Old 03-09-2008, 06:22 PM   #1
Big G OP
Big G's Avatar
Oddometer: 3,149
DRZ 400 E dual sport
Hey everybody, I am sure this is 205, but, for some reason my search wouldn't work. Anyhow, I was thinking of street licensing my '04 DRZ 400. I want to be able to use it for little weekend excursions to explore the local mountain roads (dirt, paved, rock, etc, etc)
My understanding is that around here (Az.) all I need to do is get it inspected, and make sure I have a DOT brake light, horn, mirror, DOT headlight, and DOT tires. The part I am a little concerned about is the brake light. I want to make sure I can get it wired properly to have it work. Has anyone done this? I know that there are kits to get is street legal on the market (only a couple hundred), but, I think I can do it for even less. Not to mention that the kits come with a REALLY ugly taillight. I've seen an LED one that I like.
Anyhow, if any of you have any thoughts, let me know! Thanks, Greg
"Survival is the slowest form of suicide."- Daredelvis
YZ-250 Throttle = A little touchy
DRZ-400E
2013 Triumph Rocket III Roadster 2300cc WOAH!
Meat = Murder, ergo Murder = YUMMY
Big G is offline   Reply With Quote
Old 03-10-2008, 05:44 AM   #2
Bo_9
Oddometer: 190
You can mod the stock led for a functional but not nearly bright enough for most brake light. Instructions for that can be found at www.thumpertalk.com. they have by far the most active DRZ forum in existance. I used an edge2 from Wheeling Cycle along with a wiring harness and led blinkers. I've changed the blinkers since this pic, but the taillight is still working fine, now even has a plate hanging from it...
Bo_9 is offline   Reply With Quote
Old 03-10-2008, 05:48 AM   #3
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,764
i used the Baja Designs LED tail kit. Be aware that the LED clusters like I had are VERY sensitive to proper voltage. There's lotsa discussion on TT about doing wiring mods to the DRZ to get the voltage stable throughout the system. AS is from the factory they are not great. If you're NOT going to fix the bleeding circuits, be sure to pigtail it and keep a charger handy, and used conventional lights.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 03-11-2008, 09:10 PM   #4
Big G OP
Big G's Avatar
Oddometer: 3,149
Thanks for the info guys! That Edge2 is pretty cool. Is it DOT approved?
DRZ-400E
Old 03-12-2008, 08:46 AM   #5
Bo_9
Oddometer: 190
Not sure, but it hasn't gotten me any odd looks from LEO's...
I don't think it has the coveted DOT molded into it , but I'll check.
Old 03-12-2008, 09:19 AM   #6
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,598
I would just order it all up from Baja Designs. They're good people. Some people have had luck with cobbled together DS kits and have done if for less money though. YMMV. http://www.bajadesigns.com/2005%20Web%20Site/dsk.htm
Does the AZ DMV actually do the inspections or do you take it to an approved bike shop? If it's the latter they could probably help you out too as far as what flies and what is overkill, eg DOT tires, front and rear activated brake light etc...
2k4 Wee-Strom, black, farkled, smells like bacon.
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
brad21 is offline   Reply With Quote
Old 03-12-2008, 11:42 AM   #7
jgas
Stoogely Adventurerer
jgas's Avatar
Oddometer: 843
I bought a little tail/brake light made by Emgo from my dealer. I think it was in a Tucker Rocky or Parts Unlimited catalog. Cost 10 bucks and it has worked fine for 2 years. It is kind of ugly, but it mounted easily and had a simple two wire set up with a dual element bulb. I used a plunger switch from an auto parts store which already had a spring loaded wire to attach to the rear brake pedal. I didn't worry about a switch on the front brake lever. In Arkansas you don't need blinkers unless you ride at night, then they can ticket you if they want, but they rarely bother. They are picky about a good horn, high and low beam headlight, and one mirror. Thats about it. You can add either a brighter or less bright headlight anyplace on the front of the bike instead of a high and low beam as long as one is brighter than the other. I added a quality 55 watt Halogen bulb in place of the stock crappy bulb, and a small 35 watt fog light purchased at Wally World. Voila, two headlights. For a horn I used an air canister horn for boating duct taped to the handlebars. It was loud as hell, but they recently decided the horn has to be powered by the bike. Oh, and of course liability insurance.
jgas. " Most of the singletrack is gone. Forever"?
-Graduate of the "Rock on the side of the Trail as a Hammer" school of motorcycle repair.
"No matter where you go, there I was".
-DRZ 400, GasGas 275, Klein, zero cc.
jgas is offline   Reply With Quote
Old 03-12-2008, 12:56 PM   #8
sperkins
Oddometer: 213
Yeah check out that website. You should be able to find what you need.
my work
sperkins is offline   Reply With Quote
Old 03-12-2008, 06:04 PM   #9
Marvin_ADV
Marvin_ADV's Avatar
Oddometer: 435
I have a dual sported E model in AZ, good bike for this state with all of the offroad riding you can do. I bought mine with a kit already installed from Electrosport, the Dakar model. Works great! Enjoy!
Marvin_ADV is offline   Reply With Quote
Old 03-13-2008, 09:57 AM   #10
Big G OP
Big G's Avatar
Oddometer: 3,149
I think Az MVD inspects it themselves.
DRZ-400E
Old 03-13-2008, 10:53 AM   #11
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,764
Electrosport is good stuff.
Zapp
Old 03-13-2008, 12:05 PM   #12
Raven_F800GS
Otogai
Raven_F800GS's Avatar
Oddometer: 12
DR-Z 400E accessories
Dear All!
I am looking for some accessories for my new Suuki DR-Z400E e.g. engine skid plate, a kind of a computer, maybe custom exhaust, etc.
Can I count on your advise, please?
Thanks in advance!
Suzuki XF 650 - sold
BMW F 800 GS
Suzuki DR-Z400E - sold
Husaberg FE570 - Pure Power
Raven_F800GS is offline   Reply With Quote
Old 03-13-2008, 02:20 PM   #13
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,598
Originally Posted by Raven_F800GS
Dear All!
Thanks in advance!
http://www.thumpertalk.com/forum/forumdisplay.php?f=25
Old 03-14-2008, 01:21 PM   #14
Raven_F800GS
Otogai
Oddometer: 12
BMW F 800 GS
Old 03-17-2008, 03:24 PM   #15
Big G OP
Big G's Avatar
Oddometer: 3,149
Dear All!
Thanks in advance!
I have a White Bro's skid plate on mine, and it is good and bashed up, but, I am not terribly happy with the mounting setup. It uses small metric bolts that go into the stock holes.
I have a Utah Sport Cycle plate for my YZ, and am much happier with the set up. It's lots more rugged.
DRZ-400E
Times are GMT -7.   It's 06:10 AM.
