06-30-2012, 12:22 PM
#5356 |
travelin.tk
Oddometer: 53
One more question...
If I would like to replace my cam chain, I need to remove my clutch (been there, done that) and the primary drive gear. The manual states that I need a 'gear holder' to hold the gears when I remove the primary drive gear lock nut. I don't have a gear holder, what can I use instead??? Just a piece of soft wood between the gears? The last time I remove this nut, my cylinder head was off, so I put a piece of wood between the piston and the frame, but now I don't have the cylinder head off and I don't wish to take it off. Thanks for any advice! :)
Crossing Africa on 2 Honda NX 250s! www.travelin.tk |
06-30-2012, 12:44 PM
#5357 | |
Oddometer: 226
As for your other post of riding on tight valve clearance....it probably won't hurt anything. Probably. Usually tight valves will make a motorcycle more difficult to start. If the clearance gets worse, you may overheat and burn a valve. With the numbers you listed, I would feel confident to get to your destination. What about robbing some valve shims from the broken motor? Might be able to mix and match some to make it work.
Buncha dirt bikes with license plates. tntmo screwed with this post 06-30-2012 at 12:53 PM |
06-30-2012, 10:45 PM
#5358 | |
Oddometer: 135
tensioner
Ok, but that wouldn’t help you with your two options to choose Anyway, this wearing out issue is apparently a slow process (mine was increasingly rattling the last 28.000km to a point where I couldn't ignore it any longer) so I suspect that the sudden breakdown of your first engine has probably nothing to do with it. Did you check the lifter operation as described in the manual (see below)?
scrambler66 screwed with this post 06-30-2012 at 11:30 PM |
07-01-2012, 10:21 AM
#5359 | |
travelin.tk
Oddometer: 53
To answer your first question of a few posts back: Yes, the engine was making strange noises, already for a long time: http://advrider.com/forums/showpost....postcount=3648 http://advrider.com/forums/showpost....postcount=3659 But the most common answer was that it was nothing to worry about, although a few people mentioned the cam chain. http://advrider.com/forums/showpost....postcount=3665 I didn't have enough practical mechanic experience to understand the sound was the cam chain (if it was that sound). Now I know... The cam chain tensioner / lifter works according to the manual. I actually played around with 2 different tensioners before we started this travel, so see if I could make the sound go away. But it was all with the same half-worn chain, so same result, obviously. My cam chain guides seem to be OK and not too worn, except for the damage that the broken cam chain link did, now they are scrap. But they didn't seem to be so worn out as to lengthen the cam chain. I will run the replacement engine with the current cam chain and see how it sounds and then decide to change the cam chain or not.
07-01-2012, 11:00 AM
#5360 | |
All-season-rider
Oddometer: 88
Im also into suspension, both front and rear. Most probably I will go for Hyperpro all way. Most expensive, but also seems to be first class. In meantime, when raising funds (flirt my wife for some months...) I'll go for an ultracheap ($40) yellow SV650 and Hyperpro progressive in front. I talked with a Hyperpro dealer, who wrote excactly this: "It is just regular SAE40 fork oil, with a air gap of 150mm on this bike". So, SAE40 is a new one (for me), and air gap is 107mm as standard... That's a new twist in making better suspension! Maybe this 40-oil and 150 gap is something worth to try even on OE springs? ![]() Regarding oil brand/supplier, I have yet to see any neutral / objectively review. Personally I'll stick to well-known brands, who get's good results in motor-oil reviews. Until anyone convince me there is something brilliant better product than what i.e. Castrol/Valvoline does
Life is a just a game - lets play! |
07-01-2012, 11:56 AM
#5361 | |
Oddometer: 135
07-01-2012, 05:34 PM
#5362 |
Oddometer: 78
Wheels
Totally non-related to the cam chain /tensioner debate.
How would I find out if the wheels from a 82 cb650 would fit on the NX without buying them first? Front is 19 the rear is 18. I ask because a pair came up for sale locally with new rubber, but I hardly see any bikes on here with different wheels other than the 350XL or related 17" swap. Thanks. TB |
07-01-2012, 05:41 PM
#5363 | |
Oddometer: 7
The Hyperpro front kit includes the fork oil. I just got my kit Friday. I picked up the later SV650 shock because it has a lower spring rate and I wanted to make a smaller change, check it and go from there. Found some blue fork gaiters/boots and fork seals from Pyramid Parts on fleabay. Looking forward to getting this suspension upgrade in place.
NX, XR and bunch of honda trail bikes |
07-01-2012, 10:29 PM
#5364 | |
All-season-rider
Oddometer: 88
If I buy Hyperpro from another country, they cannot include the oil. Import regulations bla bla. That's why I got the oil viscosity and air gap from the shop :-) Hopefullly this odd combination of oil and air gap can be adapted succesfully to OE setup ![]() Yes, I have seen the later SV shock is a tad softer. If you cut the lower fork and makes a new hole for the bolt on the old SV-shock, this will be a tad lower than the newer.. So, its a choice, either way
07-02-2012, 12:57 AM
#5365 | |
Oddometer: 135
XL650V shock
scrambler66 screwed with this post 07-02-2012 at 01:19 AM |
07-02-2012, 02:29 AM
#5366 | |
Oddometer: 24
If the exhaust valves are under the same specs, there's a big chance they'll be scorched along the way. Just sayin |
07-02-2012, 03:41 AM
#5367 | |
Oddometer: 6
Kevan |
07-02-2012, 04:25 AM
#5368 |
Lost Boy
Oddometer: 2,973
Hondascoot mentioned he did a spacer in the stock forks to raise the front enough to clear a 21 wheel. I could accomplish the same thing by getting a set of custom wound springsthat are slightly longer, and get whatever spring rate we want at the same time. I'm weighing the cost benefit ratioof doing that versus swapping the forks with xr250 forks. Yes the xr forks are slightly larger diameter, but it's only 1mm. Either way I'd want to go through the forks and replace oil and seals, so that cost will be the same. The other advantage to the spring swap is we could do it in stages, springs first then the 21 wheel later. Thoughts?
Geauga Power Sports By riders, for riders. Ohio Motorized Trails Association Are you a member? OMTA on Facebook Baja info thread. |
07-02-2012, 11:44 AM
#5369 |
Oddometer: 4
Hi Everyone!
I've been lurking for awhile, but I thought I'd finally introduce myself. My name is Jill, and I am a pretty new rider, and my NX is my first bike. Muddyrabbit taught me everything I know about riding so far, and is now helping me fix my bike up. Prior to this, I knew nothing about working on motorcycles, but I am learning slowly! Thanks to tips from this thread, we were able to replace my old shock with one from an SV 650. What a difference it has made! My future plans include swapping that rear wheel to a 17'', and swapping the front forks/ wheel, as well. |
07-02-2012, 11:47 AM
#5370 |
All-season-rider
Oddometer: 88
Welcome Jill-the-Crazy
