Old 05-02-2013, 03:30 AM   #6256
scrambler66
scrambler66's Avatar
Oddometer: 316
round headlight
Hi Sergio,
everything is possible if you really want it 37mm headlight brackets, round headlight and speedo are easily available at eBay or elsewhere. The main problem, however, is with the steering lock, which is in the way. So either you got to mount the headlight low enough or you have to eschew the lock, just like that guy from the German Dominator forum.
scrambler66 is offline   Reply With Quote
Old 05-02-2013, 09:25 AM   #6257
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,748
Originally Posted by larry31 View Post
Tomorrow I pull the plastic and do-the-dirty-deed!
Must be something common. First try the left one flashed, and last year before winter storage, everything was working.
low voltage, bad bulb, or bad flasher unit....
Mine was a bad relay flasher unit, it's behind the headlight, under the cowl..
It's a black, cubic(roughly) about 25mm square by 30mm, 18mm deep? (approximation)
Does anyone have a 'chain SLIPPER' they don't need? not the slider, the slipper....
<=== needed...
please PM me if you have a spare one, thank you !
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 05-02-2013, 04:42 PM   #6258
tntmo
Oddometer: 505
Where is the chain slipper located?
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 05-02-2013, 06:17 PM   #6259
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 300
Turn Signals
Quote: by Valvecrusher
"low voltage, bad bulb, or bad flasher unit....
It's a black, cubic(roughly) about 25mm square by 30mm, 18mm deep? (approximation)"
Thanks for all the info guys.
I jumped the flasher wires, and the lights on left light up when switch is left.
Right lights come on when turn switch is to right.
All circuitry and lamps are ok.
I put a flasher in from local auto parts store and turn signals work ok now. A little slow to start flashing but enough to get it inspected.
I ordered a Honda flasher from dealer. Will swap out when it comes in.
Took it for a nice 100 mile jaunt, today, around some paved, and not paved roads with a buddy. 70 deg's, sunny, and it's been dry here for a couple of weeks, so not much mud on abandoned roads currently.
I love this bike!!!
larry31 is offline   Reply With Quote
Old 05-03-2013, 11:23 AM   #6260
valvecrusher OP
tractus pro pensio™
Oddometer: 1,748
It's on the left lower 'B' spar of the main frame...
Located in between the left primary footpeg, and the kickstand mounting bolt..
Or if you can suggest a supply for high density delrin(or high wear plastic resin) block,
i could shape/build/form one from raw stock ?
It's part #10, and the 'stay' that it mounts to is part #5.
Honda NX250??
valvecrusher screwed with this post 05-03-2013 at 11:33 AM
Old 05-05-2013, 01:08 AM   #6261
Kingkobaa
Kingkobaa's Avatar
Oddometer: 13
Speedo cable
Does any other bikes speedo cable fit honda nx 250? I would need a cable that is few inches longer.
Kingkobaa is offline   Reply With Quote
Old 05-05-2013, 03:28 AM   #6262
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
A few, most obvious being the NX650 Dominator.
Why do you need a longer one?
Jacl-Kampuchea is offline   Reply With Quote
Old 05-06-2013, 11:11 AM   #6263
Kingkobaa
Kingkobaa's Avatar
Oddometer: 13
The original can't quite reach the instrumental panel when I lifted it up. I did this because I fitted my NX with buell dual headlights.
Old 05-06-2013, 12:53 PM   #6264
gloud
Oddometer: 158
Mcmaster carr will have the delrin block. I just bought some to have on hand.
gloud is offline   Reply With Quote
Old 05-11-2013, 02:45 PM   #6265
tntmo
Oddometer: 505
If you still need the slipper, I have one. PM me.
Old 05-13-2013, 05:08 PM   #6266
mp350
Oddometer: 17
Got a what I thing is a carb issue and need a little help. Just got to take the bike for a test ride and it won't go over 50 mph, if you give it more throttle it sort bogs and feels like the brakes have been put on. When I rebuilt the carb I stuck the needle clip on the third notch, so to I go to the 4th or 2nd notch. Thanks
mp350 is offline   Reply With Quote
Old 05-13-2013, 05:17 PM   #6267
Dirtstar1
Human torpedo
Oddometer: 121
A lean carb makes more RPM's and a rich carb makes more torque but is less efficient. Moving the needle up pulls it out of the main jet sooner. Move it back down and it leans out the mid circuit.
Was it windy? heavy air make my bike slow. Try your test again at night or early in the morning and see different results.
Dirtstar1 is offline   Reply With Quote
Old 05-13-2013, 06:10 PM   #6268
mp350
Oddometer: 17
Rode to work at 6 am and back home at 5 pm, Bike acts the same. The stock needle only had one clip with no washers, new needle ( has 5 notches ) set on third clip no washers. When I got the bike carb was leaking and running rough. Did the following... changed oil,air filter, cleaned & rebuilt carb . Bike has 13,000 miles and I live at sea level. Now it does idle at about 2000 rpms. Motor does not make any strange sounds or smoke. Plan is to take the carb off go to 2nd notch and put in a new plug for good measure. Put it sure is a pain to get that carb out. Thanks
Old 05-14-2013, 02:22 AM   #6269
Local Machine
Oddometer: 70
The position of the needle controls the mixture supplied by the venturi, so imho this is not the cure. The venturi jet is responsible for your midrange rev mixture.
At high revs the slide is all the way up so it must be something else.
I'd bet on a clogged main jet or a worn our rubber tip needle down at the carb floater section.
Local Machine is offline   Reply With Quote
Old 05-14-2013, 04:34 PM   #6270
mp350
Oddometer: 17
Took carb off and placed on section notch, still the same it goes flat right above 5000 rpms. Local machine I will have to take it off and clean again, but when a rebuilt it the only reused part was the float all other jets replaced with new parts. The only part not installed was the adjustable jet, didn't think I would need it since it is sealed. But that also may be the clogged part of the carb. So I guess I will drill it out and install it too. Thanks for the input.
Times are GMT -7.   It's 08:18 AM.
