Old 06-09-2008, 09:33 AM   #226
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,741
After i fooled with it for days, i finally switched out some things and got it to run like crap for a bit..
I took it on a spell up the road and it was spitting, missing and boggin'...
I pulled into a friends drive, and as i sat there thinkin, 'was that thee Satan, for real?' ... I heard the gas dribbling and gurgling , and i smelled it so i looked down...
I had a PUDDLE of gas sitting right below me...running out the carb overflow like a waterfall..
so I booked it home, turning off the petcock a few times...that was yesterday..
and today as far as i can tell, no flood issues, it still runs ok...
but, why did the snake show up, touch my bike, dang near crawls into it....and then my NX gives me a head and horns hissysnit??
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 06-09-2008, 03:40 PM   #227
Papa Pete
RIDES RED
Papa Pete's Avatar
Oddometer: 675
Cursed?
The curse of jerkos is appon you. Swing a dead cat three times counter clockwise ,while hopping on one leg facing east toward the rising sun
And never again post on the other NX thread!
You my friend need some good mojo and maybe a new plug, carb cleaned
and perhaps switch out your coil.
Papa Pete is offline   Reply With Quote
Old 06-09-2008, 05:44 PM   #228
selah
Crestone
Oddometer: 63
17 inch wheel gear ratios
Picked up a nice 17 inch xl wheel. Curious what those of you that have switched over decided on for sprockets? With what results?
selah is offline   Reply With Quote
Old 06-09-2008, 06:18 PM   #229
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,818
I used a 47t which is a tad low but would let me 80mph just before redline. A 45t would have been perfect for me.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 06-09-2008, 06:40 PM   #230
TLK
Oddometer: 19
My New NX250
Well I finally sold my 620 Multistrada and decided that the climate that I live in, both geographically and financially, was not fitting for a $5Kish motorcycle. That is when I came across this beautiful specimin. 1989 Honda NX250 with only 3100 mile and nary a scratch on it!
The pics:
Only problem is that the battery doesn't want to hold a charge. Runs like a top once the battery is charged!
TLK is offline   Reply With Quote
Old 06-09-2008, 06:50 PM   #231
valvecrusher OP
tractus pro pensio™
Oddometer: 1,741
I stuck with the 'stock ratio' gearing sprockets...
I think...the sprockets are the ones one it when i purchased it. I know the rear is stock 41.
I will confirm that as soon as i put on my new ones...which ARE stock.
It moved 6th into a 'true' overdrive, and moved 5th up to where the original 6th was with the 16" wheel. I like it, because now 3th and 4th are two highway (45 and 55 mph) passing gears, with 5th being the old 6th....
and 6th becoming a (65+) in the mid 6s on the tach, i think...
*I'll add the actual RPM numbers for speeds in*HERE* when i remember them, with the gearing i have.
Honda NX250??
valvecrusher screwed with this post 06-09-2008 at 08:37 PM
Old 06-09-2008, 06:50 PM   #232
valvecrusher OP
tractus pro pensio™
Oddometer: 1,741
The pics:
He's a beauty!!
Honda NX250??
Old 06-09-2008, 07:44 PM   #233
amishmotorscoot
scared fresh daily
Oddometer: 72
brand new to all things motorcyclic
After skulking for a month or so I finally am saying hello to the folks who ride the NX250. I purchased mine, a 1988 model,with just under 13k miles, in mid-April this year because I could afford it and I could reach the ground. (I'm 5'4" and 135 lbs) It is my first motorcycle in my 53 years and it is a hoot! I commute about 25 miles round trip and get about 80 mpg. I have learned a great deal from reading the two NX250 threads, though I currently am not making plans to visit Greece. The fellow I bought the bike from rescued it from a box, and did a good job of making it street safe. It currently has street tires (King Tire) which suits my present ride needs fine. I have added a pair of Waah-Mart driving lights w/35 watt bulbs (the 55w bulbs drained the battery as I rode!) so far this is my only mod. I do have a few questions for you-all, as your experience is far longer and deeper than mine.
1) fuel- my state (Oregon) recently mandated that all regular gas contain 10% ethynol - is this a problem in a motorcycle? Should I opt for the higher octane which does not have ethynol added?
2) rear rack - has anyone tried to fit the cycleracks rear rack to the NX250? the rack for the xr250l looks as if it might fit (with some mods?).
3) radiator hoses - I am currently disabled by hose leaks, I was able to slide the pre-formed sleeves off the old hose and hope to slip them onto new bulk hoses (much cheaper and available immediately at my auto supply store) - is this reasonable? ( I had ordered new hoses from BikeBandit but they were back ordered indefinately.)
pardon the long-winded post and thanks for your thoughts
AMS
amishmotorscoot screwed with this post 06-09-2008 at 07:53 PM
amishmotorscoot is offline   Reply With Quote
Old 06-09-2008, 08:29 PM   #234
TLK
Oddometer: 19
Thanks VC, and thanks for putting this thread together! Just enjoyed my first little ride on it; I am very impressed with the handling, and i am coming from a Ducati. Like I said, only issue i am seeing is this battery that won't hold a charge; would it be anything other than a shot battery? Also, any thoughts on jetting it my high altitude (i live at ~8000).
Thanks again.
Old 06-09-2008, 09:32 PM   #235
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,043
Ah sooo damn sweet
Looks spotless...quite a find!
congratulations
The pics:
my mini ride reports
"parts made of unobtanium"
ArthDuro is offline   Reply With Quote
Old 06-09-2008, 09:37 PM   #236
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,043
Damned be you devil!
stay away!!!!!
that my friend is pretty crazy
However check those fuel lines it might be unsafe!!
But seriously though thats a huge bummer, check that cam chain too.
Let us know how it goes... we need to shunt this curse
Originally Posted by ValveCrusher
I've been relatively free from problems in my last 10000 miles on the NX250 I ride daily.
Then I saw Satan.....no, not the obnoxious greekn type...the actual embodiment of the dark demon himself...all up in my NXs' grille...
I DON'T think he was looking for 'unsafe' mods either...
Old 06-09-2008, 09:37 PM   #237
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,043
[QUOTE=Papa Pete]The curse of jerkos is appon you. Swing a dead cat three times counter clockwise ,while hopping on one leg facing east toward the rising sun LOL LOL LOL
priceless Papa Pete!!!!!
Old 06-10-2008, 06:37 AM   #238
selah
Crestone
Oddometer: 63
A thing of beauty.
The pics:
8000 feet.... Where are you?
Old 06-10-2008, 10:28 AM   #239
TLK
Oddometer: 19
I'm in Big Sky, MT
Living the dream.
Old 06-10-2008, 02:11 PM   #240
Papa Pete
RIDES RED
Papa Pete's Avatar
Oddometer: 675
Big Sky
Welcome to the thread that has a sense of humor and won't poopoo you for making your bike the way you want it to be. There are many here who can help with answering questions for parts and service.
When ever you do something to your bike,just blame Jeff.
Times are GMT -7.   It's 07:57 AM.
