Old 04-19-2009, 06:06 PM   #1576
racingwoody
racingwoody's Avatar
Oddometer: 353
Fuse box relocation
Fuse box relocation project.
From here:
Photobucket
To here:
Photobucket
Photobucket
When I moved the fuse box I also had to change how the seat was removed:
Photobucket
Photobucket
Woody
1989 Honda NX250
CHEERS!
racingwoody screwed with this post 04-20-2009 at 02:47 PM
racingwoody is offline   Reply With Quote
Old 04-19-2009, 06:12 PM   #1577
racingwoody
Oddometer: 353
Tool box
All this was to make room for the tool box.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Woody
1989 Honda NX250
CHEERS!
racingwoody screwed with this post 04-20-2009 at 03:25 PM
Old 04-19-2009, 06:22 PM   #1578
racingwoody
Oddometer: 353
19" front
16" rear
knobbies
12 tooth front sprocket
Photobucket
19" front
17" rear
Trailwings
13 tooth front sprocket
Photobucket
Woody
1989 Honda NX250
CHEERS!
racingwoody screwed with this post 04-20-2009 at 03:27 PM
Old 04-19-2009, 06:24 PM   #1579
racingwoody
Oddometer: 353
Originally Posted by drexNX
stock shock blew, this one... doesn't.
Looks like there are some things missing from this bike?
Woody
1989 Honda NX250
CHEERS!
Old 04-19-2009, 08:15 PM   #1580
drexNX
Oddometer: 81
yeah, the stock airbox had to be ditched to run that GSXR750 shock, replaced with a pod filter. the airbox lid got ziptied to the framerails, and I had to make a mudguard/battery tray in the process
drexNX is offline   Reply With Quote
Old 04-20-2009, 08:06 AM   #1581
dhw1179
Oddometer: 47
Valve Clearance
I've got all the plastic and gas tank off of my bike being painted. Debating checking my valve clearance while it's apart. How hard is this? The luck I've had on my bike, it will be an ordeal. I've read the service manual and reviewed the exploded parts diagrams. Just don't want to get into something that will leave my bike down during the upcoming beautiful weather.
DHW1179
Floyds Knobs, IN
dhw1179 is offline   Reply With Quote
Old 04-20-2009, 09:16 AM   #1582
RogerThat
Old Guy Adventure Videos
RogerThat's Avatar
Oddometer: 159
Question No Pics
Woody
What happened to all of the pictures or am I the only one that can't see them.
Would love to see the out come of your project.
Roger
Simple solutions to complex problems will not be allowed.
RogerThat is offline   Reply With Quote
Old 04-20-2009, 01:27 PM   #1583
racingwoody
Oddometer: 353
Sorry I attached the photos after my initial download to photobucket then moved them to a different folder. Just waiting till I get home to fix sorry.
Woody
1989 Honda NX250
CHEERS!
Old 04-20-2009, 06:37 PM   #1584
racingwoody
Oddometer: 353
fixed!
Woody
1989 Honda NX250
CHEERS!
Old 04-20-2009, 06:59 PM   #1585
Ratchdaddy
Ratchdaddy's Avatar
Oddometer: 185
GSXR Shock
I have a pretty bad rear shock on the one I have (it may be the least of my worries compared to my top end problem). My plastic is mostly gone anyway so I have no problem modifying thing for function over form. I do not have any machining or metal working skills though, so did your shock just bolt onto the existing mounts. I usually end up with pod air filters anyway. That is what ended up happening to my Buell also.
Ratch
88 NX-250
Ratchdaddy is offline   Reply With Quote
Old 04-20-2009, 07:34 PM   #1586
Ratchdaddy
Ratchdaddy's Avatar
Oddometer: 185
Bike update. Cant adjust valve clearance?
I took the bike into the shop after reading the forum and deciding that I had the classic symptoms of tight intake valves. Here were my symptoms;
-hard starting, bike would spin like crazy but would not catch or even cough.
- Lack of power, I rode another NX250 for seat of pants comparison.
- bike seemed to be getting too hot.
- Lots of clacking valve noise
I took it into the shop and the mechanic called me back today and told me he could not adjust the valves because the smallest shim available was already in there. He also said that the exhaust valves were really loose and that was probably the noise I was hearing.
He said that he would probably have to replace the valves and the guides and the estimate was over $500. I picked up the bike because I cannot swing that kind of money right now. I am probably going to try for a second opinion because I have had mixed results with this shop.
Does the mechanics description sound reasonable? If he is right, what is the most economical way to get the bike back on the road? I have some mechanical experience but this may be over my head.
I am looking forward to any advice or input.
Old 04-20-2009, 08:36 PM   #1587
wyowillys46
Hau Ruck!
wyowillys46's Avatar
Oddometer: 2,105
Your intake valves have sunk and need new seats installed and cut. $500 seems a little steep for a one cylinder head. I had new seats, guides, and a mill job done on my car (6 cylinder) for about $225 a while back.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Old 04-20-2009, 09:29 PM   #1588
dhw1179
Oddometer: 47
Clutch question
Finally got the clutch spanner tool, got the clutch off, swapped the plates, put it all back together, put it on the bike, but now I have no clue how tight to tighten the clutch springs down. The service manual doesn't say. Can someone give me an answer or point me in the right direction? Thanks
DHW1179
Floyds Knobs, IN
Old 04-20-2009, 09:57 PM   #1589
Ratchdaddy
Ratchdaddy's Avatar
Oddometer: 185
My problem I guess is finding a shop that can or will do it. Anyone have any recommendations for the Southern California area?
Ratch
04 DL650
88 NX250
Old 04-20-2009, 10:50 PM   #1590
Purzell
Wheelie scared
Purzell's Avatar
Oddometer: 150
What my old NX did today (well, Saturday)
As you know, I sold my NX. A nice guy bought it and some of us went dual sport riding this weekend. Thought you might enjoy this photo. The water was deep! The NX did great. The TW is a better bike for me but it's fun to see the NX out there making this guy happy.
2002 Bajaj Chetak
Purzell screwed with this post 04-18-2014 at 11:44 PM
Purzell is offline   Reply With Quote
Times are GMT -7.   It's 03:58 PM.
