Old 03-29-2013, 07:29 PM   #6196
heliyardsale
Always looking for Dirt!
heliyardsale's Avatar
Oddometer: 415
I have an NX250 in great shape I will sell in CNY. 1988 blue, ~5k miles all original. Price $1600 firm. PM me if interested.
An Alaskan bush pilot once told me "every great adventure begins with piss-poor planning"
Heli (Doc Mike)
heliyardsale is offline   Reply With Quote
Old 03-29-2013, 10:48 PM   #6197
Honda land cruiser
Oddometer: 14
Pics and all other details please....
HLC
Honda land cruiser is offline   Reply With Quote
Old 03-30-2013, 01:51 PM   #6198
tntmo
Oddometer: 529
I just posted a bunch of parts in the Flea market if anyone is interested. A complete engine and a bunch of bits and pieces.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 03-30-2013, 02:30 PM   #6199
crobox
crobox's Avatar
Oddometer: 324
Hondasuki KLNX250R
I posted a few times on here a few weeks ago, starting at post 6133 back on page 409. I am the guy who bought a beat-up, non-running NX250 which turned out to have a major problem with an intake valve, for $250. I'm also the guy who was considering transplanting the suspension from a CanAm 250, just so I could turn the NX into a little trail-rider practice bike.
Well I mentioned my ideas to a friend named Shawn (in fact the husband of the woman who sold me the NX) and he told me that he had a 1986 Kawasaki KLR600 rolling chassis (no engine, tank, seat, plastics, etc.) that I could HAVE. So I got to work.
Following is a list of the things I've done to the bike, which I privately think of as my Hondasuki KLNX250R.
Front end: From the triple clamps down, it's all KLR600. I pressed the steering stem out of the NX250 bottom triple clamp and pressed it into the bottom triple clamp of the KLR, although the NX stem was 2mm smaller in diameter so I had to machine a sleeve, 1mm wall thickness, complete with bottom "step", to make up the difference. Using the NX stem meant no worries about the bearings. Light machining was also required for the top triple clamp. I used the NX front brake master cylinder and brake line too, and bolted the line right up to the KLR caliper. I did have to tig weld in an extension to the brake line to make it longer. Also made some special brackets to mount instrument cluster and key-switch. Of course the bike also now has a 21" front wheel (although the tire is pretty worn out). Total cost: about $30 for KLR front brake pads.
Handlebars: Aluminum, from a Suzuki RM something or other. Free from Shawn. New Scott grips from Cycle Gear. Old mirror from some previous project. Total cost: $13 for the grips.
Front fender: leftover from my Honda XL600R project, painted blue. Cost: $8 for fancy plastic spraypaint.
Seat: From eBay. Needs to be recovered. I bought navy blue vinyl for the job, but haven't done it yet. Cost: $52 for seat and vinyl.
Footpegs: Swapped on the KLR footpegs, which are nice dirt-bike style. Easy bolt-on job, no mods required. No cost.
Rear fender: Piece of junk that was on there before, but I did re-position it higher up to fit with the seat better. Should probably be replaced one day. No cost.
Rear end: The tire from the KLR was basically brand new, as well as being a 17" rim. Too good to pass up. I decided the easiest way to use the back tire was actually just to use the swingarm from the KLR too. And, the swingarm is aluminum and pretty cool looking. A fair amount of ingenuity and machining was required to make it work. Lots of swapping of parts from both bikes and machining of new parts to make the swingarm pivot area solid and functional. I also had to modify the NX brake pedal to get it to fit in there between the swingarm and the frame. I also had to shorten the cable which goes from the brake pedal back to the brake arm, which was not super easy because it's a cable instead of a piece of solid round steel, like on the NX. The KLR was missing the brake arm, so I had to get that on eBay. Also had to buy brake pads. The original NX chain fit right on! Total cost: about $50 for brake pads and arm.
Rear suspension: Got a GSXR 750 shock from eBay for $22 shipped. There were cheaper ones, but this one looked good. The fit is not really plug 'n play. The top mount of the GSXR shock is 5mm wider than the NX, so the the little angled support arms on the NX (that go from the rear engine mounts up to the shock) need to be machined. Specifically, 2.5mm needs to be removed from the inside face of the top boss on each of these arms. The bottom fits fine. As many others have noted, this shock is not compatible with the stock airbox, which was no problem for me as I put on a UNI foam pod. However, it's also not compatible with the stock exhaust, which is something I do NOT remember reading. (Maybe I missed it). I also made new connecting arms to replace the "wishbone" connecting arm from the NX, near where the shock connects to the swingarm. I needed to do this because the KLR swingarm is configured differently, and I took the opportunity to make the link a bit shorter and get myself some more height in the back. Cost: $22 for the shock.
Exhaust: Once I realized I couldn't bolt the stock exhaust back on with the GSXR shock in there, I rooted around in my parts pile and found an old stainless supertrapp. I cut the bit of pipe off the original muffler (the part where it attaches to the header) and did a caveman job of welding the stainless muffler directly to it. I then totally reconfigured the mounting tabs from the supertrapp to mate up with all the mounting points on the frame where the original muffler used to be supported. The supertrapp had no baffle discs or rear cover, so I made those. No cost.
Kickstand: Extended by about 2 inches. No cost.
I've done a few other small things here and there, like re-routing cables and such, but that's the main stuff.
So let's see, the total cost is.....
(I'm curious too!)
$425.00. Not too bad. I haven't titled it yet. Not sure if I will. Shouldn't be a problem though, as the frame VIN and the engine number are unchanged, and that's all they care about in New Mexico. Ahhh, gotta love New Mexico!
I will do a few other things as time goes by, like add some "wings" to the fuel tank to protect the radiator, re-cover the seat, maybe add a headlight, and get into the head to deal with that problem valve (but only if I have to!!). For now it runs fine, and is lots of fun. And I don't mind dropping it!! (Although I haven't yet...)
Here it is:
If anyone wants close-up pix of anything, just ask.
Oh, and also... I've got a pile of parts from the NX that I don't need, such as: both sides tank fairings, headlight fairing, headlight, headlight mounting bracket, front fender, forks, complete front wheel, triple clamps (minus stem), speedo cable, complete rear wheel, rear shock (ooh, I bet that's a hot item!), swingarm, seat-pan (no foam or vinyl, plastic pan only), airbox, and maybe some other stuff. Fairings are decent, a few cracks and scuffs. I'll post an ad in the flea market one of these days, or PM me if you want something.
Cheers,
Christian
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox screwed with this post 03-30-2013 at 02:46 PM
crobox is offline   Reply With Quote
Old 03-31-2013, 04:20 AM   #6200
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 722
Wow, you don't hang around too long over a job do you?
Good work! The bike looks much taller than stock now. What sort of ground clearance would you estimate & roughly how much longer than stock is your wheelbase now?
Thanks,
P
Jacl-Kampuchea is offline   Reply With Quote
Old 03-31-2013, 07:09 AM   #6201
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,099
Jealous. I totally want a super beater trail type bike. That's what my XL was supposed to be before I got all Jay Leno's garage on it.
Carter Pewterschmidt is offline   Reply With Quote
Old 03-31-2013, 09:35 AM   #6202
crobox
crobox's Avatar
Oddometer: 324
Ha ha! Yeah, same with me. That's why I put this bike together... to get to be a better off-road rider without smashing up my showroom condition XL! I will say that the electric start on the NX is pretty great. No heavy boots required, just fire up and go. I find that I am using the NX a lot for my 100 yard "commute" between house and workshop!! Fun!
Old 04-02-2013, 03:45 PM   #6203
Psychoboy
Psychoboy's Avatar
Oddometer: 14
So I was out riding on Sunday and my front tire got a flat. So I pulled off called my wife to bring the trailer etc... etc...
Then I noticed my taillight lens is missing... Does anyone know where I can order this or have an extra they will sell me? The sites I know that sell OEM parts for this bike don't have it.
It's an 89' NX250 (I think all the NX250's are the same on this part)
Psychoboy is offline   Reply With Quote
Old 04-02-2013, 07:15 PM   #6204
CurtW
Thumper
CurtW's Avatar
Oddometer: 62
Originally Posted by victory80 View Post
...Btw does anyone know what temp thermostat or at what temp the fan kicks in? ...
I have a temperature gauge on my oil system, not the water, but the fan very consistently comes on when the oil hits 180 F.
CurtW is offline   Reply With Quote
Old 04-02-2013, 10:17 PM   #6205
Jacl-Kampuchea
Booze Merchant
Oddometer: 722
Dealer should have them as a few other honda bikes share this tail lens.
I bought a non Honda replacement for $15 recently from a local shop but I'm not in the US.
Old 04-03-2013, 02:56 AM   #6206
muzcuk
Oddometer: 62
Originally Posted by muzcuk View Post
The rubber dust seals were replaced along with the steering bearings, if that's what you mean. In my case they were impossible to remove without destroying anyways.
I am pretty sure mine is too loose. Is there a guideline describing how tight it is supposed to be? There is a weird nut sort of like an inverse flower that tightens it; it is under the nut that keeps the handlebar holder thingy in place. I reckon the flower-nut is crucial for adjusting the triple tree bearings tension, but I have no tools in hand to adjust it. Do you think I could just hit it with a screwdriver/hammer combo to tighten it above hand-strength?
Hey guys! Finally the rain ended. Turns out the imbalance was due to rear axle after all. Thanks to Honda Scoot, PTC and Local Machine for the help!
Here is a picture of the dent on the frame before I painted it. It is apparently not that big of a deal.
Also a picture I took from backside, yes I live in a fisherman's village. The local machinist was nice enough to let me use his shop for this project. Frame 'looks' straight for what its worth, doesn't it?
I have been working on this bike for months, on/off. I have no experience what-so-ever and only basic tools (and a dremel), and have I mentioned that I am broke?
Bike is in rideable condition as of now, only few details to be solved (mostly electrical). I have no plastics except for the airbox cover (and its pair on the other side).
The bike had a running engine but a messed up front end when I bought it. It had some sort of custom fiberglass fairing which I took down. I know many guys despise stripping these bikes but my idea was to remove everything that would be hard to maintain and/or might get loose with vibration. This bike will become the perfect machine for ripping through Istanbul within a month. I want to take it for a 5000 km trip around the black sea (Turkey - Georgia - Russia - Ukraine) at the end of the summer. I want it to be bulletproof.
I have taken priceless advice from this community, and for this I salute you. Due to the nature of the project I was unable to document it properly, and for this I apologize. I will at least give you a tour when it is done.
muzcuk screwed with this post 04-03-2013 at 03:17 AM
muzcuk is offline   Reply With Quote
Old 04-03-2013, 11:44 AM   #6207
Ratchdaddy
Ratchdaddy's Avatar
Oddometer: 185
Please document your trip and keep us posted. After riding my F800GS through some technical stuff in Death Valley last week, I started thinking about a smaller dualsport like a DRZ400. Instead I think I will put the money towards making my NX250 reliable and use it for trailriding.
Ratchdaddy
2014 R1200 GSA
1988 NX250
1977 Condor
1987 Honda Battle Spree
Ratchdaddy is offline   Reply With Quote
Old 04-04-2013, 08:40 PM   #6208
scrambler66
scrambler66's Avatar
Oddometer: 328
new seat
Spring is just around the corner (at least according to calendar), the white stuff almost gone, so time to revive my Xl250 degree. Which I never would drive on salty roads, it’s enough that my Nixie is rusting away. Since the original seat foam was too soft, I took the seat to Kahedo (BMW drivers know this name) for a harder and somewhat higher foam. Back in the nineties, Kahedo already produced NX250 seat covers, so he still had the pattern, even with the “Honda” label on it (which the Euro-Nixies had). Since I didn’t like the mint green of the original Degree seat cover, I selected the dark blue of the 1988 NX250 (compare with the Nixie in the background). High quality and it’s as close to original as it gets – but it cost me a fortune.
scrambler66 is offline   Reply With Quote
Old 04-05-2013, 04:08 PM   #6209
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,752
scrambler, is there any of this 'harder, higher' foam still available?
PM me the details..
__________________________________
In other details, the NX with 50,000 miles was broken down to 'do the valve adjustment'...
Well, ALL the valves measured EXACTLY in spec
....so, didn't change anything but the oil...
took a cellphone pic to show the cam's lobes, and how perfect they look...
(couldn't find regular camera)
now just trying to get pic off the phone, up to the 'net..
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 04-05-2013, 07:27 PM   #6210
plibnik
Oddometer: 7
Originally Posted by thedutchrockstar View Post
Motorcycle kit:
I also recommend you change the standard gear lever for the foldable one from the xl250? and you add some bar weights.
Just for the peace of mind that if your bike drops a couple of hundred kilometers away from home that atleast you can still keep on going.
And if you are planning on going through the Netherlands give me a PM.
I can provide a place to stay for a night or longer, a maintenance stop for the bike and if any repairs are needed they can be performed.
And don't forget the camera we want pictures!
Hello! I'm not all that late - just one year has passed!
The trip was changed, I urgently bought a Transalp and we made a Trans-Alp journey. Yet I won't sell my trusted AX-1, never!
Thanks for your advice, it came to be of use.
And look whom I saw at one of the mountain passes!:
This little dude got to Grimsel pass from the islands! It had British license plate and speedo in MPH, not KPH. Cool!
plibnik is offline   Reply With Quote
Times are GMT -7.   It's 10:10 PM.
