Old 03-12-2013, 10:29 AM   #841
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Great!
Thanks for the feedback.
Looks like I will have to get one when my new 690 comes in.
Old 03-12-2013, 11:26 AM   #842
Ian B OP
Fairing Manufacturer
Oddometer: 591
Originally Posted by Yellow Pig View Post
Great!
That sounds like a very good idea ! I sell more 690 Lynx's worldwide, than every other fairing put together !
Just a point about the latest 690 model ( including last years). KTM have decided to move the indicators off of the specific mount and back onto the OEM 'candle', which is a pain, because you need to remount the indicators when fitting a Lynx.
The easiest way to solve this is to order an indicator mounting bar from the earlier model ( also used by the 530 and 450 ) and move the indicators onto this. It's much better in any case to have the indicators mounted of the fairing, because you don't have to unplug them when you remove the fairing.
Cheers Ian
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 03-12-2013, 12:24 PM   #843
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,597
Nice tip. Thanks.
Old 03-12-2013, 03:46 PM   #844
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by Ian B View Post
Having a look at one locally this week
Ian
Woooohoooooo!!
modeselector is online now   Reply With Quote
Old 03-12-2013, 08:49 PM   #845
triplenickel
triplenickel's Avatar
Oddometer: 2,430
How durable is the glass/kevlar mask to cracking under flex or vibration?
70k on mine the SE doesn't get babied, it has one small crack between the lights where I hit a tree. If I had any reason to buy another I would!
07 SE
PG007
Old 03-16-2013, 01:41 PM   #846
Kainic
Almost there
Kainic's Avatar
Oddometer: 390
Any words on the updated Mirage for the F650?
Kainic is offline   Reply With Quote
Old 03-17-2013, 08:24 PM   #847
Ian B OP
Oddometer: 591
F650 single, or twin ? Nothing more on the single for the moment.
Old 03-18-2013, 03:46 AM   #848
Kainic
Almost there
Kainic's Avatar
Oddometer: 390
Single
Sent from my iPad using Tapatalk HD
Old 03-21-2013, 05:14 PM   #849
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,789
Thumb Outstanding Adventure Products....
Just found the thread and figured I should chime in here too... I've been using Ians Fairings for the last 62,000mi on my KLR.
First an XSTwin and then last Spring I switched over to some DRZ forks and a Lynx. Wanted to shed the weight of the fairings subframe and it's tendency to cracking, plus be able to point the headlight anywhere I turned the bars.
The wind protection and lighting (yes I ride at night) have been OUTSTANDING!!! The quality is second to none, and Ians service has been excellent at every turn.
Thanx for everything Ian and Cheers!
Mocking it up...
I carve and glue in pipe insulation to seal out any light that may escape and reflect back at me...
Had to make a spacer to lengthen the fairing, raising it off the fender due to the KLR head tube being longer than the DRZ's.
Though funny looking at first, this created a nice spot for the fender bag to tuck back under...
The girl all finished up with some HighwayDirtBikes bars, guards, and Vapor protector, DoubleTake Mirrors and of course The Lynx!
The best pics I could come up with (sorry) showing the rear of the fairing... it has a Montana, 12v outlet, Kissan volt/temp, heated grip controls etc.. really.
Jettn Jim screwed with this post 03-25-2013 at 04:21 PM
Jettn Jim is offline   Reply With Quote
Old 03-23-2013, 04:41 AM   #850
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,823
Howdy Jim, Told ya you would love the fork upgrade.
I hope you went with the better brakes too.
You going to Hells Canyon again this year?
Did that dog ever make it back home?
Everything Ian does is top shelf
I have thousands of miles on mine, one of my favorite mods to date.
Check the short ride report in my sig...
Mr. Fisherman is offline   Reply With Quote
Old 03-25-2013, 04:24 PM   #851
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,789
Thumb
Yo Fishy... yes Ians stuff is TOP NOTCH! And his customer service the beast too!
The Forks rule....
Yup Mick is back safe in Idaho and missing me (Miss'n him too )
Hope to get to the Gathering for the 3rd year in a row... YUP YUP!
Read your RR and loved it, thank you!
Peace my brother,
JJ
Old 03-25-2013, 05:36 PM   #852
Ian B OP
Oddometer: 591
The Forks rule....
Peace my brother,
JJ
Thanks guys, the check is in the post !!
You might have figured out that there is a new Lynx now and one of the things I've got on the list is to create a 'proper' KLR version that would fit both older and newer models. Looking at your photos has just reinforced this. Perhaps fitting the larger Mirage 2 screen would be a good move as well.
Cheers Ian
Old 03-25-2013, 06:03 PM   #853
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
sounds like what i need as I keep chopping on the 08 fairing
thats so I can get full lock with the hand guards
So its a good time for a KLR fairing for the 08's
johnwesley is offline   Reply With Quote
Old 03-25-2013, 06:42 PM   #854
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Oddometer: 1,789
Cheers Ian
Yes Ian I see the new version on the KTM's pictured... and I LIKE IT!
Can/will the new Lynx fairing mount up to my existing dash?
And the Larger Mirage.... +10 I would like to have a custom one done up 2" wider on each side and 1-1/2" higher across the top as well as 2-3" longer across the bottoms of the side (I'll call them) wings, that flare on the bottom corners.
Peace,
JJ
Old 03-26-2013, 07:36 PM   #855
Adrian V
Oddometer: 515
A few questions
I'm thinking of getting a Lynx for my DRZ 400, but I have a few questions:
Do the halogen lights come in a version for Oz where cars drive on the left?
How much brighter are the HID lights?
What model is the projector low beam light?
Would these new (ish) Hella Bi Halogen lights be an option:
http://www.myhellalights.com/index.p...adlamp-module/
The Bi-Halogen lights might be worth considering as both lights can stay on when on Hi and Low.
Thoughts?
Cheers,
Adrian
Adrian V screwed with this post 03-26-2013 at 07:42 PM
Adrian V is offline   Reply With Quote
Times are GMT -7.   It's 04:45 PM.
