Thought some of you Kool-Aid drinking guys might want it
notmybikemodelname is offline   Reply With Quote
Old 05-11-2010, 10:59 AM   #14014
jamin_mathis
jamin_mathis's Avatar
Oddometer: 2,519
I'm boring I just run the 606 front and back, I've been thinking about trying the Pirelli Scorpion Pro All Terrain/Enduro Klammer uses them and they seem to do great by him I think there even more aggressive than the 606 and a bit cheaper. Hay did your bike come with a tool kit mine didn't but I just saw one in the OEM parts catalog?
A riot is the language of the unheard MLK
jamin_mathis screwed with this post 05-11-2010 at 11:37 AM
jamin_mathis is offline   Reply With Quote
Old 05-11-2010, 01:05 PM   #14015
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,438
i would be skeered to use that tire as pictured on the street.
Old 05-11-2010, 01:29 PM   #14016
jamin_mathis
Oddometer: 2,519
It's is DOT it can't be that bad can it?
Old 05-11-2010, 01:35 PM   #14017
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,438
yup... but someone has to prove it on little T at 60 mph......
perfect for trailer queens and crossing public streets.....
Old 05-11-2010, 01:39 PM   #14018
Oni
Ronin
Oni's Avatar
Oddometer: 1,839
I got this on the back. Not bad, wears kinda quick, on 2nd one. MT21 front, like the front!
Got a Dunny 606 rear from H8 to spoon on next.
http://www.motorcycle-superstore.com...Rear-Tire.aspx
Oni is offline   Reply With Quote
Old 05-11-2010, 01:43 PM   #14019
rruugger
formally rruugger
rruugger's Avatar
Oddometer: 1,298
[quote=notmybikemodelname]I just saw this at Cal Worthington Ford.
Ewooooooooooo!!! now thats a pumpkin hauler! I like the American flag above it too! Does that make me a racist? I can't tell anymore.
LIFE IS 20% WHAT HAPPENS TO YOU AND 80% WHAT YOU DO ABOUT IT
rruugger is offline   Reply With Quote
Old 05-11-2010, 01:51 PM   #14020
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,366
i look at that tire and want to ice race +1 for pucker factor on the street.but ive seen 2 FFs run them sooooo ill drink to that oopsy PUI
GO KINGS!!!!(Edit:2 TIME STANLEY CUP CHAMPION KINGS) 00'KX500 (dune wrecker)08'SE ,06'EXC,02'YZF/W,76'04'H-D
92 YJ extreem ,76 CJ 5 sand beast ,07 JK cruiser
dunerat is offline   Reply With Quote
Old 05-11-2010, 01:58 PM   #14021
NSFW OP
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,438
[quote=Sir Crashalot]
hello sir crashalot........ you stole that name from me....
Old 05-11-2010, 01:59 PM   #14022
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
It can be yours for $9950 Go see Cal, Go see Cal, Go See Cal.
Old 05-11-2010, 02:09 PM   #14023
dunerat
WTF?
dunerat's Avatar
Oddometer: 14,366
[quote=h8chains]
Joel ... we need to register our trade names with go daddy to stay abreast
Old 05-11-2010, 02:16 PM   #14024
notmybikemodelname
KOTW is a myth!
Oddometer: 7,276
[quote=h8chains]
Joel,
You know this guy sounds and looks a lot like Rruugger to me.
The same avatar and all of the same bikes. What's up with this? Or did I miss a name change at some time?
Old 05-11-2010, 03:15 PM   #14025
Ben99r1
Ben99r1's Avatar
Oddometer: 3,043
Earl do not run the kenda 270. The knobs are tall causing the bike to lay over on turns. If you ask anyone. They always say the tire runs better after they have some miles on them. That's because the knobs have to wear done. If you want a cheap rear tire look at the Shinko 244. Its a copy of the kenda 270. But it is made with a softer rubber compound and shorter knobs. So the lay over feeling is not as bad as the kenda. It also cheaper and almost has the same wear miles too. I run a 606 front and rear now. But ill will be using a 606 front and Michelin T 63 rear next. I have been told that it gets alot on miles. It is almost like a tkc 80 but it sells for $52- $55 at Motorcyclesuperstpre.com. The Shinko 244 is only good for a rear tire. Ben
Ben99r1 is offline   Reply With Quote
Times are GMT -7.   It's 07:04 AM.
