Old 07-31-2013, 08:35 AM   #6421
muzcuk
Oddometer: 62
Hey guys, my new head gasket has arrived, I will re-do the head this weekend.
I was thinking of loctite-ing the cylinder head cap nuts while I'm at it. What is your opinion about that?
I think if they came loose once, they can do it again, I want to do it right before I sell the bike for peace of mind. The new owner might not be as handy with tools as I am .. Also, I loved this bike and I don't want it falling apart.
My torque wrench won't fit to torque inside nuts, so its going to be manual torquing with a 3/8" driver. I am scared shitless of snapping something by over-tightening.
muzcuk is offline   Reply With Quote
Old 07-31-2013, 01:41 PM   #6422
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
Don't loctite with red loctite. Blue is O.K.
Get a proper torque wrench.
Jacl-Kampuchea is offline   Reply With Quote
Old 08-01-2013, 03:07 AM   #6423
Local Machine
Oddometer: 69
The first thing youll hafta do is make sure the head rests totally flat against the cylinder. maybe youll need to send it to a machine shop to make sure there aint any kind of warped surface on that thing.
Dont over-tighten the head. Run that thing for 200-300 miles, let it cool down and re-toque those bolts. You wont be needing locktite . I dont think this is a good idea.
Local Machine is offline   Reply With Quote
Old 08-01-2013, 04:11 AM   #6424
micahshaw
Oddometer: 54
front hub options
i'm doing the CR80-85 front fork conversion with a twist-
17" front wheel.
i have a 36 spoke rear XL250 wheel that i can use the 17" rim off of.
(i'll have Barnett make a spokeset)
i want to keep my stock 19" NX wheel assembly as back up-
question is what hub will fit the stock NX fork?
i at least need a baseline for fitment between the CR forks
micahshaw is offline   Reply With Quote
Old 08-01-2013, 07:25 AM   #6425
andreasax-1
Oddometer: 2
Xenon AX-1
Hello,
I recently became an owner of old AX-1 and i want to install xenon.
Has anyone successfully installed xenon on AX-1?
If yes what type?
andreasax-1 is offline   Reply With Quote
Old 08-01-2013, 02:59 PM   #6426
slabo
Oddometer: 15
Hi, I'm picking up an AX-1 tomorrow. My previous bike was a 1994 XL250 Degree, almost same like this was stolen. I really like it.
Anything in particular I should like look out for in these bikes? Is the riding position more forward than the XL250 ?
What issues to look for on those white aluminum wheels?
Any help appreciated, thanks
slabo is offline   Reply With Quote
Old 08-01-2013, 06:07 PM   #6427
victory80
Oddometer: 21
new rear wheel
Hey nx'ers just wanted to show you my new rear wheel setup. Said goodbye to the old 16" and hello to 17" and better street tire selection. These are about the widest tires to fit while keeping the fork brace and perfect spacing for the rear. Specs as follows:
Excel 17x4.25 150/60
Excel 17x2.5 110/70
 photo 7FFDA045-6E3F-4989-BA2C-B99FD454115A-7349-00000BBBA9DC6356_zps94e4c3cc.jpg
 photo 29EE3E79-905B-480C-B3A9-9E971483F7D3-7349-00000BBB9414E8FA_zps08b26c77.jpg
 photo 0690D13E-0809-4A46-A917-65843C624A10-7349-00000BBB9CD93060_zps8137d8b2.jpg
 photo BBE05225-6090-4887-B133-718AD13F2804-7349-00000BBBA34D7F2B_zpsa150dfe0.jpg
 photo 08AA1302-BD2E-484B-861D-A8ABF6ACBE15-7349-00000BBB76C79618_zps09c39732.jpg
victory80 is offline   Reply With Quote
Old 08-02-2013, 06:03 AM   #6428
Jacl-Kampuchea
Booze Merchant
Oddometer: 721
Very nice job. Direct bolt up to the original hubs, I guess?
I'm tempted to buy a newer XL Degree rear hub ( newer ones had rear disk brakes ) and do a similar conversion on my AX-1.
Decent 16/19 tubeless tires are like rocking horse shit here.
Old 08-02-2013, 02:41 PM   #6429
victory80
Oddometer: 21
Yeah using the stock hub for the front and xr350 hub for the rear. I wish I had discs but these drums work well enough.
Old 08-03-2013, 12:30 PM   #6430
OzTiger
OzTiger's Avatar
Oddometer: 85
Clutch Problem
Howdy all,
I just replaced the clutch in my wifes NX250. Following IBJim's very handy instructions, it all appeared to go smoothly. However, once assembled and ready to test I have no clutch at all. No matter how much a adjust either end of the cable it has no clutch...Not a slipping clutch...just fully engaged all the time.
I replaced the friction plates, discs and springs using ebc stuff..i lubed the friction plates before installing them etc.
Any ideas where I went wrong? Wife will shoot me if her ride isn;t ready by West Fest next weekend.
OzTiger is offline   Reply With Quote
Old 08-04-2013, 07:05 AM   #6431
legends117
Oddometer: 56
CDI question from N00b
Hey y'all - I have had an '89 NX250 since last October, and finally gotten it all sorted out and just started putting some miles on it. It is a fun little bike - BUT, I think I have discovered the dreaded CDI fault and would like a second opinion.
When riding the bike a highway speed (60mph) and close the throttle to slow down, and the bike cuts off (0 rpm on the tach). I can thumb the starter button and it starts immediately (while still in motion); so I was wondering if the "experts" on this Thread thought that was CDI related, or carburetor related? The carb has not given me any other problems, so I thought it was CDI, but before purchasing a new one, wanted another opinion.
Thoughts appreciated - Peace - JD
Peace - JD
'89 Honda NX250
'11 Triumph Tiger 800
...currently, but always looking for the next one
legends117 is offline   Reply With Quote
Old 08-04-2013, 01:34 PM   #6432
Jacl-Kampuchea
Booze Merchant
Oddometer: 721
Not typical CDI symptoms, if it fires back up every time.
Old 08-04-2013, 03:49 PM   #6433
mp350
Oddometer: 17
carb problems still
Ok cleaned and put a new kit in my carb ran well for one day then would not idle, but could keep it running in the higher rpms. Got me a used carb clean it up and installed, having the same problems with it. So is there something else to look for or just throw a match to it?
mp350 is offline   Reply With Quote
Old 08-04-2013, 04:37 PM   #6434
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 294
Carb
You don't mention if you checked the gas tank, gas filter, gas lines, etc.
Could you have crap in fuel system getting in the carb.? Check vent on gas cap and any lines attached.
larry31 is offline   Reply With Quote
Old 08-04-2013, 05:37 PM   #6435
mp350
Oddometer: 17
carb
Tank is clean, new fuel line and filter, plus plug,air filter and oil changed.
Times are GMT -7.   It's 09:54 AM.
