Go Back   ADVrider > Riding > Regional forums > The Sandbox - AKA Flatistan
Old 02-08-2013, 04:47 PM   #22816
SR56
Bullfrog
SR56's Avatar
Oddometer: 501
My guess from the way it sounds is that the mid range is a little rich...which is controlled by the needle in the carb. To lean out the mid range you want to lower the needle a notch. I'd check the manufacturers recomendation on oil/gas ratio and stick with it. Too little oil and you can trash the engine in a hurry. The problem is too much oil/gas total in the mid range, not too much oil. What have you changed since it ran like glass? Smoking after shutting it down is no big deal...the exhaust may have a llittle residual oil but that will clean out when you get the jetting corrected. On the good side if it idles and runs good with the throttle wide open, you have minor tuning issues to worry about and nothing major. Hope this helps.
SR56 is offline   Reply With Quote
Old 02-08-2013, 05:40 PM   #22817
Hatch
PAR OG
Hatch's Avatar
Oddometer: 3,223
thanks guys!
yes Rob, it has the adjustable PV. haven't pulled it yet.
SR- the ktm owners handbook suggests 40-60:1 so.... yea
madhouse, I am worried about just that - I found a good suggestion on ktmtalk - I filled the tranny with exactly .7L of oil, so if I drain it, I should get back about .7L... if not...
"No man ever steps in the same river twice, for it's not the same river and he's not the same man."
Hatch is offline   Reply With Quote
Old 02-08-2013, 05:59 PM   #22818
Madhouse
Semi-Goodlookin!
Madhouse's Avatar
Oddometer: 3,329
Jerry,
Shot in the dark.
Check you coolant level.
Maybe tiny head gasket leak?
Madhouse is offline   Reply With Quote
Old 02-08-2013, 07:58 PM   #22819
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,317
Smokin two smoke
All the advise is good and spot on...
IMHO or even IMEO - start with fresh compression. Ring (in the case of the 200) or piston and ring with new fresh bore and THEN start to refine carb exhaust etc. The KTM 200 will run with almost no compression...
If you know the compression is OK (can you push it through with your HAND? if so it aint shit) then I would look at gummed up exhaust First before other remedies. BTW I have repack kit that has never been opened.
The more I listen to the vid the more I think you are clogged up in the muffler...
who knows....
Ask Gimmie why a bad battery on a 2012 5 Hunny acts like a clogged filter!!!!
Good luck.
KTM 500 EXC Yellow Vee Black DR650
A few others in the past
You dont quit riding when you get old, you get old when you quit riding.
I don't always ride street bikes, but when I do I prefer VStroms
Vico1 is offline   Reply With Quote
Old 02-08-2013, 08:49 PM   #22820
Woods Rider
X-Crazed Racing Fool
Woods Rider's Avatar
Oddometer: 1,940
Originally Posted by Hatch View Post
I've tried some specific forums, but I keep gettin generic advice... thought maybe some locals might could shed some light...
Some of you 2t old timers, could you lend a young ignorant mind a figurative hand? I am wondering if this thing needs a rebuild:
it idles ok, runs at wfo ok, rough midrange, smokes all the time. ran it hard an fast for about 10 minutes and the pipe was smokin for minutes afterwards... new packing? strange midrange issue?
I ran 44:1 per previous owner, then tried 50:1 with no difference. tried cheap oil, then went and spent $ on oil. no difference. already pulled carb numerous times, checking float bowl clearance, cleaned all jets and passages with carb cleaner, tiny wire brushes, more carb cleaner, compressed air. When bought, the bike ran like glass. then I started effin with it with the mindset of preventative maintenance, and ended up killin it.
My 300 ran on 60:1 flawlessly for years. I ran BelRay H1R in it. Didn't smoke, piston and rings wonderful shape after two seasons of racing (including 24 hour race at Perry Mountain) .
I never would have mixed it so lean if the KTM owners manual didn't call for it.
Also I second Mr Robert Dirt's prognosis of power valve cleaning time has arrived.
2009 530 EXC - Dualsport Rocket Ship
2004 DL1000 VStrom - For the road
Only a motorcycle rider knows why a dog sticks his head out the window of a car!
Woods Rider is offline   Reply With Quote
Old 02-09-2013, 06:46 AM   #22821
waysherr
Behind Bars For Life
waysherr's Avatar
Oddometer: 494
[QUOTE=power valve cleaning time has arrived.[/QUOTE]
No need for wire brush, contact cleaner, & elbow grease. Bring me your power valve parts & I will bead blast them at work for free. You will think they are brand new from the nearest dealer This applies to any ADV member.....bead blasting, welding, etc. I can help, ask Skidmark
Nobody said life would be easy, they just promised it would be worth the ride.
waysherr is offline   Reply With Quote
Old 02-09-2013, 06:52 AM   #22822
waysherr
waysherr's Avatar
Oddometer: 494
[QUOTE-start with fresh compression.[/QUOTE]
So true! With no valve train to breathe through, ring seal is EVERYTHING to a 2stroke. If you pull the jug off, put the ring in it and measure end gap. .003 per inch of bore is a good rule of thumb, I bet yours is fat.....
Old 02-09-2013, 07:27 AM   #22823
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,744
Can you brazen small holes on something like a dampner rod? I want to fix the front end on my XR but can't do a whole lot till I make that fix first.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 02-09-2013, 07:45 AM   #22824
Vico1
The Maestro
Vico1's Avatar
Oddometer: 6,317
Gonna head out to Karick Lake and meet up with the Bama boys....
See you all tomorrow...
Old 02-09-2013, 04:16 PM   #22825
Moabman
Ironman
Moabman's Avatar
Oddometer: 144
Are the fast burners meeting at Blackwater or Karick Lake? Time?
2010 KTM XC-W 530
Moabman is offline   Reply With Quote
Old 02-09-2013, 04:34 PM   #22826
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,744
Ride leaves from karick lake at 9am.
Old 02-09-2013, 04:34 PM   #22827
rotorhead511
Live and let live.
rotorhead511's Avatar
Oddometer: 482
Karick Lake with a 0900 rollout.
'12 450 XC-W
'11 300 XC
'04 GasGas TXT Pro 280
'89 Honda Transalp XL600V
rotorhead511 is offline   Reply With Quote
Old 02-09-2013, 04:34 PM   #22828
MItrnsplnt
PllnGs tillthey puke
MItrnsplnt's Avatar
Oddometer: 666
FASTBURNERS unite!!!! Karick lake @ 0900 Sunday a.m.!!!!!
'09 KTM 530EXC (do-it-all workhorse)
'04 KTM 250EXC (ST switchblade)
'13 Sherco 3.0 (trials billy-goat)
Rocky Mountain Ride 2011: Aspen to Crested Butte and back
http://advrider.com/forums/showthread.php?t=723271
MItrnsplnt is offline   Reply With Quote
Old 02-09-2013, 04:36 PM   #22829
rotorhead511
Live and let live.
Oddometer: 482
That's CRAZY. The three of us hit the submit button at exactly the same time. Check the time stamps.
'12 450 XC-W
'11 300 XC
Old 02-09-2013, 04:42 PM   #22830
Moabman
Ironman
Moabman's Avatar
Oddometer: 144
See you there.........
2010 KTM XC-W 530
Times are GMT -7.   It's 05:01 PM.
