Old 08-04-2013, 09:07 PM   #6436
micahshaw
Oddometer: 54
Originally Posted by victory80 View Post
Yeah using the stock hub for the front and xr350 hub for the rear. I wish I had discs but these drums work well enough.
well done sir-well done.
micahshaw is offline   Reply With Quote
Old 08-04-2013, 10:25 PM   #6437
allmotor
Oddometer: 5
whats a safe size the xr 17" can hold width and tall wise?
Originally Posted by scrambler66 View Post
That’ll work
But the XR rim is way too narrow (2.15'') for a 130/70-17 – you need at least a 3.50'' rim. Here is an example of an NSR125 3.50-17 wheel with a 130/70-17 - fits quite well into the swing arm of my AX1 (which is the Japanese Version of the NX250)
allmotor is offline   Reply With Quote
Old 08-06-2013, 07:36 AM   #6438
SaDoW
Oddometer: 79
thats my baby .... restored and ready
it can go up to 145 km/h
what a wonderfull bike they made!
SaDoW is offline   Reply With Quote
Old 08-06-2013, 10:09 PM   #6439
allmotor
Oddometer: 5
what rear tire setup? gears?
Old 08-08-2013, 02:08 PM   #6440
SaDoW
Oddometer: 79
everything is as factory set them
exept exhaust carb settings and air filter
Old 08-09-2013, 09:44 PM   #6441
MadDoc
Oddometer: 10
Talking Finding the perfect handlebar replacement
Hi guys, I have been looking for a strong alloy and slightly higher handlebar for my lovely '88 AX-1. You know the original comes in steel and I guess previous owners had bent it several times cos it had lots of marks on it. Here's what I found: a Renthal 755-01 mine is gold colour.
It is a road bike type but has exactly the same width with OEM one and more importantly due to higher Rise (appx 2cm higher) and Height (appx 4cm) it gives you a much better off-road experience coz you can now stand on your bike with a normal pusture rather than riding like a monkey
Here's the specs:
Bend: Medium, W:725mm, H:115mm, Rise:85mm, Base:185mm, Sweep:105mm
My own measurements of OEM bar were: W:725, H:60, R:60, Base:200, Sweep 100mm
And the great thing is you don't have to worry about the clutch cable or any other thingy. Because the overall height is a contribution of both Rise and the additional height after the bend the clutch cable gets only 2cm upwars while you get a 4cm total rise on your hands.
Hope this is helpful to you blokes.
MadDoc is offline   Reply With Quote
Old 08-10-2013, 02:06 AM   #6442
Local Machine
Oddometer: 69
Originally Posted by PinteroFuscetti View Post
Hello,
Has anyone ever tried any of these cheap CDI units ... if they work at all...
I am thinking of buying one as a replacement and test since they are kind of cheap... but if someone allready been there i'd rather not get into trouble.
Thanks.
www.ebay.com/itm/400335541428
www.ebay.com/itm/190779214762
www.ebay.com/itm/321026126707
www.ebay.com/itm/160408508664
www.ebay.com/itm/180435075822
www.ebay.com/itm/310713057962
There are plenty of these cdis out there, that look the same but they are configured differently inside. I dont think that any of these babies will work on a NX or Ax1 bike.
The only aftermarket cdi that worked for me was one made by SUN Japan and it was pretty expensive. Not by a whole lot, but it wasnt cheap either.
If I remember correctly I had to fork out 80 bucks to get that thing and I still remember that it had the same code printed on the side. Just like the original.
Its been almost two years since then and my bike still works fine and to be honest I think it gave it a small boost at the top range, but I aint 100% on that.
Just sayin
Local Machine is offline   Reply With Quote
Old 08-12-2013, 09:59 AM   #6443
Sparke
Oddometer: 471
Renthal bars
Here's the specs:
How much to you think the height of the grips went up? How tall are you? I am wondering if this improvement is high enough for me? ..I am 5'10"
Sparke is offline   Reply With Quote
Old 08-13-2013, 02:25 AM   #6444
MadDoc
Oddometer: 10
Laugh
As I said about 4 cm rise on the grips...I'm 1.70m - medium size I guess - maybe small in US standards :P
Old 08-13-2013, 02:22 PM   #6445
natabata
Oddometer: 3
carburator
Hi guys,
today i tried removing the carb, because it needs cleaning.
so after two hours of trying i gave up, I just couldnt seem to get the carb out , there was always some part stuck at the gasket, and i can't imagine the carb fitting through that triangle hole.
Is there somthing really simple I'm missing?
I did open the air cleaner box screws, but it didnt help much.
natabata is offline   Reply With Quote
Old 08-14-2013, 05:26 AM   #6446
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
I undo the two clamps and fuel lines.
Then remove the throttle and choke cables.
Then from the sidestand side of the bike I work the carb left and as far into the intake on the head as it will go.
When it's gone that far I then pop it out at the airbox end.
Takes some stiff enough force, but once done once it's a piece of cake.
The fuel tank should be off to give you clearance and visibility while you work.
Jacl-Kampuchea screwed with this post 08-14-2013 at 06:17 AM
Jacl-Kampuchea is offline   Reply With Quote
Old 08-14-2013, 08:33 PM   #6447
HondaNX250
Oddometer: 4
Cdi
I went ahead and bought this CDI. I got it in the mail today. And i went to replace it and it was to small to go in the Holding Case. And then when i tried to start the bike it didnt seem like it had enough uff to start but would eventuality start. Its kinda like a stutter. Can you take a look? it says it compatible. But i think they sent me the wrong one.
http://www.regulatorrectifier.com/ca...X-250-CDI-Unit
HondaNX250 is offline   Reply With Quote
Old 08-15-2013, 04:43 AM   #6448
Jacl-Kampuchea
Booze Merchant
Oddometer: 721
What do you man by "uff"?
Old 08-15-2013, 12:48 PM   #6449
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,724
was your NX running with the original CDI?
have your checked your spark plug gap, or replaced the spark plug?
have you checked the Pulse Generator value?
Is the airway clear? (me and another user here both had something get sucked into the airbox, -mine over the air filter-) and it caused a 'stutter' .. and lack of 'uff'.
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 08-18-2013, 08:08 AM   #6450
Local Machine
Oddometer: 69
If I can recall correctly some of these aftermarket cdis have a difference on the wiring layout. I remember I had to leave one of the wires on my harness out of the game.
It's been a couple of years and I am not sure which one it was tho.
Times are GMT -7.   It's 05:07 AM.
