Old 07-22-2013, 07:13 PM   #6406
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 309
A Sunday Evening ride
Took the NX out last night.
http://youtu.be/hBU6Z3kPVII
larry31 is offline   Reply With Quote
Old 07-24-2013, 10:25 AM   #6407
Neiz
Oddometer: 1
NX 250 problem
Hi guys i recently got me an NX 250 from 88 and she runs smooth, however the front brakecaliper is game over, and has a problem finding a new used one, however found a brake caliper from a honda XR650 it looks the same but does it fit my NX250. perhaps taking the bracket from the old caliper and fit on the the XR caliperhope you guys can help thanks a bunch in advance
Neiz is offline   Reply With Quote
Old 07-24-2013, 09:57 PM   #6408
scrambler66
scrambler66's Avatar
Oddometer: 322
XR650L caliper
The XR650L (dunno ‘bout the XR650R) and the NX250 got the same calipers but different brackets. So as you said, the combination NX bracket / XR caliper fits perfectly. BTW, the bracket of the XR650L was designed to fit the NX650 front wheel with larger 256mm brake disk. So with the XR650L bracket (or the complete XR caliper, as shown below), you can mount a NX650/XR650L front wheel in the NX250.
International NX250/650 Riders Board http://forum.nx250.de/viewforum.php?f=20
My NX250/AX-1/XL250 Degree homepage
http://www.nx250.de
My NX650 Scrambler http://advrider.com/forums/showthread.php?t=766897
scrambler66 screwed with this post 07-24-2013 at 10:07 PM
scrambler66 is offline   Reply With Quote
Old 07-27-2013, 03:35 AM   #6409
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
Got my bike back together. It seems that the thermostat broke, which caused it to get hot as shit and blow out the water-pump seal and the head-gasket. New head gasket, new meechanical seal on waterpump and no thermostat from here on, just free flow.
Re-seated two valves and now it purrs like a kitten.
Cost of repair to me - $88.25.
Lovely Now to treat her to a bit of cosmetic work. . .
Jacl-Kampuchea is offline   Reply With Quote
Old 07-27-2013, 04:32 AM   #6410
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 309
Another NX250 adventure
I rode my NX over 250 miles yesterday. Left home and traveled up through our White mountains here in N.H.
The highlight of the trip was my ride up Mount. Washington Auto road.
Here's a 13 min. video of that ride up. http://youtu.be/Xgd4QzoEOiA
BTW: The NX performed flawlessly.
Old 07-27-2013, 09:35 AM   #6411
scrambler66
Oddometer: 322
chain tick
Originally Posted by thirstybuck View Post
However, even when I've made the adjustment on a warm running engine and takeout just enough slack to eliminate chain tick/slap I still get brief chatter from 4.5-5.5k rpms upon de-accelleration.
Did you ever solve that problem?
Sounds suspiciously like something I experienced with another NX – the timing chain is new (but an aftermarket one, maybe that’s the problem), the tensioner seems to be ok – but still there is a slight, but disturbing rattling during de-acceleration. Maybe a broken piston ring? Has anyone an idea?
http://www.nx250.de
Old 07-27-2013, 07:29 PM   #6412
Gebogen
Gebogen's Avatar
Oddometer: 524
AX 1 Plastics
Has anybody bought the AX 1 plastics they are advertising on Ebay? Do the AX radiator shrouds fit on the NX tank?
Gebogen is offline   Reply With Quote
Old 07-28-2013, 01:13 AM   #6413
scrambler66
Oddometer: 322
they fit - I use them on my NX250 BigWheel project number 3
http://www.nx250.de
Old 07-28-2013, 06:41 PM   #6414
polarized
Dirt Virgin
Oddometer: 23
Nice bike Scrambler, thanks for the pictures.
Just ordered a pair for mine.
Now I just have to figure out something for the headlight as the cowl is busted up and ready to fall off...
polarized is offline   Reply With Quote
Old 07-28-2013, 11:55 PM   #6415
PinteroFuscetti
Oddometer: 6
cdi
Hello,
Has anyone ever tried any of these cheap CDI units ... if they work at all...
I am thinking of buying one as a replacement and test since they are kind of cheap... but if someone allready been there i'd rather not get into trouble.
Thanks.
www.ebay.com/itm/400335541428
www.ebay.com/itm/190779214762
www.ebay.com/itm/321026126707
www.ebay.com/itm/160408508664
www.ebay.com/itm/180435075822
www.ebay.com/itm/310713057962
PinteroFuscetti is offline   Reply With Quote
Old 07-29-2013, 02:52 AM   #6416
Local Machine
Oddometer: 70
Have you checked the condition of the aluminum head cam mounts?
I had a funduro beemer once that used to rattle like that.
I had to replace both the mounts and the cams on that thing. I was lucky because all them rotax singles have detachable mounts and there was no need for a brand new head.
If thats the case try to find a pair of AX-1 cams, the lobes are a bit longer and thats a good thing.
Local Machine is offline   Reply With Quote
Old 07-29-2013, 04:22 AM   #6417
scrambler66
Oddometer: 322
never mind, found the reason
Now that’s the kiss of death for that engine. A piston pin with too much play - the piston rod was never sold separately by Honda, the complete crankshaft is not available anymore – and most used ones are probably in a similar condition. Dang. I wish I'd live in Cambodia where somebody would fix that for 88 bucks ;-)
http://www.nx250.de
scrambler66 screwed with this post 07-29-2013 at 07:39 AM
Old 07-30-2013, 04:48 AM   #6418
Impulse2k1
Oddometer: 39
Does anybody know where I can get a set piston rings for the NX?
Impulse2k1 is offline   Reply With Quote
Old 07-30-2013, 10:52 AM   #6419
tntmo
Oddometer: 515
They still sell them, order from any parts site.
Buncha dirt bikes with license plates.
tntmo is offline   Reply With Quote
Old 07-30-2013, 04:28 PM   #6420
CurtW
Thumper
CurtW's Avatar
Oddometer: 62
Originally Posted by PinteroFuscetti View Post
Hello,
Thanks.
Just reading the descriptions, I would not expect any of those to be compatible. If you could run an NX off of a GY6 CDI, *somebody* would have discovered that by now--it's probably the most common engine on the planet, and cheap CDIs for that engine have been plentiful for years.
CurtW is offline   Reply With Quote
Times are GMT -7.   It's 04:31 AM.
