Old 06-29-2013, 10:33 PM   #6361
elcaptainq
Oddometer: 2
front right large plastic for sale. Blue. Side left as well ( the smaller one) OK condition. Pm with offer
elcaptainq is offline   Reply With Quote
Old 06-30-2013, 12:29 AM   #6362
aquajake
Oddometer: 3
So, I recently purchased one of these bikes, and I love it already! I've been lurking on here for a while, and looking for one of these bikes. When one popped up on my local Craigslist, I jumped on it. After I bought it though, I noticed something as we were loading it into the truck. It appears to have a broken weld in the area indicated by the red line in the attached photo. (Hopefully you guys will be able to see where I'm talking about) It looks like an engine mount or something? Have any of you guys ever seen anything like this?
aquajake is offline   Reply With Quote
Old 06-30-2013, 12:39 AM   #6363
wiltouterrain
Oddometer: 9
Originally Posted by scrambler66 View Post
Today is your lucky day, because we already solved that problem a couple of weeks ago in our German NX250 forum – and another one, which you are probably not even aware at this point:
Honda never sold sealing and bearing or the complete front cover separately, so you would have to buy a new starter engine. But don´t bother, it’s not available anymore.
The dimensions of the starter engine front cover (towards the starter gear) sealing and bearing are pretty exotic (13.5mm) and not easy to get:
Sealing BC1693F 13.5 X 24 X 6
Bearing HK 13.5 X 19 X 12
We finally found a source in Germany, but in other parts of the world you have to look for yourself ;-).
But there is another option: the Mitsuba starter engine is used in 99% of all motorcycles and ATVs, only the cover differ. So you can take a complete front cover from a TRX ATV, spare part number 31210-HC4-003.
The TRX cover has a one piece sealed bearing without a lock washer, so when used on a NX250 starter engine, you must eschew the lock washer.
As for the reason for the water-oil emulsion: if the o-ring (nr10) is leaky, the engine sucks in air, and the moisture of the air starts to accumulate in the starter gear and starter engine. The next thing that usually happens is that the bearing of the front cover starts to corrode and the starter engine will make a lot of unpleasant noise.
my starter makes an hrrible noise!!
So des it come from the special Bearing HK 13.5 X 19 X 12?
I saw a 900 cbr starter for cheap,mistuba MT-23,does it fit directly? and no more noise?
the starter: http://www.leboncoin.fr/equipement_m...36.htm?ca=12_s
mine,like a lifting:
wiltouterrain screwed with this post 06-30-2013 at 04:19 AM
wiltouterrain is offline   Reply With Quote
Old 06-30-2013, 04:20 AM   #6364
wiltouterrain
Oddometer: 9
but I still miss that:
Old 06-30-2013, 08:51 AM   #6365
Sparke
Oddometer: 469
Rear tire swap info needed
I have been backtracking through this thread but can not find the accurate info on what 17 inch wheel swaps correctly. Please inform me , thanks
Sparke is offline   Reply With Quote
Old 06-30-2013, 09:02 AM   #6366
aquajake
Oddometer: 3
Try the first page of this thread, there's some links there. (I believe the info for the wheel swap starts on page 67)
Old 06-30-2013, 10:08 AM   #6367
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,752
I am very sorry to not have properly indexed this growing thread by now.
have made several attempts, but nothing has been accomplished at this point.
I will complete a new (better) index as soon as reasonably possible, and it will be much easier and complete.
Again, my apologies for not already having this done.
The wheel you are looking for comes from the
1984-1987 XL250R honda, or
XL350R honda.
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 07-01-2013, 09:57 AM   #6368
IamsaparoS
Oddometer: 31
Hello friends.
you can look spare parts for the AX-1 MD21/MD26/MD31 and another here.
http://auctions.isibike.com/?catId=0&freeWord=AX-1+MD21
IamsaparoS is offline   Reply With Quote
Old 07-01-2013, 11:28 AM   #6369
scrambler66
scrambler66's Avatar
Oddometer: 328
Most likely. It`s almost always the front bearing of the starter engine, in very few cases the bearings of the starter reduction gear corroded, resulting in similar noise.
Since my crystal ball is in repair I have no idea As said, the starter engines are the same but their front covers (back covers as well) are different and I do not know which other might fit.
Moreover, since that bearing is a weak point of those starters, most used ones are also defective, so even if that starter engine fit, it might continue screeching.
Here you can get sealing and bearing
http://www.al-electric.de/?aktion=nu...1693f&pid=3801
http://www.al-electric.de/?aktion=nu...19x12&pid=3303
scrambler66 is offline   Reply With Quote
Old 07-02-2013, 08:54 AM   #6370
valvecrusher OP
tractus pro pensio™
Oddometer: 1,752
MANY starter motors are identical with different nose pieces(shaft and gear wheel) and different backs..
but the motor length/depth + diameter (body case) is the determinant iirc
For example take the Nighthawk 450 starter, switch the NX nosepiece and now viola'
NX starter...
(THAT was a FOR EXAMPLE, i'm NOT stating that the Nighthawk450 starter will exchange, but to give an example to what Scrambler66 was trying to say)
I will dig around and see if i can find the starter motor 'common bike' list..
I know i saw one somewhere
Honda NX250??
Old 07-02-2013, 09:47 AM   #6371
tntmo
Oddometer: 529
I found a modified SV650 shock laying around from my old NX, if anyone is interested in it let me know. Cheap!
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 07-03-2013, 10:23 AM   #6372
valvecrusher OP
tractus pro pensio™
Oddometer: 1,752
After some thought, i seem to recall CustomerService(Sir Mobs) covering this early on IN THIS THREAD.
I'm sure it's in here, search this thread or his posts...
I knew this was covered...just took a little thought
Honda NX250??
Old 07-03-2013, 11:47 PM   #6373
wiltouterrain
Oddometer: 9
too me,the best choice are kawasaki er5 wheels because front wheel has the disc on lthe left and rear wheel has drum brake.
On my bike,I put cb500 wheels (and fork,more slower and stiffer),that's such à probleme with front disc on the right,odometer doesnt work...
wiltouterrain screwed with this post 07-04-2013 at 10:06 AM
Old 07-04-2013, 01:49 PM   #6374
Ratchdaddy
Ratchdaddy's Avatar
Oddometer: 185
SV650 shock
I am interested. Just got my NX250 running again this morning.
Ratchdaddy
2014 R1200 GSA
1988 NX250
1977 Condor
1987 Honda Battle Spree
Ratchdaddy is offline   Reply With Quote
Old 07-05-2013, 10:39 AM   #6375
petros600
Oddometer: 37
Looking for Cluster background lights replacement
The instrument panel background lights are burned on my nx250. Any idea from where i can order them or did anyone convert them to LED's?
petros600 is offline   Reply With Quote
Times are GMT -7.   It's 06:02 AM.
